| Rookie |
 Rookie World Chat Champion
 Posted: 17:14 - 21 Dec 2007 Post subject: Watercooling |
I've been upgrading my PC to a HTPC over the last couple of months, and the major issue I want to sort at the moment is noise. I'm running it in a horrible beige Tiny case with fack-off big case fans, a noisy PSU and quite a lot of stuff packed in. So I want to sort out the aesthetics and cooling in one, so naturally I've been looking at watercooling.
Is it worth it? I'm not exactly running a supercomputer at the moment, only an Athlon 3000, so it would seem a bit overkill right now. However, I've noticed 9600 Phenom Quad Cores are rather cheap now, and a matching motherboard is reasonable aswell. If I pile that in is it going to need watercooling?
I've been looking at a Thermaltake case with integrated watercooling:
Thermaltake
And a NZXT Hush case - NZXT - with a Kalman Resorator v2 running. Zalman
If watercooling is worth it, which type is worth it? The Thermaltake comes in £70 less than getting a Zalman but if it's not any good the £70 would be well spent, I know the Zalman's are pretty much the best money can buy. It would have to be really good for me to put up with it though, as another box hanging around is something I really don't need, despite it's prettiness.
Or I could just buy my NZXT case, some silent fans, a nice fanless CPU cooler like a Mars which I'm not sure about because that seems to be the quietest you can buy, and it's still 16dBs, and a quiet PSU. Which brings me to the last issue.
Are fanless PSUs any good? I've been told they love to overheat, so when it comes to PSUs should I be looking at fanless, or ultra-quiet fan ones?
Any and all advice much appreciated.
| lllN30lll |
 lllN30lll World Chat Champion
 Posted: 17:24 - 21 Dec 2007 Post subject: |
I think watercooling was originally designed for cooling purposes, not noise reduction.
if your not doing serious amounts of overclocking then i'd just stick to getting some very quiet fans instead.  ____________________ Turbo R1
CRF450R |
| Rookie |
| lllN30lll |
| Rookie |
| lllN30lll |
| Tarmacsurfer |
 Tarmacsurfer World Chat Champion
| Rookie |
 Posted: 18:50 - 21 Dec 2007 Post subject: |
| Tarmacsurfer wrote: | Thermaltake boxes with the water system built in tend to have something of a bad rep, small bore pipes so not a great flow rate and alos a tendency to leak at the drop of a hat, they're primarily used by people who have no idea wtf they're doing and want to boast about their watercooled "rig". The Zalman setup is nigh on silent so for an HTPC, assuming you have the space, then it's not a bad solution. To be perfectly honest, I'd try a build with the hush case on air cooling and see what you think, water cooling can indeed make a system alot quieter (depending on pump and a few other variables) but it would probably be overkill for what you've got in mind. |
Good stuff. Given I won't be upgrading the processor for a while anyway, I think that's what I'll do, though it seems like a waste spending money on quiet fans that could be going towards a Zalman! But then when it's time to do the CPU I can see if they handle it well enough and quietly enough - if not, it will have to be a Zalman. Thanks for the advice on the Thermaltake, I had a feeling that might be the case. |
| DEN MONKEY |
 DEN MONKEY World Chat Champion
The last post was made 18 years, 305 days ago. Instead of replying here, would creating a new thread be more useful? |
