Baffle
Mr.Everready
PostPosted: 15:00 - 03 Apr 2007    Post subject: Baffle Reply with quote
My new can is rather loud, even on tickover. I've not had a chance to give it a right blast on the road yet but I'm not expecting it to very quiet.
Are these baffles you get any use ? I imagine that it will get used only on a few occasions but maybe better having ? There is a hole just below the exhaust spout so it would be no bother fitting.
https://i6.ebayimg.com/05/i/000/94/df/7345_1_b.JPG
It's to go in my CCC can.
https://www.bikechatforums.com/files/img002_190.jpg
The Tot
PostPosted: 15:03 - 03 Apr 2007    Post subject: Reply with quote
I was tempted to buy those 10 quid baffle kits off ebay to mute the sound of my bike somewhat. I need to drill a hole in mine to fit the baffle. My main concern if it will go all the way in since the muffler exit is angled and not slash cut or straight since the baffle is straight and doesn't follow the cross section of the exhaust.
Never argue with autism
syris
PostPosted: 16:06 - 03 Apr 2007    Post subject: Reply with quote
I had a Scorpion can on my Fazer, it had a similar removable baffle to that.
It cut the noise down a good bit when it was in - but still no where near the noise of the standard can.
It should be fine for MoT's, is the can stamped not for road use?
Mr.Everready
PostPosted: 16:08 - 03 Apr 2007    Post subject: Reply with quote
No it "should" be ok, it's just got the BS number on it. My tester has a GSXR600 and doesn't really bother, even if it does have not for road use on it.
Type_Mo
PostPosted: 16:19 - 03 Apr 2007    Post subject: Reply with quote
ive found that the hole only fits at the top of the cans, unless u got a massive end can.
they do reduce noise a fair bit, and you can cut the end bit to sit flush with the can Thumbs Up
The last post was made 19 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.44 - MySQL Queries: 16 - Page Size: 45.77 Kb
