| D O G |
 D O G World Chat Champion
 Posted: 14:50 - 17 Nov 2007 Post subject: Car trouble driving me insane...start you bastard, start! |
I am really at the end of my tether with this one, please can anyone help me diagnose the fault, as I am fast approaching a violent breakdown.
Essentially the car (Volvo 850 2litre 20V, 1994) is becoming incredibly stubborn to start. On the advice of the AA man the other day I have changed:
- Crank sensor
- Coil pack
It has made no difference.
On checking the spark from the coil to the dizzy, whilst the engine is being cranked, there is no spark, but as you stop cranking (i.e. turning the key back off) a spark appears, and looks pretty strong. Clearly the spark at this point is useless, as you have stopped cranking.
The thing is, the problem can be fairly erratic - sometimes it just starts straight-away.
My partner relies on the car as her only transport - which she needs to use to ferry my 9month year old daughter around. Its really getting me super stressed out that I cant fix it, and money is pretty tight at the moment.
I reckon I'm going to have to get a mobile mechanic out to look at it unless I can sort it, does anyone know of a good one in the Southampton/Locks Heath/Fareham area?
Really appreciate anyones help with this.
Ta
Chris |
| flat spot |
 flat spot World Chat Champion
| Harold_Shand |
 Harold_Shand World Chat Champion
 Posted: 16:17 - 17 Nov 2007 Post subject: |
https://www.volvoclub.org.uk/
I needed their help a few times with a old 460 I had. Volvos? Reliable? Humph. ____________________ BCF's 6th favourite poster 2009-2010
Harold_Shand's theory might be the best explanation. |
| Kickstart |
 Kickstart The Oracle
 Posted: 16:25 - 17 Nov 2007 Post subject: |
Does it spark when you stop cranking, or as you turn the ignition off? Just that a coil works by discharging when the earth is interrupted, and would suspect this happens when power is cut to the ECU.
Anyway, suggests you are getting power to the coil but that the coil is not being triggered. So likely to be ECU / electronic ignition unit or the crankshaft position sensor, or the wires between them.
Is there just a single pickup? Some cars have 2 (one on the crank,one on a cam). Is there some kind of adjustment for the clearance from the sensor to the trigger?
| Kickstart |
| D O G |
The last post was made 18 years, 320 days ago. Instead of replying here, would creating a new thread be more useful? |
