| halo123. |
 halo123. Renault 5 Driver
 Posted: 09:49 - 25 Jul 2007 Post subject: petrol mix up , solution? ** edited* crankshaft problem |
Hi this is a bit of a stupid question , i mixed up the fuel i was supposed to use on my bike and ran thru a tank and a half of leaded (lrp) petrol instead of unleaded so now there is a knock.
What should i do. do you think if i just flush the tank out and replace with unleaded it will burn the excess carbonization from the leaded or do i have to over haul the head and manually clean the carbon off ( i have checked and the knocking is a possible side effect of using the wrong fuel ) (in other words will the knock go away if i just use normal unleaded petrol?)
Thanks ____________________ Halo123. =Techie/geek and bike rider ,
current bikes owned ,fix me upper gs 500e missing cdi
cbr 250 virgin colours
| sickpup |
 sickpup Old Timer
| halo123. |
 Posted: 11:14 - 25 Jul 2007 Post subject: |
It is the gs500 , well the carbs were not balanced or set properly, etc ,and using leaded petrol has more carbon buildup , which can theoretically cause it to knock.
I had the bike running soundly when i got it, and used it for a week on the lrp , a distance of about two to three hundred km.
I dont know anyway to disgusie a knock , to sell the bike though ,
( having bought it second hand as is , i cant really demand money back as it was running sweetly when i got it . Buying it has also made me very broke, so i would like to try fix most of it myself, as they want to charge me R1000.00 for a service, ( in south africa , and i paid R5000. for it )
But any ideas are welcome
thanks
Angus ____________________ Halo123. =Techie/geek and bike rider ,
cbr 250 virgin colours |
| Spoon261 |
 Spoon261 Trackday Trickster
| Spoon261 |
| halo123. |
 Posted: 11:39 - 25 Jul 2007 Post subject: yeah i will have to try something like this |
Do you think if i had to use the stuff ( wynns carb cleaner ) you get in a little bottle that you add to the fuel it would help
nb i am in southafrica so the vpower is the same price as unleaded
depending on which service station i go to , about 15c diff in the prces so we dont notice so much on bikes etc.
[They do cost 4 to 7p a litre more than unleaded, but are worth trying.
Shell V Power is my favourite.
They are all meant to clean carbon deposits off the engine.
They are designed to be used all the time, so are weak meaning it will take several tank fulls to totally clean out an engine.[/quote] ____________________ Halo123. =Techie/geek and bike rider ,
| halo123. |
 Posted: 11:48 - 25 Jul 2007 Post subject: gas stations in sa |
We have total , bp , and engen , gas stations here.
The only additive that i know of is like the wynns carb cleaner stuff.
so i can use the ulitmate and techron fuels and engen also has something similar to these but i can remember its name.
( in regards to where the knock is , it is as if the bike is missing on every second piston stroke on the left side, so it sounds very similar to the way the old vw beetles used to )
nb i have checked the spark plugs and they seem to be sparking correctly ( but were very dirty ) , but will be changing them for new ones , over the weekend i hope . ____________________ Halo123. =Techie/geek and bike rider ,
| halo123. |
 Posted: 14:03 - 25 Jul 2007 Post subject: |
Looks like i will be stripping the head off of the bike to remove the carbon as techron etc ,
Takes quite a while and i dont want to ride the bike like it is , just in case its not carbon build up, check a few other options before i do though.
if anyone has any other ideas , thoeries please let me know.
| Jackyboy |
 Jackyboy Scooby Slapper
| halo123. |
 Posted: 15:09 - 25 Jul 2007 Post subject: |
redex?
I will see if we have it here . ( is this the same stuff do you think ?
https://www.holts.co.za/products.asp , which one would i use , the petrol additive , remember i am in south africa , so i dont have a halfords . ____________________ Halo123. =Techie/geek and bike rider ,
| stinkwheel |
 Posted: 17:25 - 25 Jul 2007 Post subject: |
I find it HIGHLY unlikely that a GS500 is going to detonate on LRP unless it has a REDICULOUSLY low octane rating, which it doesn't.
You ain't going to get a carbon build-up off it either, it is just normal petrol with either a sulphate or phosphate additive to lubricate the valve seats on vehicles that don't have hardened ones. The only thing it is likely to cause a problem with is a catalytic converter or possibly exhaust gas sensors, neither of which your bike will have.
I think the source of your knocking noise is something else entirely. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| cestrian |
 cestrian World Chat Champion
| ZRX61 |
 ZRX61 Victor Meldrew
| stinkwheel |
| halo123. |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 Posted: 07:14 - 26 Jul 2007 Post subject: |
Hey guys thanks for the input. So is there any way that some one could get the bike to sound healthy and then a week or two later the bike starts sounding like crap. (In other words to sell the bike make it seem okay when there is a problem with the thing)
| stinkwheel |
| halo123. |
 Posted: 11:19 - 26 Jul 2007 Post subject: |
| stinkwheel wrote: | Might also be worth actually fixing whatever the problem is instead of being a total cunt?
No more help from me. |
no bru that hurts , i bought the bike a two weeks a go and want to know whether they could have made it sound healthy ,
i am going to keep the bike for a while , that is why i have it in my bio as a fix er upper ,
i am not going to rip anyone off.( i wanted to know whether i was ripped off?)
i am the oke who has not sold my old bike cause the stand is loose , and its a clone so everything comes off.
and i think there is a difference in the octane rating as you can see here , ( https://www.sapia.org.za/cleanfuel/faq.htm )
by the way i take this as relevant as i am in durban , south africa , which is right by the coast , and if you think i am messing you around have a look at my company(where i work) web address , www.homerentkzn.com and my proper name is angus hale ____________________ Halo123. =Techie/geek and bike rider ,
| ZRX61 |
| ZRX61 |
| stinkwheel |
 Posted: 22:11 - 26 Jul 2007 Post subject: |
| halo123. wrote: |
by the way i take this as relevant as i am in durban , south africa , which is right by the coast , and if you think i am messing you around have a look at my company(where i work) web address , www.homerentkzn.com and my proper name is angus hale |
I appologise then. You can see how it read.
I'd still look elsewhere for the problem though.
First off try localising the position of this 'knock' use a large screwdriver as a sounding rod. Press the handle firmly into your ear and press the end against various parts of the bike. This should let you hear where the noise is coming from (eg. top-end, gearbox, bottom end, clutch etc).
'knocking' from a fuel with too low an octane rating is also known as 'pinking' which perhaps describes the sound better. It's not generally a solid mechanical sound. It also tends to only manifest itself when the engine is under load such as going up a hill or pulling hard, getting gradually worse the more load you apply.
Have a look in your airbox. Suzukis sometimes spit oil into them from the sump breather and partially block the air filter which would cause it to run hellofa rich. Give the filter a clean while you're in there.
Something else worth doing is balancing the carbs. A paralell twin can get very noisy if the carbs are out of balance.
| Quote: | Maybe you'd like to take a look at the pile of lead foulded plugs I have in my garage? |
Be interesting. Why'd you keep them for so long? They lean-burn ones?
All Japanese motorcycles have been designed to run on unleaded fuel since 1978. It started to become commonly available in the UK in the mid 1990's. They still use the same sparkplugs. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| halo123. |
 Posted: 07:32 - 30 Jul 2007 Post subject: update |
As an update to the topic , i changed the spark plugs ( they had the wrong ones in there, checked the timing chain and , set the cams with how the book says , started it and the noise is still there.
So i thought i would take it out for a spin and see is it changes in pitch or anything.
Forgot that i had no power and went and dropped the thing and broke the clutch lever
So i have come to realise that i will be doing a lot more work on it than i thought as the knocking appears to be lower down than i thought.
( i felt like a retard having to push bump start and ride home in second ) ____________________ Halo123. =Techie/geek and bike rider ,
| bish777 |
 bish777 World Chat Champion
| halo123. |
 Posted: 09:50 - 30 Jul 2007 Post subject: |
I have already taken the carbs off and checked the timing ,
but to no avail. I will send it for the carbs to be balanced etc when i get some more money. but will probably do a complete overhaul in the interim.
The noise seemed to have started when i stalled it in 4th gear , cause someone never looked at the stop street and pulled halfway across. ____________________ Halo123. =Techie/geek and bike rider ,
| ZRX61 |
| stinkwheel |
The last post was made 19 years, 82 days ago. Instead of replying here, would creating a new thread be more useful? |
