| m0l0t0v |
 m0l0t0v World Chat Champion
 Posted: 15:34 - 29 Aug 2007 Post subject: Put Diesel in by mistake |
Bollocks.
Well yesterday I put in 6 litres of Diesel by mistake and then after noticing I cursed loudly. Then I filled up the rest of the tank which was about 6 litres with unleaded. I could run the bike but pretty much over 6k revs or it would cut out.
Got to my friend house and we thought about trying to syphon out the peetrol ad then go get some unleaded but it was kidna hard to take the petropl out. We were able to get about 6 or so litres and fill it up with more unleaded. Had to stay over at his house as the bike wouldn't start and it's still not starting.
Any suggestions on what to do save for taking it to a garage and paying lots of money which I don't have? And obviously not filling it up with diesel
Thanks  ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
**\Tarmacsurfer/** said: It's that immaculately manly coiffure of yours isn't it. One glimpse of your virile locks and the punters can't wait to buy whatever it is you suggest, as it might let them be just a little bit like the Adonis that is our very own Molly Doovydoo said: Its not my fault I can't get it up properly, I just wasn't blessed  |
| deanoet |
 deanoet World Chat Champion
| veeeffarr |
 veeeffarr Super Spammer
| gadfium |
 gadfium Trackday Trickster
 Posted: 16:08 - 29 Aug 2007 Post subject: |
siphon/drain the tank completely dry, then fill with fresh petrol. Drain the carb float bowls as well (they normally have little screw at the bottom of the bowl. Change the plugs.
If that doesn't work, then it is probably the garage (and a bill )
I agree with the above...you shouldn't have started it knowing there was diesel in it. You should have siphoned the tank there and then (or called the AA/RAC) ____________________ Those who risk nothing, do nothing, achieve nothing, become nothing. |
| andrew |
 andrew Mister Road Rage
 Posted: 16:15 - 29 Aug 2007 Post subject: |
Muppet! You should have drained the tank at the garage. It would have been an easy job and would have saved you a massive pain in the arse! Could easily have got the fuel hose off and brought yourself a plastic jerry can to pour it out into....
Like has already been suggested. Drain the tank and the carb floats... If it still aint starting take it to your local bike shop.
Diesel is black and Petrol green for a reason!  |
| veeeffarr |
| gadfium |
| stinkwheel |
 Posted: 16:57 - 29 Aug 2007 Post subject: |
I doubt it will have done any damage at all to be honest. If it is a fuel injected bike, it could have screwed up some of the sensors and made the ECU have a hissy fit.
Assuming it is a normally aspirated bike (with carburettors), as has been said, empty the tank then refill it with fresh petrol. Now open the drain screws at the bottom of the carbs to empty the float bowls.
It would be worth running some fresh fuel through the carbs too. If there is a 'pri' position on the fuel tap, turn it to this and open the carb drains again, this will let fresh fuel run through the float bowls. If there is no 'pri' position, you're left with sucking on the carb vacuum hose to get fuel to run out of the tank into the carbs.
Because you've run it on diesel/petrol mix, your sparkplugs will be covered in soot and carbon deposits, as will the inside of your exhaust system. You'll need to take the plugs out and either clean them or replace them.
When it runs, expect a load of smelly blue smoke and a lack of power until it 'clears itself out'. You may need to check/clean the plugs again a couple of times until all the residue is gone.
It may be worth doing an oil change after covering a few miles depending on the amount of soot contamination in the engine. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| m0l0t0v |
 Posted: 17:28 - 29 Aug 2007 Post subject: |
| lllN30lll |
 lllN30lll World Chat Champion
| m0l0t0v |
 Posted: 17:36 - 29 Aug 2007 Post subject: |
I did ask but the guy didn't even know what syphon out meant. And I asked if they had something to take out petrol that's mistakenly been put in. He just said put more unleaded in and have it to at least 25:75 diesel to petrol ratio. Apart from taht he wasn't any helpful at all.
He did tell me to put in at least 14 litres of unleaded and then I told him I'd be har dpushed to put in 14 litres from a completely dry tank  ____________________ '99 Hornet 600 , VFR 400 NC30 '92 , Kasawamasaki GT 550 , '98 Hornet 600
| fazza59 |
 fazza59 Scooby Slapper
 Posted: 18:06 - 29 Aug 2007 Post subject: |
If it was not a bike and a Range Rover just starting it would have set you back £3k min. New ECU's as well as hours for draining. Dont ask!!!
Was the diesel and the super unleaded Blue??? ____________________ Current - Yamaha R1 - Yamaha XJ600N - Kawasaki GPZ 500S (project? Maybe )
Pics of my bikes |
| timjim |
 timjim Trackday Trickster
 Posted: 18:34 - 29 Aug 2007 Post subject: wrong fuel |
i see this all the time as a mechanic so youre not the only one..only thing to say is be more careful in future.As mentioned,drain the tank and carbs,either change the plugs or clean the old ones off thoroughly.Run the bike at first at low revs and leave running at tick over till warm.Make sure the tank is FULL of clean fuel.Allow the bike to cool a little and redrain the carb bowls again... do this as many times as you like..youll probably experience the fuel looking like a dull white gel liquid.Youre lucky the you put diesel in petrol and not petrol in diesel as this IS an expensive mistake..new diesel fuel pumps can cost up to 2 and a half grand jsut for the pump...dont do it again  |
| Kickstart |
 Kickstart The Oracle
 Posted: 19:41 - 29 Aug 2007 Post subject: |
Petrol in a modern common rail diesel is a very bad idea, small amount in an older diesel you would get away with (indeed, used to be recommended as a way to stop diesel turning waxy in cold weather). Biggest problem is that diesel fuel lubricates the system itself, petrol doesn't.
However diesel in a petrol engine should not cause any great issues.
On an injected engine the injectors might get a bit clogged up. Fuel filter and pump might have a hard time. Would probably wreck the lambda probe and / or cat if you ran it for any length of time
Carbed engine there are far less likely to be any issues. Drain the tank and carbs, change the plugs and you will probably be OK.
| bish777 |
 bish777 World Chat Champion
| Walloper |
 Walloper Super Spammer
| stinkwheel |
 Posted: 20:54 - 29 Aug 2007 Post subject: |
Mind you, a mate of mine runs a 2-stroke bike on petrol with diesel in and an old for escort diesel on diesel with petrol in. He gets it all free from the garage next door who drain gallons of the stuff out of peoples cars when they make exactly the same mistake at the garage.
They're both laughing all the way to the bank. My mate gets free fuel and the garage owner has charged to dispose of the stuff then has it taken off his hands for nothing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Walloper |
| timjim |
 Posted: 21:48 - 29 Aug 2007 Post subject: wrong fuel |
i agree with you in principal Walloper and would laugh my c### off if and when things go wrong.As a workshop,the garage i work at has to charge the customer for waste disposal for the fuel we drain..we have to pay for a waste disposal licence so as a tanker can come in and take it away safely,its all to do with enviroment care.The garage mentioned is cutting out the middle man and making a bit of a saving.
Having run by bike on contaminated fuel from a jerrycan in the past,i learnt my lesson and am more than careful now where i get my fuel.tim  |
| thegubner |
 thegubner World Chat Champion
| Walloper |
| konsoli |
 konsoli Traffic Copper
The last post was made 18 years, 226 days ago. Instead of replying here, would creating a new thread be more useful? |
