Gilera Stalker front wheel off centre
scottishcammy
PostPosted: 16:17 - 21 Feb 2007    Post subject: Gilera Stalker front wheel off centre Reply with quote
Hi folks. I've just an '04 Gilera Stalker, and very happy I am with it too! Anyway, I've just noticed the front wheel seems to be a bit off centre. I'm not mechanically minded but am willing to have a go at most things. I would appreciate if anyone could give me some idiot proof advice how to go about fixing this!
Many thanks in advance,
Cameron.
scottishcammy
PostPosted: 16:18 - 21 Feb 2007    Post subject: Reply with quote
scottishcammy
PostPosted: 16:19 - 21 Feb 2007    Post subject: Reply with quote
nev777
PostPosted: 18:00 - 21 Feb 2007    Post subject: Reply with quote
It's a bit difficult to see if its out of line, as the wheel is not straight ahead in the pics. The only way to really tell is to use a straight edge against both sides of the back wheel, to see the gaps at the front.
Another (less reliable) way is to get up a bit of speed on a level surface (roads tend to be cambered) and let go of the bars. If it veers one way, its out of line.
Basically there is no adjustment. If it's out of line, its probably been crashed or at least kerbed. The only way to cure it is to straighten the frame, which is not easy.
No fear, my arse! If you're not scaring yourself at every corner, you're not riding hard enough!
scottishcammy
PostPosted: 18:11 - 21 Feb 2007    Post subject: Reply with quote
Hi, in the pics' the handlebars are dead straight. The deviation is the amount it is off centre. The main thing I'm worried about is if it's dangerous. Particularly if it is a case of something is lose and at some point I'll turn the handlebars and the wheel won't correspond!
nev777
PostPosted: 16:13 - 22 Feb 2007    Post subject: Reply with quote
Ah, right, gotcha!
Ok, most 'peds only have the bars connected to the forks by a clamp bolt that tightens up the tube on the bottom of the bars. If this is loose (god forbid) or more likely has had a whack, it easily goes out of line. It can't go out of line much more than it has because the bolt sits in a groove in the shaft, and it can't come off in your hands for the same reason.
Remove the front fairing and you will see the clamp. Slacken the bolt, hold the wheel with your knees (or a mates knees) and turn the bars til they line up. Then retighten the bolt and refit the fairing. Simple (but the fairing could take you an hour! Lol)
nev777
PostPosted: 16:16 - 22 Feb 2007    Post subject: Reply with quote
Ah, right, gotcha!
h00dwink
PostPosted: 17:53 - 22 Feb 2007    Post subject: Reply with quote
nevs got it right.
it happened a couple of times on my old gilera. with a bit of a knocking force it'll go back inline (after you've come off this is).
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
baldy
PostPosted: 18:49 - 22 Feb 2007    Post subject: Reply with quote
usually goes like that after the steering lock has been snapped.
One day i will rule the world, just not today.
befdelta7
PostPosted: 00:07 - 23 Feb 2007    Post subject: Reply with quote
or an attempt at snapping it.
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
sunbear
PostPosted: 07:49 - 23 Feb 2007    Post subject: Reply with quote
Just a thought.....are you sure the mudguard isn't wonky and causing an optical illusion ? Thumbs Up
Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT !
scottishcammy
PostPosted: 11:57 - 23 Feb 2007    Post subject: Reply with quote
Hi, thanks for the replies. It's def' not an illusion mate. When the back of the plastic fairing is flush, the wheel is off as per the pictures. You have to turn the handlebars to get it true.
I removed the top fairing and found a long bolt that ran down the fork tube. I removed it but couldn't budge the wheel an inch (and I'm no weekling!). I'll bugger about with it late. Wink
The last post was made 19 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 72.66 Kb
