Aprilia RS125
CraigPeters
PostPosted: 18:18 - 15 Mar 2007    Post subject: Aprilia RS125 Reply with quote
Hi I have an Aprilia RS125 Which is rather Poorly Sick
The Engine is a Rotax 122 Model
I am having loads of problem's with the Compression + Timing of the Engine.
I was Wondering if anybody Knew of a place where I can FREE Download the Haynes Manual for my bike (as I am a skin-flint + Currently on the Dole so can't afford to buy it!!).
And Haynes Manual's are usually Aimed at the general DIY Type Person, therefore, providing more "Down To Earth" Solution's and Advice.
mayfair
PostPosted: 23:24 - 15 Mar 2007    Post subject: Reply with quote
https://www.mmra.org.uk/marci/rs125/index.php
Try this Thumbs Up
CraigPeters
PostPosted: 00:43 - 16 Mar 2007    Post subject: Manual's Reply with quote
Yeah Mate found that one + Some other's so now I have posted the manual's I have been able to find. But that Haynes one is still proving rather tough to get hold of.
Check out the link on my Home Page www.craig-peters.co.uk
Its a zip file of all I have found (so-far!!!) about 21Mb though
Timmeh
PostPosted: 08:32 - 17 Mar 2007    Post subject: Reply with quote
Unfortunately you can't fix compression problems other then rebuilding the top end. Either you have enough compression or you don't. There isn't any point trying to fix anything else until you've got a piston that is actually doing its job.
i_am_tim
PostPosted: 16:46 - 17 Mar 2007    Post subject: Reply with quote
changing the piston rings can help restore compression to where it should be as long as its not too far out, anywhere above 100 ok, but as long as you are above 90 swapping the rings should help
previous bike: 2000 Aprilia rs 125 - SOLD
current bike: 2001 Yamaha R6 - sweeeeet
The last post was made 19 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.98 - MySQL Queries: 16 - Page Size: 45.73 Kb
