'pass' button
which best matches what you think ?
isnt it obvious ? I have always done this
18%
 18%  [ 4 ]
sounds like a bad idea to me
27%
 27%  [ 6 ]
doubt it will make much difference
31%
 31%  [ 7 ]
hadnt thought of that, guess it might be worth doing
22%
 22%  [ 5 ]
Total Votes : 22
colin1
Captain Safety
PostPosted: 21:10 - 01 Nov 2006    Post subject: 'pass' button Reply with quote
if you want to flash your lights, you press a button marked 'pass'
its occurred to me that the reason it might be marked pass is that while overtaking, you can whip on your main beam so that your glare in peoples wing mirrors alerts them to your presence as you pass, and then you release when you pull in.
i normally ride dipped as i think its easier for someone to judge the location of a dipped beam, but am considering doing this when filtering overtaking etc in future
what do you lot think ?
Shaun
Likes 'em bent
PostPosted: 21:12 - 01 Nov 2006    Post subject: Reply with quote
The pass button from what I understand is to be used on motorways, ie your in the fast lane, middle lane is empty and you want the twat in front to move over.
BlackSheep
PostPosted: 21:16 - 01 Nov 2006    Post subject: Reply with quote
I think that when you dazzle somebody and they run you over it will be your own fault .
(im an Artic driver i have photosensitive eyes and am sick of being dazzled during the day , also main beam in daylight makes it harder to judge how far away you are and how fast you are moving)
GSXR 1100 StreetFighter
colin1
Captain Safety
PostPosted: 21:20 - 01 Nov 2006    Post subject: Reply with quote
yeah id agree with that, but im still thinking getting the guy im overtaking notice me might still be good
although if it startles them and makes them veer to the right this may be a problem
PostPosted: 21:21 - 01 Nov 2006    Post subject: Reply with quote
It's for giving headlamp flashes. So for example, if you are moving up to overtake someone, as well as using your indicators, you can give the lights a quick flash to alert them to your presence.
its occurred to me that the reason its marked pass is that while overtaking, you can whip on your main beam so that your glare in peoples wing mirrors alerts them to your presence as you pass, and then you release when you pull in.
Do you have any idea how irritating and distracting that is? If you do that to me, expect to be seeing my full beam in your mirrors until you are out of my sight.
A note on the 'pass' button. It is often wired up differently to the main heradlamp circuit. I have seen several bikes on which the 'pass' button wiring is NOT protected by a fuse and doesn't pass through the lighting relay in the black box. I wouldn't use it for prolonged periods.
colin1
Captain Safety
PostPosted: 21:23 - 01 Nov 2006    Post subject: Reply with quote
ok, so a flash when just about to overtake rather than being held on wd probably do the trick
thanks
GearboxGeezer
PostPosted: 21:25 - 01 Nov 2006    Post subject: Reply with quote
thanks
Thats no fun, You cant scare the shit out of them by doing 100mph passed them.
mikeoldcars
PostPosted: 21:48 - 01 Nov 2006    Post subject: Reply with quote
i thought the P.A.S.S. button stood for
'press and shout something'
for when someone annoys you
st3v3
PostPosted: 23:21 - 01 Nov 2006    Post subject: Reply with quote
i just use it for thanking road-users giving way and letting them go first oh yeah, and to display in frustration at what an incompetent driver they are Laughing
NSR Mick
PostPosted: 23:23 - 01 Nov 2006    Post subject: Reply with quote
thanks
Is that so they think it's safe to pull out on you? Rolling Eyes
PostPosted: 23:30 - 01 Nov 2006    Post subject: Reply with quote
No, it should be done early enough so if they are going to pull out on you, they do it before you are right alongside them. Think of it as a "Here I am approaching at speed, decide what you're going to do." signal.
wilbur
PostPosted: 23:45 - 01 Nov 2006    Post subject: Reply with quote
The highway code quite clearly states (in the UK) that flashing your lights may only be used a a hazard warning AFAIR. The most ignored rule on the roads.
colin1
Captain Safety
PostPosted: 23:50 - 01 Nov 2006    Post subject: Reply with quote
i suspect people go above the speed limit more often to be honest
V2
Exactly, you're a hazard, so warn someone before its too late! Laughing
Groove
PostPosted: 00:21 - 02 Nov 2006    Post subject: Reply with quote
Mines used to say "hello" to a mate passing in the opposite direction (if there in a car)
PostPosted: 00:25 - 02 Nov 2006    Post subject: Reply with quote
No, it is a signal that you are there.
highway code wrote:
90: Flashing headlights. Only flash your headlights to let other road users know that you are there. Do not flash your headlights in an attempt to intimidate other road users.
V2
PostPosted: 00:29 - 02 Nov 2006    Post subject: Reply with quote
Spoilsports!
irving
PostPosted: 00:38 - 02 Nov 2006    Post subject: Reply with quote
Eh?
colin1
Captain Safety
PostPosted: 01:35 - 02 Nov 2006    Post subject: Reply with quote
everyone knows that revving loudly with clutch in is to intimidate other road users
far more effective than a flash
The last post was made 20 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.78 - MySQL Queries: 18 - Page Size: 107.25 Kb
