Central Heating thermostat - could I use for electric rad?
PostPosted: 14:20 - 13 Mar 2007    Post subject: Central Heating thermostat - could I use for electric rad? Reply with quote
Does anyone know how a central heating thermostat works?
Are they essentially a thermometer with a big relay on the other end?
If so, would it be simple to wire one into control an electric radiator?
lanester
PostPosted: 16:36 - 13 Mar 2007    Post subject: Reply with quote
I believe in their most simple form they are a bi-metallic switch where you adjust the tension before they break the circuit depending on the temperature (correct me if I'm wrong). New thermostats will most probably be electronically controlled by a thermistor or IC with a triac or relay output. although they may still use the mechanical switching method, hth.
2003 - 2006 Honda XR125L, 2006 - 2011 Suzuki DR-Z 400 SM
2011 - 2014 Yamaha FZ6 Fazer S2, 2014 + KTM 690 SMC-R
old bob
PostPosted: 17:46 - 13 Mar 2007    Post subject: Reply with quote
Under no circumstances should you use a central heating thermostat (room stat) to control an electric heater. A roomstat is only designed to switch low current loads an elctric heater wil be at least 2 Kw and will need switching contacts capable of handling at least 10amps, to be safe I would noe use anything less than 15amp switching.
PostPosted: 18:13 - 13 Mar 2007    Post subject: Reply with quote
My electric heater draws around 600-700w on the setting I use it on.
However, point taken, ta.
I wonder if I could wire up a bigger relay to the thermostat Thinking.
cagiva gezzer
PostPosted: 19:32 - 13 Mar 2007    Post subject: Reply with quote
https://www.tlc-direct.co.uk/Products/SMET05.html
"thermostatic plug" into google.
PostPosted: 19:45 - 13 Mar 2007    Post subject: Reply with quote
Cool; just what I was looking for.
Had tried google, but not with 'thermostatic', which seems to have been my downfall.
Ta Thumbs Up.
The last post was made 19 years, 71 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 16 - Page Size: 49.15 Kb
