| rpg |
 rpg Scooby Slapper
| Jamie S |
 Jamie S World Chat Champion
 Posted: 14:17 - 26 May 2007 Post subject: |
Brake fluid absorbes moisture which then reacts with the alloy of the brake caliper. When you stripped the caliper down did you remove the seals? If you did you would have found a load of crud behind them that is oxidised aluminium. This needs to be carefully removed. I use a small brass-wire brus with soft bristles.
Also a varnish can build-up on the actual rubber seal itself which needs to be carefully scraped-off using a plastic ruler/fingernail etc.
If you clean the seal and the groove behind it you should find the pistons slide in easily. Put some silicone grease on the piston to keep water away from the seals. ____________________ a.k.a 'Geri'
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 14:20 - 26 May 2007 Post subject: |
This is a quite comprehensive
https://www.bikechatforums.com/viewtopic.php?t=63228
The seals as Geri said need to be changed as well. I had big problems with my FZR brakes and was sorted once stripped, cleaned and seals replaced. ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Jamie S |
 Posted: 14:24 - 26 May 2007 Post subject: |
A certain MR "Sickpup" should do you a good deal on the caliper seals.
| Cillit-BANG |
 Cillit-BANG World Chat Champion
The last post was made 19 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
