Disc Brake Help.. ^_^
Zepf
PostPosted: 18:24 - 20 Aug 2003    Post subject: Disc Brake Help.. ^_^ Reply with quote
Hey,
My bike fell on it's side, the side with the brake fluid reservoir (thingy) next to the front disc brake. Well, this bolt thing came loose and the brake fluid pissed everywhere.
I pull my front brake and it is loose (obviously)..Am i right in assuming if i just refill the brake fluid it will be fine, or is there more to it than just refilling.. (never had disc brake bike b4!!)
Cheers..
Zepf
TiN
Pocket Tin
PostPosted: 18:29 - 20 Aug 2003    Post subject: Reply with quote
You mean the brake caliper, yeah? The reservior should be mounted on your handle bar.
You've most likely got air in the brake system, which means that it'll need bleeding. Take a peek in the FAQ section for a guide on bleeding your brakes.
TiN
dotgems.net
Zepf
PostPosted: 18:30 - 20 Aug 2003    Post subject: Reply with quote
aye thats what i mean..damn, hope this is easy enough as i aint never worked with disc brakes b4..
Zepf
Zepf
PostPosted: 18:34 - 20 Aug 2003    Post subject: Reply with quote
problem is, there is a tip for bleeding brake lines, but it doesn't actually tell you how to do it.
I just basically need to know how to bleed lines and refill with new brake fluid..
Regards,
Zepf
TiN
Pocket Tin
PostPosted: 18:40 - 20 Aug 2003    Post subject: Reply with quote
Yes, it's your brake lines that need bleeding. "Brakes" covers your caliper(s), reservoir, and line(s). Fluid is pumped from the reservoir through the line(s), and to the caliper(s). If you get air in your brake line they will feel spongy (if you can feel anything at all that is).
TiN
dotgems.net
Zepf
PostPosted: 18:44 - 20 Aug 2003    Post subject: Reply with quote
Is this the FAQ your talking about: https://www.bikechatforums.com/viewtopic.php?t=17818 ??
As it doesn't actually explain how to do it..
Zepf
P.S. Sorry if i sound retarded, disc brakes and all the components are new to me.. ^_^
TiN
Pocket Tin
PostPosted: 18:45 - 20 Aug 2003    Post subject: Reply with quote
This one's better:
https://www.bikechatforums.com/viewtopic.php?t=17099
From point 6 onwards.
TiN
dotgems.net
Zepf
PostPosted: 18:49 - 20 Aug 2003    Post subject: Reply with quote
Ah, i see..do i have to buy some plastic hose so i can see for air coming out??..
TiN
Pocket Tin
PostPosted: 18:51 - 20 Aug 2003    Post subject: Reply with quote
Ideally, although the primary use of the hose isn't for checking if air is coming out, but more to ensure that brake fluid doesn't dribble nicely all over your caliper. Razz
TiN
dotgems.net
Zepf
PostPosted: 18:54 - 20 Aug 2003    Post subject: Reply with quote
It's all good. thanks for your help m8y.. ^_^
TiN
Pocket Tin
PostPosted: 18:55 - 20 Aug 2003    Post subject: Reply with quote
No probs, and good luck!
TiN
dotgems.net
Scooby
Scrappy Doo
PostPosted: 19:11 - 20 Aug 2003    Post subject: Reply with quote
One more thing. Whatever you do don't get any on your wheels Very Happy
A big enough hammer fixes anything!
The last post was made 20 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.94 - MySQL Queries: 17 - Page Size: 72.76 Kb
