zx6r servicing
Ferret
PostPosted: 21:05 - 05 Oct 2006    Post subject: Reply with quote
Did it have its valves done at 8000 and 16000 ? This is a must on these as the clearances go tight and that will at some point lead to a burnt valve
Brake fliud should be done every 4 years as it starts to turn acid through water absorsion ( or is that alkalin) and starts rotting seals.
ta
Ferret
BigChris
PostPosted: 21:34 - 05 Oct 2006    Post subject: Reply with quote
you'll need to replace plugs, check valve clearances, cam chain, fork oil, coolant, brake fluids, air filters etc.
while you're at it, get an arata race system, power commander, velocity stacks, fit the lot and get a custom map. That should give you sommat to do Wink
tatters
Exxon Valdez
PostPosted: 00:41 - 06 Oct 2006    Post subject: Reply with quote
Yokogeri wrote:
how much should valves cost to do? Ive not touched them since I've had it as I simply dont know how to do it, did look at the haynes and it looked a bit tricky.
Its normal around £100 in labour to check the valves and IF they need adjusting your looking at maybe another £200 ish for the extra labour and to change the shims.
Its a tricky job so don,t even try doing it your self scott.
tatters
Exxon Valdez
PostPosted: 00:50 - 06 Oct 2006    Post subject: Reply with quote
BigChris wrote:
cam chain, fork oil
Don,t bother changing the fork oil unless the forks start playing up, and cam chain Confused auto adjusters on modern bikes it not a old superdream with a manual tensioner.
DynaMight
PostPosted: 09:21 - 06 Oct 2006    Post subject: Reply with quote
Valves need checking every 16k miles on B1H's, so aslong as it hasnt been thrashed to death for the last 20k miles they're probably ok now, so get them checked.
Valves are easier to check than they are to actually adjust. Get some feeler guages and check them yourself and if they need adjusting get a garage to do it Smile
extreme3d
PostPosted: 15:29 - 06 Oct 2006    Post subject: Reply with quote
It's also worth keeping in mind that the major services are the ones people expect to see on the service history come resale time. If it's not done by a dealer then it might not sell so easily.
BigChris
PostPosted: 20:16 - 06 Oct 2006    Post subject: Reply with quote
Dont do it yourself, take it to a proper garage to get sorted out. If you're in the south yorks area i can recommend a place, but unfortunately its a bit make or break on our bikes.
BigChris
tatters wrote:
BigChris wrote:
cam chain, fork oil
say that for my zx12r you punk Razz
BigChris
PostPosted: 20:17 - 06 Oct 2006    Post subject: Reply with quote
Incidentally, I can get you the entire service for half that Very Happy
Mr.Everready
PostPosted: 12:26 - 07 Oct 2006    Post subject: Reply with quote
Download the manual, it has the figures you need if your doing it yourself.
https://www.gofastvideo.com/gallery/item/predownload/486/free-racing/videos/kawasaki-zx6rr-2003-2004-shop-book.html
Right click / save as - where it says click here to play video. Section 2-23/24/25/26
BigChris
PostPosted: 15:18 - 07 Oct 2006    Post subject: Reply with quote
£150 for my full sevice, and they worked on it for nearly 3 days solid.
Very Happy
I'd really really advise against it bro. Really!
Mr.Everready
PostPosted: 17:20 - 07 Oct 2006    Post subject: Reply with quote
Somebody in the accounts department made a huge mistake then.
3 days at 8 hours a day, plus parts = £150 ? I don't think so.
BigChris
PostPosted: 21:38 - 07 Oct 2006    Post subject: Reply with quote
well getting the shims wrong means that you either blow yer valves and knacker yer engine, or you lose compression and it'll go like shit.
As for my service, the costs were agreed at £150 prior, except they fucked up my powercommander fitting and so stripped it down to bare nuts and bolts to find out what was wrong.. Should have only took a day.
The last post was made 20 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.54 - MySQL Queries: 63 - Page Size: 83.01 Kb
