Downgear the storm?
Korn
Admin
PostPosted: 12:03 - 19 Sep 2003    Post subject: Downgear the storm? Reply with quote
Right, I really fancy giving this a go. I've worked out that 2 down on the front and 4 up on the back should still leave it doing 140 in 6th but make it an utter nutter's bike in the low gears Twisted Evil
Question is, where can I get a 14t front and 45t rear sprocket for a Firestorm? That sprocketspecialist.com place is over the pond.
Also, I'm thinking the speedo will stop reading correctly (ratio is changing from 2.56:1 to 3.21:1) so what's the best way to sort this? I've heard of those little boxes you can plug into the wiring between the sensor and speedo but how easy are they to set up and does anywhere apart from M&Pisstake sell them? I don't really fancy having to fit a pushbike speedo Confused
3516 Miles, 11 Countries
TiN
Pocket Tin
PostPosted: 12:06 - 19 Sep 2003    Post subject: Reply with quote
Demon Tweeks should be able to supply you with whatever sprockets you need. But check out the Renthal website for a list of available sprocket sizes.
I'm thinking about getting a Yellow box, but you'll need to order from Oz, and they cost around £70. Confused But if you're still interested, give me a shout, and I'll be motivated to put an order in. Smile
TiN
dotgems.net
Demonic69
The Pink Rhino
PostPosted: 12:09 - 19 Sep 2003    Post subject: Reply with quote
I've wondered about this too. Mainly the speedo issue. Does it underread or overread?
Back on a Blade. Just feels so right.
Stew
If it's good enough for top race teams...
PostPosted: 12:10 - 19 Sep 2003    Post subject: Reply with quote
AFAIK if the speedo reads from the front sprocket and the bike is downgeared then the speedo will over read.
"Unlike public school you don't need to have your arse up and your head down to go a long way...."
Demonic69
The Pink Rhino
PostPosted: 12:11 - 19 Sep 2003    Post subject: Reply with quote
So I'm really going slower than it says? Cool Very Happy
Deano
Good luck with trying to keep the front down hehe Very Happy
Dean Stone #777
EMRA 2012 final standings, Formula 600s 3rd, Superstock 600s 3rd.
www.triplesevenracing.co.uk: www.ljmotorcyclerepairs.co.uk www.gettaylored.co.uk BN RaceScience, Now officially run out of money to carry on racing Sad
Demonic69
The Pink Rhino
PostPosted: 12:17 - 19 Sep 2003    Post subject: Reply with quote
How do you figure out the best ratio?
Korn
Admin
PostPosted: 12:19 - 19 Sep 2003    Post subject: Reply with quote
Here's the table I used to work out what sizes I wanted, check out the plan Zim thought up (and yes, they do actually do those sizes) Laughing
Tell me the standard sizes for the blade and the speeds in gear (at redline) and I'll make you a chart. Just pick what you like the sounds of.
Stew
PostPosted: 12:20 - 19 Sep 2003    Post subject: Reply with quote
Who ever got 175mph from a standard storm?? Razz
Scotty
Scooter Boi
PostPosted: 12:28 - 19 Sep 2003    Post subject: Reply with quote
let me get this right, Zim wants his bike to have a top speed of 80mph ish.
Thats slower than an NSR.
(obviously it will get there alot quicker, and probably wheelieing all the way there...)
wont that speed up chain and sprocket wear...
Regards
Scott
Korn
Admin
PostPosted: 12:30 - 19 Sep 2003    Post subject: Reply with quote
Hence why I want to downgear it. I've has just under that on the M3 according to the bike's speedo, but then again mine isn't standard, and it still took a while to get there.
Deano
PostPosted: 12:32 - 19 Sep 2003    Post subject: Reply with quote
Yeah but scotty if zim start to miss the top speed then he will just change the sprockets back. it only takes 10-20 minutes depending on the person.
Also I can Zim flippin his bike if he's not careful I'm sure he won't but bloody helly is that throttle gonna be dangerous
Dean Stone #777
Scotty
Scooter Boi
PostPosted: 12:36 - 19 Sep 2003    Post subject: Reply with quote
Well least he can just leave it in 6th and never change gear.
Regards
Scott
PostPosted: 12:41 - 19 Sep 2003    Post subject: Reply with quote
You'll probably need a new chain if you are making thost changes, as its going to want two extra links.
As Tin said, it's called a Yellow Box and G has one for sale I think
G1_
PostPosted: 12:56 - 19 Sep 2003    Post subject: Reply with quote
Downgearing the bike sounds like a good idea, something I may concider doing to my next bike.
However surely if you downgear it too much you make it unrideable? You would have a slower 0-60 time, for example, as more gear changes are involved.
Korn
Admin
Phoned B&C Express and they had the sprockets I wanted in stock so I ordered. I'll see what happens with the chain when I get them, hopefully it will fit as it's getting towards the stretch limit as it is, if not or if I have to shorten the wheelbase too much I'll have to get a new one.
£49 including delivery for hardened Renthals, should be here Monday or Tuesday. I reckon it will wheelie 1st through 3rd off the throttle, should be fun Twisted Evil
Stew
PostPosted: 14:09 - 19 Sep 2003    Post subject: Reply with quote
And if the chain doesn't fit you could always do it in stages, such as change the front sprocket first. That way you could get used to the change gradually too. Wink
PostPosted: 14:11 - 19 Sep 2003    Post subject: Reply with quote
Wouldn't bother down gearing it much. After all if you go as far as Zim is suggesting then 1st gear will be just about unusable, and if you try wheelying it you are likely to hit the rev limiter before you have a chance to change gear in the lower ratios.And if you are not going to have useable gears then you may as well raise the gearing and then you can just drop a gear to do a wheely.
One other problem. If you lower the gearing you will increase the fuel consumption. A 1 tooth smaller front sprocket on the 1200 Bandit knocked 5mpg off the fuel consumption. Are you actually going to be able to get the Storm from one petrol station to the next if it uses any more fuel?
PostPosted: 14:38 - 19 Sep 2003    Post subject: Reply with quote
I've got a vid of someone parking 12oclock highchairs (sitting on the bars then doing a wheelie to vertical, onto the wheelie bar, then slowing it right down until you stop. The blokey doing them went 20 up on the back, dunno if he bothered with the front.
For anything apart from that (or maybe the same thing two up on the front Smile )... it aint going to help anything much. 6th will probably be similar to what was 1st Confused.
TiN
Pocket Tin
PostPosted: 14:54 - 19 Sep 2003    Post subject: Reply with quote
Yeah, and if you don't recalibrate the speedo, then the Odo will also over-read, thus adding more unused miles on the clock, which affect resale value...people will think that you've fiddled with the clocks 'cos there's no way that someone will be able to afford to rack up a lot of miles on a Storm. Razz
TiN
dotgems.net
kevo
Cop Seeking Missile
PostPosted: 15:07 - 19 Sep 2003    Post subject: Reply with quote
Because of the fuel expenses? Smile
Regards,
Kevo.
Dusty
King of the Rim
PostPosted: 15:24 - 19 Sep 2003    Post subject: Reply with quote
You need to find a balance between keeping the gears useable and getting good exceleration in each gear. If you go too far it may actually slow you down overall due to the fact you'll be changing gear all the time. And yes fuel consumption will go up, because you'll be at higher revs more of the time.
The best option is to buy a load of sprockets so that you can chop and change depending of the road/track being ridden. For motorway miles a downgeared bike(especially a storm Wink ) will cost you more per mile at a given speed.
I have one of those yellow box doobries, they are made by Black Robotics afaik. Never actually got round to fitting/calibrating it though. Confused
Gallery
PostPosted: 15:29 - 19 Sep 2003    Post subject: Reply with quote
Thats funny, I was just going to say "Ask Dusty, he'll clue you in on down gearing!"
Then my rubbish Dell laptop crashed Evil or Very Mad
Haven't gotten around to downgearing the Daytona yet though... I think I might need it for wheelies though... its more difficult to lift the front than my old SV650
Korn
Admin
PostPosted: 15:42 - 19 Sep 2003    Post subject: Reply with quote
I'm doing it for fun more than anything, so as long as it puts a smile on my face then fuel economy can bollocks Twisted Evil
Besides, I may have found a new source of power Wink
Deano
PostPosted: 15:52 - 19 Sep 2003    Post subject: Reply with quote
Silly question but WTF is that?
The last post was made 22 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.59 - MySQL Queries: 16 - Page Size: 136.52 Kb
