| carlmalibu |
 carlmalibu Spanner Monkey
| G |
 G The Voice of Reason
| carlmalibu |
| cokker |
 cokker Spanner Monkey
 Posted: 00:40 - 06 Mar 2007 Post subject: |
If your sitting on it normally, a wheelie.
If you don't shut the throttle off the bike will end up riding you  ____________________ No longer have a bike due to a DVLA/Court royal f**k up. |
| Ariel Badger |
 Ariel Badger Super Spammer
| G |
| Ariel Badger |
| Kal |
 Kal World Chat Champion
 Posted: 07:02 - 06 Mar 2007 Post subject: Re: what will happen if... |
| carlmalibu wrote: | I redline my CB500 33bhp restricted and then let out the clutch, like I used to my 125. Would I shoot away from the lights? go at a faster rate than normal? spin the back wheel? pop a wheelie? fall off? all of the above?
please, englighten me? |
You'll murder an otherwise beautiful bike - if you hate it that much I will ive it a home.
CB500's are more or less indestructable but I think you are pushig your luck there and it wont ne long before the smell of burnt engine oil fills the air!
Even at 33bhp the CB500 is more than powerful enough to get the front off the ground in first. I can also say that the Bike is very heavy if it comes down on you.
If you try to redline it and dump the clutch I believe you will find yourself bouncing off of the rev limiter and with the revs dying off will probably leave you pulling away from the lights slower than you could do.
I am not exactly slow off of the lights. Launch is at around 3,000 rpm change to second between 4 and 6,000. From second onwards then you can change around the 8k mark which is the powerband on the CB500 I am riding.
| carlmalibu wrote: | its only that I have no confidence with this bike
feels like the back end is slipping, it does if I drop to first with back brake on in the wet (VERY WORRYING!) and I worry about taking corners on it. Also not sure what the power delivery is like
Used to hoon my RS around but that was the only way to get around on it. Been too worried about the CB500, just haven't got used to its power delivery (which is surprising considering the bike) | .
CB500.s are pretty linear up to the 8k mark and then they kind of just take off. If you keep your rpm's between 4,000 and 6,000 pms then the power is very tame and useable until you have gotten settled in to how it handles.
If you take care of the CB it will take care of you,and yes they are horrendously under rated as Bikes. ____________________ Kal...
1984 GB250 Clubman,1983 CB250N Superdream, 1999 GPZ500S |
| craigs23 |
 craigs23 Mr Muscle
| G |
| carlmalibu |
| Speedy3 |
 Speedy3 Traffic Copper
| Finglonga |
 Finglonga World Chat Champion
| Kal |
| Zimbo |
 Zimbo World Chat Champion
| Kal |
 Posted: 01:22 - 07 Mar 2007 Post subject: |
Concvincing someone else to try and wreck his bike with summer on it's way is just cruel... ____________________ Kal...
| Zimbo |
 Posted: 08:28 - 07 Mar 2007 Post subject: |
Not at all, you've got me all wrong, I genuinely have no idea what it'll do!
Besides, CB500s crash really well and don't cost much to repair, he'll be fine
If not, Darwinism rules! |
| Arfdog |
 Arfdog Crazy Courier
 Posted: 08:56 - 07 Mar 2007 Post subject: |
2-stroke engines don't provide any effective engine braking, while 4 strokes are very good for engine braking, this is why you are having trouble. Drop a gear and let your clutch out fast at any speed while the engine speed is mismatched, tand there is going to be a quick friction battel between your rear wheel and the ground. If this happens round a corner, in the wet, you'll kiss the tar.
Don't gear down around corners: Going towards corner:slow down, gear down, blip throttle, ease clutch out, then enter bend and accelerate out. You won't slip this way.
Rather than using the brake to brake for corners, use engine braking SMOOTHLY by dropping a gear and EASING the clutch out. Even less chance of skidding, and less brake wear, and by doing so you will automatically be curing your problem of jerky changes, too late in a corner.
I don't take off from a redline on my GS450 from a stop, there really is no point, for a few reasons:
The gearing is so low, that with a bit of an accelerator blip then smooth clutch control and plenty of petrol, you can climb through progressively from lowish revs (2-3K) all the way through to redline within a second or 2. This means 2 things:
1: Your clutch is engaged while you accelerate through to redline, so your clutch does not wear as quickly.
2: your engine is loaded. I don't like to redline in first, because with the low gearing, it would be very similar to redlining in Neutral, which I don't do either. An engine does it hardest high revving work against a load when you are going fast in high gears, and the resultant engine wear biases the engine toward this kind of treatment (if this makes any sense at all). Revving under no load conditions fecks your engine, as there is no load, just pistons flapping about unbiased.
Much the same as your knees when running. Think how fast your legs go at full sprint. This is against a load. Now hang from a branch and try emulate that movement in free air, not good for your knees, is it...
I feel nothing redlining my RXS100 for an hour straight going up to london on the motorway. But, if I redlined it in neutral, I would not make any bets about it lasting more than a minute or three before the engine melts down... ____________________ I'm a lover, not a fighter. |
The last post was made 19 years, 86 days ago. Instead of replying here, would creating a new thread be more useful? |
