No more exercise EVER! (kind of)
Itchy
PostPosted: 23:38 - 25 Sep 2006    Post subject: No more exercise EVER! (kind of) Reply with quote
After 6 months of daily exercise running 4 miles(really really running) , general work de-stress of attacking my punch bag for about 30 minutes , loose weights , 4 miles on a stationary bike and 2 miles on a rower and various crunches pressups etc every single day for 6 months.
I have noticed ZERO improvement , I'm not stronger , I'm not faster and I still get out of breath easily and weigh more than when I started and get tired at exactly the same points as I do when I
first started all that has happened is I feel a bit worn out before bed, but can't fall asleep easily due to insomnia.My resting heart rate is almost exactly as it was before.The only difference I've noticed is my hands are not a steady as before.
My diet has not changed at all (lots of meat some veg)
Any thoughts on what I'm doing wrong? I don't stop when I get out of breath or anything I just grind on and on , or should I just sit back and forget about it? , because I've tried and nothing has come of it and people who constantly do something for no reward are called fools.
PostPosted: 23:41 - 25 Sep 2006    Post subject: Re: No more exercise EVER! (kind of) Reply with quote
Have you read up on 'proper' methods.
I don't really know an awful lot, but I know stuff like exercising at the right heart rate can make a big difference.
I didn't notice a big difference in going to the gym until the day after a race weekend - wasn't nearly as knackered or achey as I normally would be.
Lost it all now though, gotta sort it out for next year.
anders This post is not being displayed because the poster is banned. Unhide this post / all posts.
killa
Won't Shut Up
PostPosted: 09:13 - 26 Sep 2006    Post subject: Reply with quote
This is worrying....
I've started going to the gym every Tuesday, wednesday, Thursday, swimming on Friday and i've noticed difference in a few weeks.
It isnt a great deal but my arms are more toned, i feel more alive than i did before and i'm sure i've lost a little from my waist.
I can't see how having that routine everyday for 6 months you've achieved nothing. What is your current build?
The punch bag is a brilliant work out, as is the rower and running, are you telling us the whole truth? I don't want to offend you there, just asking....
Wink Thumbs Up
cqueen
PostPosted: 09:19 - 26 Sep 2006    Post subject: Reply with quote
Cut down on your meat intake (unless you are body building?).
craigie b
Citizen Smith
PostPosted: 10:42 - 26 Sep 2006    Post subject: Reply with quote
Itchy, your either lying through your teeth, in respects to stating you have noticed zero difference or (which I suspect to be the case) you are not really pushing as hard as you make out.
For example, how fast is the four miles you run? And when you finish are you fucking wrecked? Do you batter the punch bag solidly till your arms burn and you feel nauseaous? Do you increase the weights on the free weights?
A common myth is if you train dialy you will continue to reap fitness benefits. This is bullshit. A set routine, performed daily will achieve notable results for maybe four weeks. At which point your body adjusts to compensate for the new work load and learns how to optimally use calories. The net result is you see zero results from your effort. However (and bear this in mind) it will maintain your current level of fitness.
To improve on your fitness you need to up the ante every time you find it easier. Increase your running speed, add in sprints, up the rower, increase the weights. Progress comes only comes through two methods.....increasing the intensity of the training or changing the routine regulary so the body doesnot have a chance to adapt. I like a mixture of the two.
killa
Won't Shut Up
PostPosted: 11:26 - 26 Sep 2006    Post subject: Reply with quote
Itchy’s right, also you have to note that you are doing these exercises at your will, you have no set goals.
Like I said, I’ve been going 3 times a week to gym and if I can, swimming as well, I’ve been set a few goals and I can certainly notice the difference. I’m not up for a marathon and I can’t lift huge weights but that’s not my aim.
Doing running and punch bag alone will increase your stamina by a noticeable amount if done correctly.
Cardio work is achieve by running & cycling at a high heart rate, 160-170bpm.
To fat burn you need to keep your heart rate quite low, around 140-155bpm
This depends on your age, I’m 22 so this applies to me.
A good routine to tone and gain stamina is as follows
10 minutes on the treadmill, doing the calorie burn setting.
The 2000 setting on the rower (you’ll know what this is if you use one)
Then do some weights, pec machine, leg machine.
Stomach crunches now your body is in full swing
Then if you can stomach it, a further 10 minutes on cross trainer and/or exercise bike
bazza
PostPosted: 12:40 - 26 Sep 2006    Post subject: Re: No more exercise EVER! (kind of) Reply with quote
Don't worry about the mileage you do, concentrate on the time. F'rinstance, run away from your house for 10 minutes, turn round bang on the 10 minute mark and run back. Vary your route over a week and do the same thing the following week. You 'll be surprised how far past your original 10 min turnround point you get after just one week.
Another thing to try (assuming you're on a road with streetlights) is to change your pace - fast/medium/jog - at every lamppost, then later on at every 2 lampposts.
You definitely need to get yourself out of that rut and start setting yourself targets though... Thumbs Up
Arfdog
PostPosted: 14:28 - 26 Sep 2006    Post subject: Re: No more exercise EVER! (kind of) Reply with quote
lol bazza, every time I see your avatar, I think of my mother in law.
I'm a lover, not a fighter.
bazza
PostPosted: 22:51 - 26 Sep 2006    Post subject: Re: No more exercise EVER! (kind of) Reply with quote
Here, go nuts...
https://www.ochainn.ath.cx/images/allatok_07.jpg
Bigeds
PostPosted: 00:56 - 27 Sep 2006    Post subject: Re: No more exercise EVER! (kind of) Reply with quote
Either this is complete bollox (i know the spelling!!) or are you telling us you were in supreme physical condition before you started? Very Happy
What you state would lead to seeing improvements. Just hope you aren't doing weights every day as this is not good. You will only damage your muscles as you never give them a chance to recover. Only do your weights every other day.
Cannot believe the running and other cv work has not improved your stamina. btw your muscles get in to a routine so when out for a run don't just plod along at the same rate, vary it to give them a proper work out.
(Feb06) Honda CG125 - (Jun06) Suzuki SV650S K1 - (Apr11) Moto Guzzi Griso 1100
Arfdog
PostPosted: 08:53 - 27 Sep 2006    Post subject: Re: No more exercise EVER! (kind of) Reply with quote
Itchy, do you smoke the holy herb by any chance?
If you do, this is probably responsible for your lack of progress. I had the same thing with me, for years.. In some people it seems to totally affect the bodies ability to increase muscle mass, and I also believe it affects your bodies ability to absorb certain goodies in your food. I'm talking about daily toking here, once or twice on a weekend wouldn't do it.
If it's not that, maybe diet. Or try another form of exercise. They say sex is about the best cardiovascular workout you can get.. And if you don't have a partner, send bwfc4eva86 a PM, I've heard it said that he'll shag anything.
fast_tzr
PostPosted: 14:49 - 05 Oct 2006    Post subject: Reply with quote
Sorry to hi-jack here, but this thread has reminded me of something I've wondered for a while, I do weights every day, as in biceps until I can barely even lift the weight, pecks the same, sit-ups the same etc. just generally until I'm totally knackered. This only takes about 15 minutes, 5 to 7 days a week. Is this a shite routine? Should I only do weights around 3 or 4 days a week and do it for longer?
Rob
PostPosted: 22:01 - 05 Oct 2006    Post subject: Reply with quote
Diet is the most important thing. People think they can go to the gym without changing their diet, you really need a radical change to start seeing a difference. If you are eating loads of meat it really wont help to cut down your body fat (unless its lots of fish!).
As was mentioned earlier in the thread, if you want to build muscle mass then load up the carbs and work out until you can't move! But if fitness and a lean fit body are your goals you gotta diet (eat sensibly) and work out together. (Obviously not at the same time!)
Love is 1050cc Smile
octane
PostPosted: 22:50 - 05 Oct 2006    Post subject: Reply with quote
Very.
Training shouldn't go more than an hour, after that (unless you're using special ingredients), your body goes from an anabolic (muscle building) to a catabolic (muscle wasting) state, so traing after an hour is useless and detrimental. Use that hour though, 15 minutes honestly, is lame.
Doing the same routine everyday is crap also, as you're working same muscles day in day out, which fatigues the same muscles, and gives them no chance to build; different muscles different days, and try not to do same muscles more than twice a week.
Opinion differes, but personally I've found, heavy wieghts, low reps build muscle, low wieghts high reps, tones muscle.
killa
Won't Shut Up
PostPosted: 10:46 - 06 Oct 2006    Post subject: Reply with quote
Just wanted to mention, because before i hadn't noticed anything, i've lost weight, toned and feel great.
Or at least a lot better than i did before.
I've been going to the gym 3 times a week, swimming on a Friday, for about a month and a half.
My routine is as follows....
10 minutes on tredmill, do a 3-4 minute warm up jog before going to a decent running pace, not sprinting.
The pec-fly (i think) the one which you use to tone and build triceps and biceps. I do about 40 sets of 10.
Rowing for about 5minutes, hard.
Then onto the ab toner (situps), i do as many sets of 15 as possible for me.
Then back on to pec-fly
Free weights then, i go from about 8-10kg doing vertical lifts (boths arms above head), then progress down to 5 Kg where i do just reps of 10 (just pulls, im not sure of the term).
Finally get down to 2k's and do as much shadow boxing in the mirror as possible (no one is in there usually). That is bloody good.
Finish off with either the cross trainer or the bike, doing 5 or more minutes on a medium level.
Im usually wasted by this time but i was doing nothing near this when i first joined. Feels good!
As for my diet, i've been pretty good, no junk except the weekend Rolling Eyes , not as much beer. More spirits.
I've got a lot of things i make for the week and dinners that are quick, PM me if you want me to give you all of them.
I've been making a fruit salad most Sundays for the week.
Add what you like, we've got, strawberries, melon, pinapple, orange.
Add a big splash of tripcal juice (keeps it from going off for longer).
You'll need Tuperware boxes.
Hope this helps some of you out....
SoulRider
PostPosted: 12:23 - 06 Oct 2006    Post subject: Reply with quote
Do you do this 7 days a week, same thing every day?
You need to rest muscles for them to grow and improve/repair. If you do the same thing everyday your just pumping away mindlessly and are not going to make any gains, if anything you will cause yourself more injuries and gains (know this from personal experiance when i started out).
Try to alternate what you do every day, work out say 4 days out of 7 and make everyday hit different muscles groups, however if your interrested in just the cardio side split up your cardio training into different groups and dont do the same every day.
For example say you work out on mon, tue, thur and fri (what my old workout used to be, did make loads of gains but then stopped as couldnt afford gym and was so packed after work its untrue).
On the monday do a 4 miles run, remembering stretches before and after (need a cool down not good idea just to stop). Then maybe try rowing or another mild excersize (can be cardio). Sit ups, push-ups and pull ups are also a good idea.
Tuesday do X miles on bike with stretches and then another mild excersize for a cool down (could even do a mile jog, or gentle run).
Thursday do the 4 miles run but rather than doing just the same 4 mile run push for a faster time or increase the distance (if you do the run twice a week make every other time a chance to push yourself for the next goal) then again another relativly mild excersize for a cool down. Rembere settings goals is a good way to make gains.
Friday use this to do a new excersize, try swimming its great excersize for all cardio aspects and does amazing things for your body, then when you get home rehydrate yourself and go for the punch bag.
Most important thing is to not drink crap, drink litres of water daily or as much as possible. As you can probably tell i was really into my work out routine and will get myself back into it soon, just gotta join a gym and find the will power to get there at silly o'clock in the morning. Need gym with swimming pool as well Sad expensive
My Bike Pics
SoulRider
PostPosted: 12:35 - 06 Oct 2006    Post subject: Reply with quote
Yes you will cause countless injuries and make no gains what so ever. Break up the different m uscle groups for every day and never lift untill you cant life no more, expecially 5-7 days a week. Do biceps once a week with your chest. try do 3 sets on each muscle group with about 12-15 reps in each set. My monday routine was bench press, incline i believe , 3 sets on 7-12 reps increasing weights each set, then dumbell bench press incline same sets and reps but sitting/lying at about 15-20 degree angle. Then pectoral flys dumbells 3 sets 12-15 reps and i only increased weight on 3rd set. Biceps stand and sitting biceps curls 3 sets 12-15 reps increasing weight each set if possible, last set doesnt really matter if you drop to 7+ reps as your have increased a huge amount of weight for biceps. you can also do hammer curls if you want which help work out the forearm. If you want a forearm work out let me know and ill post my old one up
My Bike Pics
killa
Won't Shut Up
PostPosted: 12:48 - 06 Oct 2006    Post subject: Reply with quote
You replied after my post, so I assume this was aimed at me.
If so, look at the third line down, 3 times a week for me, and swimming on a Friday.
I’m not un-healthy but I’m no athlete either, but I’d say 4 miles run isn’t all that brilliant.
I mean, running is quite damaging anyway, and 4 miles is long way to run if you’re just starting out.
Goals are great to set but not if they are well out of reach.
SoulRider
PostPosted: 14:01 - 06 Oct 2006    Post subject: Reply with quote
sorry wasnt to direct with my post, was aimed at itchy. And i assumed that someone wouldnt set impossible goals, maybe targets that are out of reach to strive for over time, but yes goals should be something you can do, but something that does push you.
I was going with the running and cardio etc as this was what seemed to be itchys main workout routine, shin pslints etc are easy to avoid with decent running trainers, and just generally not over doing it will help minimise the amount of damage
My Bike Pics
Reevo8
PostPosted: 14:08 - 06 Oct 2006    Post subject: Re: No more exercise EVER! (kind of) Reply with quote
Oh of course because i is just the weights that tears muscle fibres. Rolling Eyes
You will find a big difference if you begin training 3 times a week weights and twice CV or vica versa. You are overtraining.
05 ZX10R, (**05 WKR) Very Happy
Clanger
Stirrer
PostPosted: 18:38 - 09 Oct 2006    Post subject: Reply with quote
Change...do a class in body pump or something, works with weights but in a different routine to which your body has got used to.
Louise
PostPosted: 18:44 - 09 Oct 2006    Post subject: Reply with quote
You need to work different parts everyother day.
Other wise, doing the same stuff over and over again is just tireing your body, and you will see NO improvement what so ever.
Protein is good if your wanted to gain muscle mass.
Also, are you just doing set weights at a set level?
I do (ie) 10 reps (of what ever) at 5kg, 10 reps at 15, ten reps at 20. do this. You will get stronger.
Blunet600
PostPosted: 13:42 - 10 Oct 2006    Post subject: Reply with quote
you should do an extreme work out every 3 days, so say on monday, do your excercise etc, then do it again on wednesday, this way the muscles get to time to recover and expand, to when you next excericise it will be alittle tougher but wiht bigger improvement. Also if you weigh more, this could be a good thing, muslce in heavier than fat! so look at it on the plus side.
The last post was made 19 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.41 - MySQL Queries: 16 - Page Size: 144.32 Kb
