FZR water pump removel.
theshmoo
Bottomless Pit
PostPosted: 15:05 - 06 May 2007    Post subject: FZR water pump removel. Reply with quote
FZR 750 water pump inpeler removel from shaft. Hows it done ??? NO nut, or cap screw holding it in place. dont want to force it off but cant work out how to remove it. I need to get in to the back off it to get to the netuel light switch.
CBR 1100 blackbird.
nsr_rory
PostPosted: 17:00 - 06 May 2007    Post subject: Reply with quote
there is a way to get them off but when i had mine off the other week on my nsr we had the whole side of the engine case off. i wouldnt reccomend taking it off unless its really necessary. have you looked for a manual for your bike because there could be a specialist tool needed to slip it out.
theshmoo
Bottomless Pit
PostPosted: 17:10 - 06 May 2007    Post subject: Reply with quote
The bike is 18 years old so manuels are hard to come by. The netuarl light switch is leaking oil badly and its behind the casing off the water pump.
CBR 1100 blackbird.
tonyyzf
PostPosted: 17:39 - 06 May 2007    Post subject: Reply with quote
Hey shmoosie, If you can wait a couple of hours, i'll go look at a micro fiche I have for the FZR
Something dark reddish with two wheels and cagiva written on the side
SS50, CB175, CB250N, CB350, CB750K2, DT250, CB750K1, CB750F1, XS1100, CB750F2, FJ1200, FZR1000, YZF1000, GSXR1000, Cagiva Navigator, Triumph Tiger 1050
https://www.cliqueyclanmcc.co.uk/
theshmoo
Bottomless Pit
PostPosted: 18:32 - 06 May 2007    Post subject: Reply with quote
thanks Tony Thumbs Up .
Its pd's bike and its pissing oil from the back of the neutral light switch, I need the inpeller of the pump drive shaft so I can remove the casing to get the screws out the switch.
CBR 1100 blackbird.
Whosthedaddy
PostPosted: 19:10 - 06 May 2007    Post subject: Reply with quote
Just looked in the FZR (600) manual that I have:
Arrow Impeller
Cracks, wear, damage - replace water housing pump assembly
Arrow Oil seal
Wear, damage - replace water pump housing assembly.
From this, I would beleive that the unit has to be changed as a 'whole' rather than the impeller and parts.
'Align the slot on the back of the impeller shaft with the projection on the oil pump shaft' . It should just pull out?
tonyyzf
PostPosted: 19:31 - 06 May 2007    Post subject: Reply with quote
Yeah, just had a look at the parts fiche, the impeller and shaft are all one, in order from the impeller inwards you have the impeller and shaft, mechanical seal, back plate, bearing, circlip and o' ring.
From what I see if all the bolts are out of the pump housings the whole thing 'should' pull out. when replacing make sure the slot on the impeller and projection on the oil pump shaft line up before tightening the bolts.
theshmoo
Bottomless Pit
PostPosted: 20:05 - 06 May 2007    Post subject: Reply with quote
So i should just pull the thing off the bike.
chears guys,
CBR 1100 blackbird.
theshmoo
Bottomless Pit
PostPosted: 20:27 - 07 May 2007    Post subject: Reply with quote
Heres the diagram
https://images.powersportsnetwork.com/fiche/images/Yamaha/1990/Motorcycles/369_waterpump.gif
I need the circilp off to slide the shaft out or do you think if I just pulled it thre bearings would come out to.
CBR 1100 blackbird.
tonyyzf
PostPosted: 21:03 - 07 May 2007    Post subject: Reply with quote
But the back plate should have come off too, no?
theshmoo
Bottomless Pit
PostPosted: 22:16 - 07 May 2007    Post subject: Reply with quote
The back plate is stuck to the shaft and can rotate on a bearing. but I cant get the shaft + back plate off the bike.
CBR 1100 blackbird.
tonyyzf
PostPosted: 22:36 - 07 May 2007    Post subject: Reply with quote
I thought from looking at it that the back plate was held onto the bike with the bolts which go right through the water pump cover, the bearing behind it is in a boss in the back plate which is pushed into the crankcase, so if you wiggled it, it would come out, shaft/back plate complete, its bound to be tight after all this time.
If you pull the impeller/shaft you'll cause the circlip to spring off and land in the bottom of the box.
willi
PostPosted: 00:06 - 08 May 2007    Post subject: Reply with quote
all the impeller housing has to come off. yo cant just remove the impeller.i rebuilt my 1000 waterpump not long ago its the same. if you try pulling the impeller out you will damage somthing and it will cost you more in the long run. its a easy job to remove so wy try and cut corners.?the only thing you may have to replace are a couple of orings. Rolling Eyes
wat goes around comes around.
theshmoo
Bottomless Pit
PostPosted: 06:06 - 08 May 2007    Post subject: Reply with quote
So the hole unit should just pull off.
CBR 1100 blackbird.
tonyyzf
PostPosted: 06:17 - 08 May 2007    Post subject: Reply with quote
yup
The last post was made 19 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 3.47 - MySQL Queries: 16 - Page Size: 92.42 Kb
