Honda Bearing Shells
davidimurray
PostPosted: 12:56 - 04 Oct 2006    Post subject: Honda Bearing Shells Reply with quote
Some of the guys at work are looking at rebuilding a dead CBR600 F4i engine that they use in their racecar.
Any ideas where they can get some new shells from?
Dave
finpos
PostPosted: 13:15 - 04 Oct 2006    Post subject: Reply with quote
Honda, for a start.
Best price the whole job before they get stuck in - they will probably find it's cheaper to buy a second-hand engine out of a crashed bike.
finpos.
irving
PostPosted: 17:11 - 04 Oct 2006    Post subject: Reply with quote
Arrow
quacker_boy
Cuddle Bitch
PostPosted: 18:07 - 04 Oct 2006    Post subject: Reply with quote
Dave as the other two have said, do a full on inspection of the engine first as in completley strip it and find out what needs doing, it may turn into a bit of a money pit depending on how 'dead' the engine is...
Another vote here for buying a second hand working engine and tinkering with it Thumbs Up
TheShaggyDA
Repost Police
PostPosted: 18:20 - 04 Oct 2006    Post subject: Reply with quote
https://www.davidsilverspares.co.uk/ might be able to help you, if not point you somewhere that can.
Robby
Dirty Old Man
PostPosted: 20:41 - 04 Oct 2006    Post subject: Reply with quote
Chances are a second engine is in fair nick, but the bike surrounding it has been destroyed in a crash.
On a CBR600 you'd have to work hard to knackered anything around the crank. Put that engine into a car and its working a lot harder pushing all that extra weight. Chuck in the extra factor that the kit/race car boys tend to take a bike engine then tune it past reliability, and a new (old) engine looks even more appealing.
Bottom line, bikes tend to crash or wear out their suspenion or suffer major electrical failure long before they wear out the engine.
PostPosted: 20:46 - 04 Oct 2006    Post subject: Re: Honda Bearing Shells Reply with quote
Dave
Hi David.
As said above, if the big-end shells are gone because of an oiling issue then there's likely to be crank journal damage. With 18 shells in the engine just replacing them and the gaskets will cost a few bob and if the crank is junked then you'll be better finding a new unit. That way you'll have the benefit of being able to build a spare engine in preparation for your next problem.
What kind of sump does the engine use? Stock, flat or dry-sump?
Paddy Blake
PostPosted: 22:51 - 04 Oct 2006    Post subject: Reply with quote
You will have to check the colors at the side of the shells to know what
ones to order.I just hope you didnt mix them up.If you did let me know.
Paddy.
0ddball
PostPosted: 23:33 - 04 Oct 2006    Post subject: Reply with quote
I'd take the old bearings along to a bearing supplier. If bikes are anything like cars a set of OE mains and big ends from a Honda dealer will cost over £200, good quality pattern ones cost about £40.
davidimurray
PostPosted: 09:17 - 05 Oct 2006    Post subject: Reply with quote
Hi guys
Thanks for the input. The stories behing these are rather horrid. The engines are used in a formula student car - only weighs 230Kg
They have in total 6 blown engines lying around! First one died because some of the holes in the throttle bodies where filled with liquid metal. This escaped and ended up between a valve and piston - mmm crunchy!
The rest have been due to oil failure - however most have been picked up as a rattle before anything catastrophic went. I know what the problem is and have told the guys working on the car - but they have yet to make suggested mods so they keep blowing engines. I worked on making a new custom sump a couple of years ago. I was very careful when we made up the internal baffling to ensure that none of the 'ports' lined up. The car ran fine for 18 months with that sump, bu they then damaged it and had to make another. Not much care was taken on the baffling, as a result they have killed 5 engines in 4 months!
Unfortunately most of the people involved are students who can do the most amazing computer modelling - but don't know one end of the spanner from another. As a result they haven't even cracked the casing to look inside. They also don't run an oil cooler any more - something I'm not a fan of!
They currently pay around £600 per engine. At the end of the day, it is in their hands - I just hate to see the engine graveyard everytime I walk past their workshop.
Dave
PostPosted: 12:00 - 05 Oct 2006    Post subject: Reply with quote
If they haven't modified the sump system it's no wonder they keep wrecking the cranks. My own bike has a flat sump and swinging pickup but that wouldn't suit a car application because it only swings one side. It sounds like the windage plate you made did a pretty good job, why not make a sandwich-type one that bolts between the cases and the sump and can be transferred between engines?
The best way is to make or buy a dry-sump system. I don't know exactly how the CBR600 setups work but some fit a mechanical oil pump driven off the water pump gear to supply the engine from a reservoir and exchange the stock water pump for an electric item.
I'll try to do some research for you, one of the sidecar boys might even have something to sell.
the grim reaper
PostPosted: 13:51 - 05 Oct 2006    Post subject: Reply with quote
A mate of mine raced Jedis with CBR6 engines in them and he used a plate between the sum and block to prevent oil starvation. This seemed to work, as the only engine he blew was down to poor fuelling on one cylinder.
One other item to consider is the clutch, a CBR6 weighs about 185 Kg dry, say about 300Kg with a fat bastard rider and a full tank etc. The cars weigh about 300Kg dry, so about 400Kg with a fat driver and fuel etc. There is also the issue that the bike doesn't have as much rolling resistance as the car, hence the clutches take a hammering.
Grim
The last post was made 19 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.69 - MySQL Queries: 16 - Page Size: 76.55 Kb
