downgearing my k3 gsxr 600
gearing
-1 at front
33%
 33%  [ 1 ]
-2 at front
0%
 0%  [ 0 ]
-1 +1
33%
 33%  [ 1 ]
-1 +2
33%
 33%  [ 1 ]
Total Votes : 3
Keir
PostPosted: 13:57 - 24 Jan 2007    Post subject: downgearing my k3 gsxr 600 Reply with quote
Ive had my gsxr for a year or so now and recently have been looking at moving up to a 750 for that 'little bit extra'. However, i love my bike and cant find a suitable 750 so.... im going to try downgearing.
What should i do? -1 at the front? anyone done this? much difference? How much top end will i loose?
Will it involve new chain etc or just the front sprocket swapped?
Thanks
Current : '08 Yamaha FZ1s
PostPosted: 14:04 - 24 Jan 2007    Post subject: Reply with quote
I'd personally go two down on the front and two up on the back. That way you keep the number of teeth the same and can use the same size chain.
Also, I'd probably just get a new chain and sprockets unless the chain is brand new, because it isn't the best idea to have new sprockets with a worn chain.
If you go one down on the front then you won't notice the difference.
Also you should try to keep the total number of teeth on the sprockets an odd number so that the chain doesn't run the same links over the same teeth each time.
{edit} and you'll hardly notice any loss of top end unless you regularly do trackdays at Snetterton!! Smile {edit}
gixxersixx
PostPosted: 23:51 - 24 Jan 2007    Post subject: Reply with quote
Ive been running my 600 k1 with -2 off the front and +4 on the rear for about a year, ive also changed some of the internal gearing, so mine will be slightly different. straight line accelleration is fantastic, great for sliding the rear out of corners. On yours though that set up will drop your top speed to about 140ish. You will get an increase in fuel consumption nothing too major and your speedo will be out and at legal speeds will be over reading by about 10 mph, but a rough guide is about 10mph per 1000rpm in top eg 5000 rpm = 50 mph, one thing I have found is in the wet weather the rear spins up a lot more, in the dry the front heads skywards. If you dont want to change your bike then go for this. Its worth doing and ask yourself how many times do you redline the bike in the first three gears against how many times you redline in top, you wont miss the top end mph.
We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies
The last post was made 19 years, 74 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 18 - Page Size: 41.95 Kb
