Throttle cable sticking!
Feasty
PostPosted: 14:42 - 21 Mar 2007    Post subject: Throttle cable sticking! Reply with quote
Hey All
Quick question, my accelerator cable is a bit stiff and if I twist the throttle handle back it doesn't close back straight away... thinks about it for a bit, slowly closes, then finally goes back to idle position!
I've tried WD40 down the cable from the handle end, didn't make much difference. Have also tried oil in the same way but still doesn't do anything. I've tried following the cable but it disappears under the petrol tank, I 'think' it goes directly into the carb but am not sure and probably wrong Confused . Is there anything else I can do?
Advice please!! Thumbs Up
(P.S Bike is a 2yr old XR125)
virus
PostPosted: 14:53 - 21 Mar 2007    Post subject: Reply with quote
I have the same problem with my CG,
make sure the throttle grip spins smoothly with and without the case that holds it to the bars, and that the carb end runs smooth (try moving the accelerator linkage on the side and seeing if it snaps back) If not then order a new cable and whilst its on the way keep it oiled as much as possible.
own: 81 xs1100g...
Feasty
PostPosted: 15:38 - 21 Mar 2007    Post subject: Reply with quote
So I assume I should be able to see the throttle linkage on the carb? Only I've had a look but couldn't see anything moving when twisting the handle, it couldn't be buried inside the carb could it!? Question
ZaphodBeeble
PostPosted: 15:54 - 21 Mar 2007    Post subject: Reply with quote
Try forcing the throttle closed, if that doesn't work then the problem is either a knackered cable or the throttle slide needs oiling. You can unscrew the top of the carb (about 1 and a half inches wide) where the throttle cable sticks out vertically. Then you should pull the slider out most of the way (about an inch and a half vertically) and lube it up with good old wd40. Thumbs Up
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
Marci
PostPosted: 15:57 - 21 Mar 2007    Post subject: Reply with quote
WD40 evaporates and thus will only pose a short-term solution. Better to use a thin smear of dielectric grease... DowCorning DC4...
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Feasty
PostPosted: 16:14 - 21 Mar 2007    Post subject: Reply with quote
How about standard oil that you use on push bike chains etc, would that be okay?
ZaphodBeeble, I can close the throttle manually straight away, it's just when you rev up and let go of the throttle it doesn't snap back quickly at all.
ZaphodBeeble
PostPosted: 17:22 - 21 Mar 2007    Post subject: Reply with quote
I find that grease is a bit too viscous for the slides. WD seems to work ok.
Take the slide out and inspect it for corrosion or signs of wear. Also, check that the spring inside the slide is not broken.
There is a gap of 287 days between these two posts...
Feasty
PostPosted: 11:45 - 03 Jan 2008    Post subject: Reply with quote
hey all!
Just bringing this old thread back from the dead that I started ages ago!
The accelerator on my bike has been fine after the last episode (see my first post) after oiling the cable regurlarly and checking it.
However it's now started sticking again, only this time oiling the cable and the carb slider makes little difference. The slider and spring are fine, no rust or breaks so I'm assuming I'll need to replace the cable next?
If so, is it easy to replace the carb end of the cable? The handle end I have no problem with, but I'm worried if I take the carb slider out things will go wrong... petrol will spill out, something will fall into the carb etc... any advice on doing this please? Thumbs Up
Also it'd help if anyone could look at the diagram above and tell me what all the numbers point to!
Thanks! Thumbs Up
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
The last post was made 18 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2 - MySQL Queries: 16 - Page Size: 61.58 Kb
