| Visitor Q |
 Visitor Q $25 whore
 Posted: 17:49 - 26 Feb 2007 Post subject: How do you know when to clean K+N's ? |
Hey, had a K+N fitted about a year ago (also got it dynojetted) but done very few miles since then.
However its started getting a low range flat spot again, which might mean it just needs cleaning. However like i say, ive not rode in particularly dusty or smoggy conditions often, or done many miles...
But i remember people saying they need a piss load of cleaning. So, anyone care to elucidate on how often theres needed cleaning?
Reason i ask is because ill have to get the stuff in in advance, as K+N site said this;
| Quote: | 20. How do I know when to clean the filter?
The general rule of thumb is that the filter needs to be cleaned when the dirt build up gets as thick as the wire mesh. The usual interval is 30,000 - 50,000 miles depending on driving conditions. We recommend that you check your filter about once a year in normal usage.
21. Can I use anything other than K&N cleaner and oil?
We recommend that you only use K&N oil and cleaner. K&N air filter oil is a compound of mineral oil blended with special polymers to form a very efficient tack barrier. We have performed tests on numerous oil combinations and our blend has the required properties for maximum flow and filtration. Petroleum products such as transmission fluid and motor oil will soften and destroy the rubber sealing edges. Our cleaner is a non-detergent degreaser. Solvents and gasoline will harden the rubber seals causing the filter to distort (shrink). A mild detergent can be used in a pinch, but care should be taken to fully rinse it out. Rinsing detergent out of a filter is similar to getting soap out of a sponge; it’s not that easy to do. Always make sure the filter is completely dry before re-oiling.
And it also reckons i need to get some sealant too...
So, how much of this is micky mouse? Im looking to kickstart/G etc who perhaps know racing/tuning types who can tell whats bullshit. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Visitor Q |
 Visitor Q $25 whore
| Gazdaman |
| EuropeanNC30R... |
 EuropeanNC30R... Gay Hairdresser
 Posted: 21:25 - 26 Feb 2007 Post subject: |
Given you have used it very little I would be tempted to say things have got gummed up with stale evaporating fuel. Lob a bottle of a decent fuel additive for cleaning the system up into the tank and give it a couple of decent runs, and see if the problem persists.
Also, possibly being cold at the moment compared to when it was jetted it will have leaned the mixture off a bit. Bandit was a pain in winter when the engine was cold compared to summer running.
| Visitor Q |
 Visitor Q $25 whore
| Visitor Q |
 Visitor Q $25 whore
 Posted: 22:21 - 26 Feb 2007 Post subject: |
| Kickstart wrote: | Hi
The stuff that has been recommended to me a few times is Forti fuel additive, apparently common in Land Rover dealers.
Keith |
Edit: Tits, auction was for injection engines only.
Hmm, its spelt 'forte' though, for future reference
Ill keep looking about, fleabay etc. As said elsewhere im trying to get 100% ready for when i go home to just walk through the door, get in overalls and start sticking bits on. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| kawakid |
 kawakid World Chat Champion
The last post was made 19 years, 239 days ago. Instead of replying here, would creating a new thread be more useful? |
