Need help fitting stebel nautilus compact.!?
jackw72
PostPosted: 13:35 - 20 Sep 2007    Post subject: Need help fitting stebel nautilus compact.!? Reply with quote
Hi guys and gals,
As per the title i have recently purchased a stebel nautilus compact.
Now ive fitted a replacement horn before which is obviously a lot easier this one has foxed me a bit.
The relay has 4 sticky out metal bits. (or SOMB's for short)
and the horn has two itself ive figured two from the horn need to connect to two on the relay, but im still not sure what SOMB from the battery goes onto which SOMB on the horn and how im going to connect the relay to the horn...
Helpppppp meee please =]
08/11/2007 A2 Passed.
Suzuki GSXR 1000 K3
Rapid Training passed
tatters
Exxon Valdez
PostPosted: 13:41 - 20 Sep 2007    Post subject: Reply with quote
There should be a small diagram on the side of the relay stating which pin is which.
https://www.railway-technical.com/relay.gif
The power circuit would be the 12v positive supply to the horn and the supply to the coil would be the existing positive and earth to the current horn.
Finglonga
PostPosted: 15:38 - 20 Sep 2007    Post subject: Reply with quote
That is a horrible diagram above, so confusing. Shocked
https://www.lunghd.com/Tech_Articles/Electrical/RelayBasics/relay_diagram.JPG
86a - From the horn lead to switch the relay.
87b - from the + of the battery (make sure its fused!).
85 - To earth, just to a screw that goes into the frame somewhere.
30h - To the horn as the above pic it to wire lights up. then the other terminal of the horn goes to earth, use the same as 85 if you want.
Like so . . .
https://www.lunghd.com/Tech_Articles/Electrical/RelayBasics/simplerelaycircuit.JPG
Andy Sez....
F.Y.Y.F.F.
The last post was made 19 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 16 - Page Size: 38.66 Kb
