CB125TDC SUPERDREAM (update)
mrlee1974
PostPosted: 20:57 - 16 Sep 2007    Post subject: CB125TDC SUPERDREAM (update) Reply with quote
Hi all,i'm a newbie here.I recently aquired a cb125tdc,i was wondering if anyone knew anything about these engine's.it has a motad exhaust fitted (2 into 1) and i was wandering if i would need to up the jet sizes in the carb's.As far as i know the carb's have not been touched and the jet size's are either 68 or 89? i cant tell which way round i should be reading them.The top speed is only 65mph and i know my nextdoor neighbour used to get over 80 on his standard engine!
if anyone as any information as to which jet size's i should try or any other tuning info,it would be greatly received.
Thank's in advance!
PostPosted: 21:14 - 16 Sep 2007    Post subject: Reply with quote
CB125TDC won't manage a true 80 (older CB125T might).
Those Motad exhausts are meant to be a direct replacement with no rejetting needed. Possible you might get marginally better results playing with the jetting but don't expect any major improvement.
hmmmnz
PostPosted: 21:17 - 16 Sep 2007    Post subject: Reply with quote
65 isnt too bad at all out of a engine of that age, i dont get much more out of my 250.
you don't need to change your jets for a new exhaust on a 4 stroke,
keep the jets the same,
if i was to do any thing, i would check the tappet clearances, balance the carbs, give the carbs a good clean out, and make sure the diaphragms in the top of the carbs are still in good condition and arn't ripped,
change the plugs, and do a engine flush and oil change, the filter is a little peice of mesh behind the right hand case (as you are sitting on the bike) give that a clean out as no one ever does and are normally clogged.
and she should be as good as new again,
remember to do the tappet clearances quite regularly as they tend to become out of spec quite quickly Thumbs Up
good luck Thumbs Up
the humans are dead
I kick arse for the lord
PostPosted: 21:22 - 16 Sep 2007    Post subject: Reply with quote
Not true, although they are less prone to dramatic and expensive failure than 2 strokes if you get the jetting wrong.
biker_king
PostPosted: 21:31 - 16 Sep 2007    Post subject: Reply with quote
what is the milage? take a look at your spark plugs to check the fuel mixture , the model after 1982 are restricted due to laws ect so 65mph would bo ok fore this model ,
keep the oil toped up and keep regular checks on the level.
good luck, james.
mrlee1974
The bike is in great condition,just want's the carb's balancing up.right side spark plug is clean as a whistle,but left is all sooty.if i was to turn the screw for mixture setting,which way should i try turning it till it's about right,in or out?
And thank's for replies so far guy's
biker_king
PostPosted: 21:36 - 16 Sep 2007    Post subject: Reply with quote
is the plug black and wet? this would be oil burning in the cylinder.
if its mat black this would be a rich fuel mixture, turn the air scrow out to lean the mixture.
mrlee1974
good luck, james.
The bike as done 26k,the engine does'nt smoke at all and thats with the oil topped up.it belonged to an old boy who looked after it well.plenty of regular service history.
mrlee1974
PostPosted: 21:38 - 16 Sep 2007    Post subject: Reply with quote
The plug is matt black,thank's for that tip,i'll try it in the morning
hmmmnz
PostPosted: 21:45 - 16 Sep 2007    Post subject: Reply with quote
sorry i should have said for his particular exhaust.
your a stickler for details mr kickstart Very Happy
the humans are dead
PostPosted: 21:55 - 16 Sep 2007    Post subject: Reply with quote
Sorry, just have visions of people putting full race systems on their bike then thrashing down a German autobahn flat out, then being surprised that they have a piston looking like a polo mint, or with bits of it smeared up the barrel.
PostPosted: 00:50 - 17 Sep 2007    Post subject: Reply with quote
Good luck balancing it, I never sucessfully managed, they are an utter bastard to balance.
In the end I used to just settle for doing it by 'eyeball' so the slides hit bottom at the same time. The adjuster screws are so tricky to reach, you can't really get at them properly with the carb in place.
Oh, and before you go looking for diaphragms, there aren't any. It has slide carbs.
65mph is about right. The earlier models would do 80mph but they had bigger valves and a steeper cam profile.
As hmmmnz says, keep an eye on the tappets, they have a stupidly small clearance as standard and can close up leading to scorching of the exhaust valve seat.
Oh, the camchain tensioner. Supposedly 'self adjusting', don't believe it for a second. To adjust the CCT, take the rocker cover off, loosen the CCT nut (back of the engine between the carbs), press down hard on the top of the tensioner blade with an old screwdriver and re-tighten the nut as you press down. It's usually a loose camchain that kills those engines, you should be able to hear the camchain whirring as the engine ticks over, not rattling. Keep an ear out for a "death rattle", if it starts, readjust it again (five minute job).
bladerunner
PostPosted: 01:24 - 17 Sep 2007    Post subject: Reply with quote
If it's been used by an old fella that was mechanicly sympathetic maybe a damd good thrashing for a while may help as well. You might find if the oil level is closer to the lower/mid range then you get a bit more rev than if it's filled to the brim as well.
Oh and if it has comstar wheels..check the rivets as these wheels are prone to poping them!!!
mrlee1974
PostPosted: 04:21 - 19 Sep 2007    Post subject: Reply with quote
Had a go at the mixture settings myself and i dont think i done a bad job,i turned the screw out a fraction till the plug matched the plug in the other cylinder.i think ive upset things a little taking the carb slides out to re-route the throttle cable.I got a huge cloud of blue smoke upon start up and it ran as rough as ya like with rev's stuck at 4k and didnt have the power to pull off.after running it for a while the smoke got less and less.i thought i might have put the slides back in the wrong carb's so i changed them over and there was not really much differance.although it's smoking more than normal,the plugs are dry? could this be a knackerd spark plug? it ran fine after i balanced carb's but everything changed when i removed the slides out the carb's to route the cable!
what do you think?
PostPosted: 06:25 - 19 Sep 2007    Post subject: Reply with quote
First thing to do when buying one of those engines is to check the top-end. They are prone to wearing away the cams & followers. If they are in good fettle then put new good oil in and don't neglect the oil changes.
PostPosted: 10:44 - 19 Sep 2007    Post subject: Reply with quote
You do realise that the mixture screw only has any effect when using negligable throttle.
PostPosted: 12:28 - 19 Sep 2007    Post subject: Reply with quote
Uncontrolled revving up is a symptom of an inlet manifold air leak. A distinct possability if you've taken the carbs off.
The throttle needles sometimes come adrift inside the throttle bodies too. You've got to drop them in absolutely straight up and down, if they catch, they can be pushed back up into the throttle body.
The last post was made 16 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.77 - MySQL Queries: 16 - Page Size: 105.83 Kb
