The beauty of the motorway
Bru
PostPosted: 21:25 - 25 Mar 2007    Post subject: The beauty of the motorway Reply with quote
Just thought I'd share my (non) event with you. Spent the day going to Brighton and back (65 miles each way - no biggie) on my NTV. Buzzy old thing - must get it balanced. And how necessary that is was made clear to me when I finally got on to my home slipway off the motorway. Gear selector had no feel to it, so with the bike stuck in top gear, I had to roll to a stop on the roundabout. I discovered that somewhere down the motorway, my gear lever retaining bolt had vibrated right out of its thread! So I must have been buzzing along for miles, with my gear linkage and lever flapping about under the bike. A quick fix, of course, when my mate pitched up with a spanner and replacement M8.
I knew the bolt was not positively locked when I regreased it. And I know that the carbs need to be balanced/looked at. Lesson is: don't take short cuts - do it right first time. Could have been worse.
Nath
PostPosted: 21:37 - 25 Mar 2007    Post subject: Reply with quote
I don't think you should be pointing the finger at out-of-balance carbs causing vibration, as the source of this problem.
Fact is, nuts and bolts have to be done up tight on motorcycles. "was not positively locked" doesn't make a whole load of sense, but if you're saying you didn't actually tighten up the bolt then no wonder it vibrated out!
Hard livin', hard luck.
Ariel Badger
PostPosted: 21:53 - 25 Mar 2007    Post subject: Reply with quote
Does "was not positively locked" mean "finger tight" in English?
JonB
Afraid of Mileage
PostPosted: 22:12 - 25 Mar 2007    Post subject: Reply with quote
What's the obsession with "out of balanced carbs" recently?
It's like they are the cause of the worlds great miseries.
MarkJ
PostPosted: 23:06 - 25 Mar 2007    Post subject: Reply with quote
Did no-one tell you? A bike with unbalanced carbs is 10 times more likely to eat a baby or drown a bag of pupies in a river.
Bru
PostPosted: 23:12 - 25 Mar 2007    Post subject: Reply with quote
Weeeell.. I'm ignorant, to be sure. But that bolt would only tighten up positively (ie. tightens up sharply in the manner of a good nut and bolt combo) if it locked the lever. Looked like an authentic fastener, but acted strangely. There's something to be said for the correct-sized washer, if one was original to the bike it's not there now.. my replacement bolt is satisfyingly longer.
As for carb balancing, OK so it may be a fad, but for me and my still newish/unknown bike, it would be a palliative. If I could only be sure that 'they all do that, sir'.. I have this need to go over most things to convince myself that it isn't just that way becaust the rust/grease/wear made it so.
It was a nice day for it, though.
St0rmer66
PostPosted: 01:16 - 26 Mar 2007    Post subject: Reply with quote
Had my first experience of a motorway today. Nearly changed lane into a 4x4 Rolling Eyes . Can't believe how stupid a move it was now I think back. Had the girlfriend on the back as well so it would have been extra bad if I had hit it! Shocked . Took it a bit easy the rest of the way...
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
mattjs895
PostPosted: 02:07 - 26 Mar 2007    Post subject: Reply with quote
just the othere day i had taken my front wheel not off to get to sort out my speedo cable problem bit got stuck inside so had to loosen bolt to flip it up side down, if you get what i'm saying)
a few days later, looked at my front wheel to basicly see the nut falling off, remember to check things after you have been working on your bike as well
cheers
matt
krebsy
PostPosted: 09:59 - 26 Mar 2007    Post subject: Re: The beauty of the motorway Reply with quote
Reminds me of when I changed the Divvy exhaust. Just taking it out for the first spin and 5 miles from home the gear selector goes solid under my foor when in 5th. Pulled in, stamped on it a few times but no joy. Managed to get the bike rolling and luckilly did not need to stop between breakdown point and home.
Turned out that the rear left footpeg bolt had undone itself and jammed under the selector. 2nd Breakdown guy (1st one who was supposedly a bike expert didn't spot it and said my Gearbox had jammed) popped the bolt out, nutlocked it back into place and got the bike running in 5 mins.
K.
1280 x 1024.
The last post was made 19 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.99 - MySQL Queries: 16 - Page Size: 63.77 Kb
