Concreteing in a Ground Anchor
Brick_Top
PostPosted: 10:27 - 24 Oct 2006    Post subject: Concreteing in a Ground Anchor Reply with quote
Easy guys,
I've just purchased an "AutoXtreme" ground anchor off eGay.
It has a box section, with a crosspin and a swivel head.
It's got to go in my front garden (mud/shingle).
Can anyone link me to a comprehensive guide on doing this? I don't watch ground force, and I've never done anything like this before.
I'm hoping it's a case of buying some ready mixed concrete, digging a fuck off hole, pouring the concrete into the hole and resting the ground anchor in it until it's set.
Cheers,
Con
PostPosted: 11:50 - 24 Oct 2006    Post subject: Reply with quote
That's exactly it.
Dig hole.
Buy readymix.
Mix with water.
Shovel into hole, add ground anchor to taste.
Make the hole narrow and deep rather than wide and shallow, it will be much harder to pull out. If your ground anchor is 4 inches square dig a 12-inch-square hole. Don't use too much water when you mix it you want it to be able to support itself like a giant elephants turd not slump down like gravy. Don't stuff bricks/rocks down the sides it will be much weaker.
Itchy
PostPosted: 14:39 - 24 Oct 2006    Post subject: Reply with quote
if you are even more lazy you can get a lorry come up to your door with premix and just dig the hole and wheel barrow it infor you about £200 last time but then I was laying a gigantic house foundation.
extreme3d
PostPosted: 19:28 - 24 Oct 2006    Post subject: Reply with quote
You could also use postmix which is the stuff used to secure fence posts. The difference is you don't add any water. Simply pour the dry mixture into the hole, stick in your ground anchor and leave. The mix will draw all the moisture it needs direct from the surrounding soil and will dry rock hard.
mr jamez
PostPosted: 20:05 - 24 Oct 2006    Post subject: Reply with quote
I'd bang some steel rods into the round to give the concrete something to cling to, should make it stronger as well.
puremagic72
PostPosted: 20:43 - 24 Oct 2006    Post subject: Reply with quote
Or you could put cellotape round the anchor? Embarassed
Baz. Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
Cillit-BANG
PostPosted: 22:19 - 24 Oct 2006    Post subject: Reply with quote
As mentioned before, don't go mental with the spade action. There are often utility supplies (water, gas, electricity, phone line sewerage etc) that run underground at the front of your property.
9 times out of 10 your fine, but if you take your time you'll spot anything untoward before it gets serious.
B&Q or Wickes sell the post-fix bags. I would buy 2 of these (£3-4 each) and use as instructed. You usually pour half a bag in, water, wait, add rest of bag, wait. All done in a couple of mins and will be hard overnight, but full strength usually takes a few days.
It will also help if you have a length of 2"x2" to tamper (whack!) the mixture to ensure it has settled all around the anchor properly.
Cillit-BANG
PostPosted: 22:21 - 24 Oct 2006    Post subject: Reply with quote
Double post
muddycoffee
PostPosted: 21:42 - 25 Oct 2006    Post subject: Reply with quote
I have concreted a couple of ground anchors in in the last couple of years.
1) don't dig an enormous hole, as you will need about 7 bags of stuff to fill it, and that is a lot of work.
2) have an old pole and some bricks to hand, then you can hold the anchor through the chain eye, and keep it in the exact perfect position while the concrete goes off.
3) If you find some old metal shelf brackets, scaffolding pole, or dexion shelving to bash deep into the ground radially deep down so your concrete binds them in, then your anchor will be impossible to lever out without a 10 ton crane.
4) have some half house bricks to hand and if you are running out of concrete mix, you can push some in to raise the level of your wet mix. Builders call this using plums!
I used bags of ballast and cement which I mixed with a shovel, about 4 to 1 ballast to cement. But fence post suff should be just as good. Although I would use more than one bag, probably 2 or 3.
Suzuki SV650 naked Blue curvy with Givi Screen and G force can.
thx1138
PostPosted: 11:46 - 26 Oct 2006    Post subject: . Reply with quote
I got various lengths of strong chain, locked them up with old padlocks I didn't require, dropped padlocked ends in a deep hole, and filled with concrete. Tapped a couple of nails into the wooden gate post, and rested the other ends of the chain there whilst the cement dried.
muddycoffee
PostPosted: 12:05 - 26 Oct 2006    Post subject: Re: . Reply with quote
That's a real good idea, but you can get an Oxford terraforce ground anchor for as little as £16 from Ebay.
And they are insurance approved, will cut your insurance costs..
muddycoffee
PostPosted: 12:10 - 26 Oct 2006    Post subject: Re: . Reply with quote
I might be missing the point here, but how do you attach an unbroken chain to your bike?
Or do you attach these old padlocks to the middle of the chain and leave the ends sticking out so they can be padlocked through your wheels or frame ?
Confused
muddycoffee
PostPosted: 12:13 - 26 Oct 2006    Post subject: Reply with quote
You can pay me £150 and I will mix up 2 bags of ballast and cement myself gladly. The materials come to less than a tenner!
200 quid Shocked lawks you must be loaded..
Itchy
PostPosted: 14:02 - 26 Oct 2006    Post subject: Reply with quote
I'm not loaded it was just an awful lot of concrete , I more or less filled in an entire cellar with concrete when I had to er get rid of something,
not that my home has a cellar anymore of course , or ahem ever for that matter... Wink
muddycoffee
PostPosted: 14:08 - 26 Oct 2006    Post subject: Reply with quote
o ahem.. right then the less said about that the better.
you're not related to fred west are you by any chance?
Laughing Thumbs Up
virus
PostPosted: 17:23 - 26 Oct 2006    Post subject: Reply with quote
slightly off topic but is the auto extreme short series sold secure?
im tempted to buy one but unless my insurance will drop then theres not much point me buying one when i could make one that wont cost me £30.
own: 81 xs1100g...
muddycoffee
PostPosted: 17:36 - 26 Oct 2006    Post subject: Reply with quote
I can assure you that the oxford terraforce ones are sold secure, and they are also on the discount list on ebike insurance.
I bought my second one from ebay for just £16
So I now have one installed at my own house as well as my girlfriend's house.
virus
PostPosted: 18:07 - 26 Oct 2006    Post subject: Reply with quote
ok, cheers, ill get one as soon as i can afford it Thumbs Up
own: 81 xs1100g...
Walloper
PostPosted: 23:55 - 29 Oct 2006    Post subject: Reply with quote
Remember to wrap a rag soaked in grease around the anchor.
That way whenever you move house it's just a deft flick of the wrist and hey presto you have your anchor for the new house.
And since you've already fitted one. It will be a piss case to put that in.
Warning:
Be carefull if you're moving to a flat though.
You will need planning permission.
virus
PostPosted: 11:34 - 30 Oct 2006    Post subject: Reply with quote
why make it easier to get out?
that defies the whole point of a gound anchor.. you may aswell tie your bike up with string instead of chains Laughing
own: 81 xs1100g...
Walloper
PostPosted: 13:10 - 30 Oct 2006    Post subject: Reply with quote
Good idea virus.
I know Woolies do some Heavyduty stuff. Laughing
krebsy
PostPosted: 18:25 - 30 Oct 2006    Post subject: Heavy duty Drilling... Reply with quote
After 4 hours of solid drilling with an 850W 110V industrial drill I managed to drill ONE 90mm deep, 16mm wide hole into the poured concrete and stone floor of my Garage.
Here's the hole (and the bolt on the left), the pair of drills (my own 500 W and the big hire drill and the anchor (ready to go in).
It took far too long to drill as the floor seems to be made out of Basalt rather than concrete Smile. Actually it was a poured concrete/crushed brick/sand mix and I ended up having to use one of the 16mm masonry bits as an impromptu chisel. Basicly I shoved it into the hole and smacked it as hard as possible with a steel mallet (thanks be to the kind neighbours Smile ) until sparks flew to break up the REALLY tough stuff I seemed to hit at about 70mm down.
I got the thing in and set it into the hole using the extracted dust and a bit of water as a mortar mix. Ok, it's only in by one of the 4 bolts but it'll be impossible to drill another hole without a motorised chisel and a whopping big drill to tidy the hole up.
To summise, Don't drill into a solid floor when you have the option of pouring concrete instead and setting the anchor in whilst wet. Smile
K.
1280 x 1024.
Walloper
PostPosted: 18:34 - 30 Oct 2006    Post subject: Reply with quote
Did you have that 850 m/c set on Hammer?
It should have went through that like hot pish through packed snow.
Was it a borrowed m/c?
Maybe the percussion mechanism is gubbed.
But what a nice hole you got boy. Laughing
virus
PostPosted: 19:13 - 30 Oct 2006    Post subject: Reply with quote
Good idea virus.
If you want to secure your bike like that then go ahead, Id rather use the 2 chains and steering lock ive got on mine at the moment thanks Rolling Eyes
own: 81 xs1100g...
loply
PostPosted: 20:00 - 30 Oct 2006    Post subject: Reply with quote
Yeah surely a decent 850 watt drill should have made mince meat of a garage floor?
Hell even my shitty £20 B&Q 240v drill gets through engineering brick in a relatively short period.
Yamaha SZR660 Caution to the wind, the throttle pinned!
The last post was made 19 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.36 - MySQL Queries: 16 - Page Size: 139.92 Kb
