What's going on?
Adam80UK
PostPosted: 06:48 - 14 Aug 2007    Post subject: What's going on? Reply with quote
Odd occurence today...
While out and about on my '95 CBR600F as I pulled up to stop somewhere my bike just totally died on me. Absolutely nothing happened on pressing the start button. After trying again a short while later I could hear a kind of electrical ticking when pressing it, as if the battery was too dead. Bike had to be jump started. I let it run then tried starting again, same, jumped again. The rode home and now seems to start fine.
I have never had any kinds of problems with the bike before, and I use it all year round. Never been any electrical problems. What could cause these symptoms, for the bike just to die on me?
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
Rit
PostPosted: 10:10 - 14 Aug 2007    Post subject: Reply with quote
If a jumpstart worked fine theres a good chance that the battery could be stuffed so will need replacing. A good battery will read over 12v so charge it up, put your meter on it and see what it reads then start the bike. It should read higher 14-15v.
You can use your meter again later and see if the battery has dropped below 12v which would mean a shot battery or something draining it?
Point to mention is that I had what I thought was a good battery on my bike but the "oooomph" wasnt there to start the bike (same symptoms as yours, clicking) A new one sorted it Thumbs Up
Also check all your big connections from batt through to starter motor.
You watching this rubbish?
Naaaa, switch over, Neighbours is on in a minute!
www.ritzbitz.co.uk
Dazbo666
PostPosted: 10:45 - 14 Aug 2007    Post subject: Reply with quote
As Rit mentioned it could be a phunked battery, or a dodgy connection.
another cause could be the regulator/rectifier which would mean your battery being constantly drained.
If you put a voltmeter or multimeter on your battery and the voltage doesn't increase when you rev the engine, it could be your reg/rec thats knackered
Word of the day : DILLIGAF
Mudskipper
PostPosted: 11:17 - 14 Aug 2007    Post subject: Reply with quote
Honda = I'd put money on the reg/rec.
Adam80UK
PostPosted: 15:02 - 14 Aug 2007    Post subject: Reply with quote
Cheers, I shall check out the reg/rec first then.
The last post was made 18 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.29 - MySQL Queries: 16 - Page Size: 47.53 Kb
