How often do you lube the chain
kkhalil76
PostPosted: 12:36 - 18 Dec 2006    Post subject: How often do you lube the chain Reply with quote
Just wondering how often a chain should be lubed. In my case it's a Honda XR125L, kept outdoors uncovered, daily commute ~12 miles in total. Cheers.
satans_BIG_helper
PostPosted: 12:47 - 18 Dec 2006    Post subject: Reply with quote
I used to do mine once or twice a week but thats when i was doing over 300 miles a week or i generally looked at the condition of it and made a decision on that.
I would generally do it once a week no matter what tho that way i knew it was lubed and gonna be in good condition, and i used to be really dull and once a month clean it Embarassed
edd
PostPosted: 13:24 - 18 Dec 2006    Post subject: Reply with quote
If im doing daily commuting I'll oil my chain every couple of days with used engine oil from a handheld oil can. Use old engine oil and it costs you no money, still keeps your chain lubed though. Thumbs Up
Bluespark Automotive - Diesel Tuning for Performance and Economy
Finglonga
PostPosted: 16:29 - 18 Dec 2006    Post subject: Reply with quote
You can usually tell by looking at it, if it looks dry then lube it, if it looks like its got a good coating on still don't bother. Wink
Andy Sez....
F.Y.Y.F.F.
FreshAL
Sir Crashalot
PostPosted: 16:38 - 18 Dec 2006    Post subject: Reply with quote
I give it a quick squirt about once a week, and clean it properly when it starts to look a bit manky - normally about 400 miles
kkhalil76
PostPosted: 16:48 - 18 Dec 2006    Post subject: Reply with quote
Thanks
baldy
PostPosted: 17:50 - 18 Dec 2006    Post subject: Reply with quote
I lube the chain on the cbr every time i go out for a long ride, i lube the chain on the er5 occasionally, and i never lube the chain on the xr400, its just not worth it, it just gets covered in muck.
One day i will rule the world, just not today.
kkhalil76
PostPosted: 17:54 - 18 Dec 2006    Post subject: Reply with quote
You never lube it? Why not this one in particular? Doesn't that affect performance?
baldy
PostPosted: 17:57 - 18 Dec 2006    Post subject: Reply with quote
Its because i go offroading every week, and the chain is old and knackered, so i dont care too much. The performance doesnt really change, as soon as you get back on the road, most of the muck flicks out.
kkhalil76
PostPosted: 18:00 - 18 Dec 2006    Post subject: Reply with quote
Got it.
All this lubing seems to be a bit of a hassle (if you're lazy like me and have no garage or any space to fiddle around with the bike). I wish it came with one of those scottoiler thingies.
baldy
PostPosted: 18:11 - 18 Dec 2006    Post subject: Reply with quote
i would'nt worry too much on a 125, the chains and sprockets are cheap enough. just keep it tensioned correctly and it should be okay. If the chain comes off at speed, it could cause some damage. When mine came off on the 125 it smashed a hole through the casing, but abit of superglue and half an hour later, it was good as new.
kkhalil76
PostPosted: 18:20 - 18 Dec 2006    Post subject: Reply with quote
It's not so much the condition of the chain I'm worried about, as I'm planning on selling the bike after maybe 6 months (hoping to do direct access soon), but it seems to run better when well lubed. Not sure if it's just in my mind, but changing gears seems smoother.
baldy
PostPosted: 18:27 - 18 Dec 2006    Post subject: Reply with quote
Mine was the same, but i think the manufacturer made the chain and sprockets out of cheese. After i changed them it was fine, but i sold it shortly after.
irving
PostPosted: 18:37 - 18 Dec 2006    Post subject: Reply with quote
kkhalil76
PostPosted: 18:45 - 18 Dec 2006    Post subject: Reply with quote
Indeedy. That's why I got off my lazy arse yesterday, cleaned it, sprayed it with some anti corrosive protective stuff, cleaned the chain, lubed it, and then stared at it for a while Mr. Green
edd
PostPosted: 22:24 - 18 Dec 2006    Post subject: Reply with quote
Im very lazy, just stick your can of oil/lube on a shelf in your garage, when you pull in stick the bike on the centre stand, leave it in gear, squirt squirt squirt. Chain = lubed. Takes 30 seconds and saves your chain becoming knackered.
Dan 4RR
PostPosted: 22:30 - 18 Dec 2006    Post subject: Reply with quote
Only really lube my chain if I'm going on long journeys, say 100+ in a day. Otherwise I'll just look at it and maybe 'stroke' it with my finger to see if it is still oiley.
Humans....the largest form of cancer the world has ever seen!
Speed Cameras - Putting goverment revenue before public safety!
Kram
PostPosted: 23:07 - 18 Dec 2006    Post subject: Reply with quote
Lube... chain.... Shocked
On my 600, I used to do it every week as i tried to look after it as much as possible. But on my VFR400, I haven't adjusted the chain since i've had it (and it was stood around for a few years, before I had it). I oiled it once, when I got it MOT'd and not had any problems since.
... plus the thick layer of dirt/crap protects it from any road filth Twisted Evil
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
Kram
PostPosted: 23:11 - 18 Dec 2006    Post subject: Reply with quote
MattEMulsion
PostPosted: 23:50 - 18 Dec 2006    Post subject: Reply with quote
I make sure that I lube my R6's chain at least every 500 miles. I keep it in good condition though and generally give it a proper clean every 2nd time it needs lubing. Other than that my bike doesn't see an awful lot of bad weather so it doesn't attract too much s**t. Doing this, my chain in still in good shape after 9500 miles.
Yamaha YZF-R6
veeeffarr
PostPosted: 23:52 - 18 Dec 2006    Post subject: Reply with quote
I've just fitted a loobman to my GS500E and I just top the bottle up with the dregs of various oil bottles I have lying around
The last post was made 19 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 16 - Page Size: 113.94 Kb
