honda ns125r-advice?
stirlinggaz
PostPosted: 21:35 - 30 Sep 2007    Post subject: honda ns125r-advice? Reply with quote
hi all,
just bought a honda ns125r off a guy on forum(cheers mate)
im gonna be using this daily while my aprilia rs125 is being re-sprayed.(im gonna attempt this myself, so any advice?,i have a compressor & gun but never used it)
but i know nothing about this bike!
but it rides ok!
anyway it would make sense if i knew a few basics!
like, i see a radiator but where do i put the coolant?
how do i lift the seat?
what pressure should the tyres be?
i can see where the 2-sroke goes & i know how to tighten chain etc,
but any advice would be gratefully recieved!
GAZ
ncrn
PostPosted: 21:59 - 30 Sep 2007    Post subject: Reply with quote
Ok seat, you have a key hole on the left hand side to the rear of the bike. Put the key in and turn it round as far as you can. A little lever will descend behind the key, pull this down and pull the seat up. The seat will come off.
Tyres are 29psi on the front and 33psi on the rear, 36 with a passenger, I find it easier to ride with 34-35 psi normally mind.
Coolant, take the seat off, and undo the tank bolt (look at the front right of the bike where the tank meets the steering, there will be an allen key bolt). Lift the tank and there is a cap that says never open when hot on it, coolant goes in there, and the tank to the left of it marked coolant. 2 stroke oil goes in the tank to the right of this.
Hope this helps ^^.
stirlinggaz
PostPosted: 22:15 - 30 Sep 2007    Post subject: Reply with quote
thanks mate,
cant see key hole for key,
will have a look in daylite.
2-stroke goes in next to top yoke, rite?
only need to lift seat for coolant?
cheers,
GAZ
stirlinggaz
PostPosted: 22:49 - 30 Sep 2007    Post subject: Reply with quote
nope,
definately cant see a key hole at side of bike.
curiosity got the better of me, so went out,put the outside lite on,
but definately cant see how to get seat up.
can see the 2-stroke oil tank on right side of bike.
will see if its under tank in morn.
then try & figure out how to lift seat!
GAZ
Handsome
PostPosted: 23:04 - 30 Sep 2007    Post subject: Reply with quote
Left hand side of the seat right near the back under the seat fairing there's a metal loop ( Helmet lock ) then you should see a lock, put key in there and turn then pull the thumb lever down and the rear of the seat up...
CaPo
PostPosted: 23:27 - 30 Sep 2007    Post subject: Reply with quote
Its not an NSR Wink There is no key for the seat. The way to remove it is by undoing the allen bolts at each side iirc.
Tyre pressures: 25 front, 32 rear.
For the coolant, remove the panel at the right hand side I think (similar to the one I gave you loose, but opposite side.) and I think the coolant bottle is there, next to the battery.
stirlinggaz
PostPosted: 11:24 - 01 Oct 2007    Post subject: Reply with quote
thanks mate,
should have asked you in first place, eh?
those guys were confusing me (easliy done!)
i take it you mean the bolts holding down the strap, across seat?
cos i took them out but was unsure wot to do next, didnt want to force it!
but, anyway dont need to remove it,if theres nothing important under there!
i will have a look for coolant bottle later, as its getting cold in mornings, will prob. need to put some anti-freeze in?
thanks again for info,
cheers,
GAZ
CaPo
PostPosted: 12:02 - 01 Oct 2007    Post subject: Reply with quote
Yeah, 2 bolts, one at each side of the strap. If its still not coming off then maybe theres bolts under the back of it I forgot about? The white cover above the tail light pops off, check under there.
When I got the bike the coolant was all flushed out and renewed, so there should be plenty of anti freeze in it, just check the levels ok. Wink
Handsome
PostPosted: 20:41 - 01 Oct 2007    Post subject: Reply with quote
Sorry, I read it as NSR not NS... Doh!
ncrn
PostPosted: 21:13 - 01 Oct 2007    Post subject: Reply with quote
Yeh I did the same.
stirlinggaz
PostPosted: 18:28 - 02 Oct 2007    Post subject: FUEL TAP? Reply with quote
found the coolant bottle, cheers.
but ........
I cant remember wot you told me about fuel tap! (doh)
it has 3 positions - 6 o'clock
9 o'clock
& 12 o'clock
which is which, off/on/reserve?
i ask cos i ran out of fuel today on way home & got a bit confused as to whether i had been on main or reserve.
cant remember where the reserve is!
i dont plan to let it get that empty again.
ive filled it up but would help to know for future reference!
cheers,
GAZ
CaPo
PostPosted: 20:10 - 02 Oct 2007    Post subject: Reply with quote
6 o'clock is on, 9o'clock is off and 12 is reserve. Smile
How many miles did you get to the tank?
stirlinggaz
PostPosted: 21:09 - 02 Oct 2007    Post subject: Reply with quote
that explains why i ran out of fuel,
i was already on reserve
so i had used up everything!,
i think i got about 140 miles?
will check in morning asi was lucky it conked out just
a few hundered metres from garage, & then another few hundred home!
cheers,
GAZ
The last post was made 18 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.89 - MySQL Queries: 16 - Page Size: 84.56 Kb
