Cheap Laser / Radar detectors (car, mostly)-reccomendations?
PostPosted: 14:54 - 23 Feb 2007    Post subject: Cheap Laser / Radar detectors (car, mostly)-reccomendations? Reply with quote
I've been meaning to get a Laser/Radar detector for ages, but never quite justified the expense.
Following a link on another forum, I had a look on ebay and noticed that they can be got for reasonable money these days.
Seeing that 14days is just up (I hope) after a seeing a front facing van a bit too late a couple of weeks ok, I've been reminded it would be useful again.
Anybody got any experience with the cheap ones, any reccomendations etc?
If it could fit work with a bike as well, that would be a bonus, but not essential as I'm less bothered with a bike, sd it's harder for them to do you from the front, etc.
flat spot
PostPosted: 16:26 - 23 Feb 2007    Post subject: Reply with quote
Just before you spend your money. They are becoming illegal soon. 3 points and a fine if you get caught. Evil or Very Mad
tribal_tiger
PostPosted: 16:51 - 23 Feb 2007    Post subject: Reply with quote
Get a shark with a Frickin lazzzzer instead then.
Better still, mutant sharks with Frickin Lazzzerrrrrrrrs
https://users.adelphia.net/~33h3q/shark.jpg
How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
m0l0t0v
PostPosted: 18:54 - 23 Feb 2007    Post subject: Reply with quote
My friend has one in his skyline. They're not illegal to have but to use as far as I'm aware. So even if you do use it it's very hard to prove that you have been using it.
I could find out what he has for you G but I think it's an expensive one as he's one lucky bugger.
PostPosted: 19:09 - 23 Feb 2007    Post subject: Reply with quote
Any details on when it's going to be coming in?
The suggestion of this has been going on for ages.
Reading up earlier, in the US it seems they have detectors for radar detectors, then detectors that detect radar detector detectors Confused.
A UK site showed somebody that had got done under 'perverting the course of justice' for having a jammer, however the case was dropped - apparantly he wasn't speeding when they had seen he had a jammer, so presumably technically wasn't actually 'perverting the course of justice' as he wasn't commiting a crime first etc.
beans
PostPosted: 20:42 - 23 Feb 2007    Post subject: Reply with quote
I got the latest version of road angel for xmas and have found it very good. Warns me in plenty of time and the flashing lights and loud beeping always alerts me no matter how much i have the radio turned up. Its saved me countless times as I do alot of miles and dont always know where the cameras are.
I update it every month for free (6months free updates). I have been told the laser detetor can be disabled online incase they are made illegal.
It alerts of all cameras (average speed, gatso,truvelo, mobile, laser etc) currently used and tells you the speed your doing accuratly. Its suprising how far out my car speedo is (02 reg focus), seems to be 5mph untill about 100mph when it gets worse indecated 125 was only 110-115.
They do a bike kit for it which comes with headphones and all neccesary wiring and securing, i havnt bought this yet as i havnt realy done many miles on the bike this year. I will definetly look into this in the summer when im on the bike more often as if i loose my licience i loose my job.
Yamaha FS1E- Suzuki RG 125 - Honda CB-1- Ducati Monster - Kawasaki ZX6-R F1- Kawasaki ZX6-R G1- 2003 Yamaha R6
PostPosted: 21:00 - 23 Feb 2007    Post subject: Reply with quote
I don't really want a GPS based one, cheers for the thoughts anyway.
flat spot
PostPosted: 21:41 - 23 Feb 2007    Post subject: Reply with quote
GPS ones will stay legal. after all, how could the government argue against something that tells you there's an accident blackspot?Throwing the safety argument right back at them Laughing
The jammers and detectors for mobile radar and laser will become illegal.
Here's a link.... https://www.pistonheads.com/speed/default.asp?storyId=9581
Although like everything else it takes ages to come in.
PostPosted: 22:25 - 23 Feb 2007    Post subject: Reply with quote
Note the date on the link - this has been bandied about for a bit, but I haven't seen any dates for any time soon.
I'm specifically looking for something that can get mobile camera vans etc.
Zimbo
PostPosted: 23:47 - 23 Feb 2007    Post subject: Reply with quote
I shouldn't bother, G. I've used the detectors for years and they're pretty variable.
The radar detectors don't work that well, they do pick up gatsos but as the radar output is fairly weak and points away from you (so it measures your speed once you're past it) you often get only a second or two of warning - more if you're following another car as the radar reflects off the rear of the car in front and you pick it up sooner. It also picks up automatic door opener sensors which operate on a similar waveband so is likely to go off as you pass every garage, supermarket etc and drive you mad with false alerts. You'll get no warning of Truvelos or Specs cameras at all. And, as above, they're soon to be made illegal.
Laser detectors are of limited use all round, laser devices lock on and measure your speed in 0.3 seconds so not much time to react. In addition, laser guns target their beam in a very narrow cone, which projects to about 3 feet diameter at 1000 yards, so at 300 yards the cone is just over a foot across and aimed at your numberplate, a device mounted in the windscreen won't even pick up that your speed has been measured a lot of the time. You need a device located in the front grill to work effectively. Again, windscreen mounted ones may pick up laser scatter from the car in front, but obviously this is not a reliable method of avoiding points! The only effective device against lasers is a diffuser, which bounces a light signal back and confuses the speed gun, but they aren't legal for use i the UK.
GPS systems are the only ones to reliably warn of all fixed camera sites, and many will also warn of laser sites too (most camera partnerships operate at only a handfull of specified sites in their region).
Final option - a GPS nav system with camera locations downloaded and set to warn you as you approach. This is the method I use these days and it works well.
PostPosted: 23:54 - 23 Feb 2007    Post subject: Reply with quote
Cheers for the thoughts.
Generally I'm ok with Gatsos etc (said touching some wood!) as I'm generally quite paranoid. It's the sneaky people with guns I'm worried about.
I know there's no warning of specs, but luckily it's generally well signposted at the moment.
I do have a GPS which I need to sort the mapping for - I know you can get POS files listing places.
Having been in a car with someone that had a detector a few years ago, I was quite impressed at how well it worked, may have been an expensive one, though.
DucatiEVO
PostPosted: 01:13 - 24 Feb 2007    Post subject: Reply with quote
As I recall the only 'radar' version I know of that actually worked properly, and didn't go off past every supermarket was one of the high-end Bell models, but it was £500+ Shocked I guess you get what you pay for in this case.
aKa: Ducky
Zimbo
PostPosted: 01:17 - 24 Feb 2007    Post subject: Reply with quote
Correct, that model had a special feature where you could "blank out" certain frequencis (such as the garage doors etc) and as a consequence false alarms were minimised. It was bloody expensive though!
Giffer2
PostPosted: 12:36 - 25 Feb 2007    Post subject: Reply with quote
You won't get one, plain and simple.
A camera van can track and take the image in 0.3 seconds, after your device alerts you (Providing it does as some don't as the beam is too small) then it'll take you around 0.5 of a second to hit the brake pedal and then however long to slow down.
Your best bet is a GPS detector as it'll warn you before you get to the location that there 'could' be a camera van there.
I have 2 systems in my car, a GPS based system with free monthly updates (Cost me £99 for the unit) and a hard wired Laser detection to pick up scatter.
Mar 2007 - Varadero XL125v7, May 2007 - SV650S
17/05/07 - A2 Test Passed
flat spot
PostPosted: 00:09 - 03 Mar 2007    Post subject: Reply with quote
Here you go........... https://www.computeractive.co.uk/computeractive/news/2184190/speed-detection-devices
PostPosted: 00:13 - 03 Mar 2007    Post subject: Reply with quote
Cheers, bad timing as I was just thinking about it again after talking to a boy-racerish person at work who reckons his works well for him.
The last post was made 19 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 93.88 Kb
