Wheel bearing problems
Skunkcap Freddie
PostPosted: 19:23 - 19 Oct 2006    Post subject: Wheel bearing problems Reply with quote
had to replace the wheel bearings just over 3 weeks ago as the others which had about 4k on them, one had seized up, anyway i got new bearings 14quid for 2 ,i got them directly from a bearings place. so i get them fitted bike feels great from then until now. then this morning i was on my way to work going around a bend and noticed that the front was a bit shakey so i took it easy to work on the way home i noticed it again. so i got my bro to have a listen and help me check the bearings in the headstock were fine which they are . thing is i havn't been wheeling or going fast over speed bumps/humps (take your pick) since i got them replaced and havn't done very many miles.
has this happened to anyone else ? i'm a bit fucked off they've gone this quick. any ideas if it could be somthing else causing it ?
Northern Irish Biker? www.nibikers.com
Jebus
PostPosted: 19:44 - 19 Oct 2006    Post subject: Reply with quote
as long as they are well greased and preloaded then they should be fine, anyway this should be in the workshop section really. they wont of gone off that fast and 4k seems low miliage for them as well.
2nd time around Smile CBT: 8/9/11
125 Varadero
Cillit-BANG
PostPosted: 19:52 - 19 Oct 2006    Post subject: Reply with quote
Are you confident that you pressed the new bearings in correctly?
It certainly sounds like something isn't quite right.
irving
PostPosted: 20:10 - 19 Oct 2006    Post subject: Reply with quote
Arrow
Skunkcap Freddie
PostPosted: 20:15 - 19 Oct 2006    Post subject: Reply with quote
thanks folks, the last time the bearings were done . a aprilia dealer did them. and charged me a fortune. i took the bearings out and replaced them the same way i took it apart.
will look into it . and check my work shop manual. many thanks
Skunkcap Freddie
PostPosted: 20:20 - 19 Oct 2006    Post subject: Reply with quote
i packed the wheel full of grease aswell
irving
PostPosted: 20:27 - 19 Oct 2006    Post subject: Reply with quote
Arrow
irving
PostPosted: 20:31 - 19 Oct 2006    Post subject: Reply with quote
Arrow
sickpup
Old Timer
PostPosted: 20:32 - 19 Oct 2006    Post subject: Reply with quote
Jebus wrote:
as long as they are well greased and preloaded then they should be fine.
Preload kills roller bearings, as does any side load.
irving
PostPosted: 20:39 - 19 Oct 2006    Post subject: Reply with quote
Arrow
Jebus
PostPosted: 20:47 - 19 Oct 2006    Post subject: Reply with quote
i guess that preload is the wrong word, i mean they were adjusted correctly, i just go by setting them 2 a certain torque setting is preloading them, at least to some sort of degree.
125 Varadero
PostPosted: 20:48 - 19 Oct 2006    Post subject: Reply with quote
Check the spacer is there. Not unknown for people to forget them in the past.
Also, when you put new bearings in only press on the outer race to avoid damaging the bearings.
Skunkcap Freddie
PostPosted: 20:56 - 19 Oct 2006    Post subject: Reply with quote
i put a fair bit of grease in , but loads came out when the spacer went back in and other bearing on.
will check it when i get the new bearings
irving
PostPosted: 21:04 - 19 Oct 2006    Post subject: Reply with quote
Arrow
PostPosted: 21:20 - 19 Oct 2006    Post subject: Reply with quote
irving wrote:
Kickstart, I think He replaced them last time.
Yes, but he replaced them in the way they came out. Who knows if someone had replaced them and left out the spacer prior to that.
irving
PostPosted: 21:26 - 19 Oct 2006    Post subject: Reply with quote
Arrow
Skunkcap Freddie
PostPosted: 21:30 - 19 Oct 2006    Post subject: Reply with quote
nah. the spacer is there alright. i'll be having a good look at it when i'm changin the bearings.
again folks, many thanks for the help
sickpup
Old Timer
PostPosted: 22:39 - 19 Oct 2006    Post subject: Reply with quote
Not on roller bearings. For example no matter how tight you torque a wheel spindle it will make no difference as the spacer will stop the bearing being preloaded.
The last post was made 19 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 1.19 - MySQL Queries: 16 - Page Size: 101.16 Kb
