Please help!!!!!!!!!!!!!!!!
ilovens125f's
PostPosted: 00:00 - 22 Dec 2003    Post subject: Please help!!!!!!!!!!!!!!!! Reply with quote
Ok here is the story ,I was coming down from 90mph
on my ns125f when I pulled in the clutch and it cut
out I tryed to start it , it kicked over twice and then
the kick start would not move it was stuk soild I had
to push it home for a mile please help . What could it be ????Crying or Very sad Crying or Very sad Crying or Very sad
Kev the Ns125F lover!!
!!!Dont ignore me!!!
PostPosted: 00:23 - 22 Dec 2003    Post subject: Reply with quote
Its seized. Smile
Dr Nick
PostPosted: 00:29 - 22 Dec 2003    Post subject: Reply with quote
MarJay wrote:
Its seized. Smile
Well try and have a merry christmas Razz .
PostPosted: 00:42 - 22 Dec 2003    Post subject: Reply with quote
It has seized. Has it freed off as it cooled down? If so the chances are it has just had the piston nip up with heat. Are you running with the stock oil pump or have you switched over to running premix? Running premix is more likely to result in a seizure when you shut the throttle and use engine braking from high revs.
If it is still not capable of being kicked over then the problem is a little more serious. I have never had the top end on a 2 stroke stay seized after the bike has cooled down. I have had it stay seized after a main bearing failed.
Dr Nick
PostPosted: 10:49 - 22 Dec 2003    Post subject: Re: Please help!!!!!!!!!!!!!!!! Reply with quote
My friend Alex's Aprilia RX125 did just that, and we thought it was seized, ended up just being a bit of gasket getting trapped between the piston and the barrel, making it tough to turn over.
ilovens125f's
PostPosted: 23:16 - 23 Dec 2003    Post subject: Reply with quote
Thanks guys
It kicks over now but still won't start Confused ,
i think it is the CDI unit i checked the
restance and they are all wrong Sad the bike (after
trying to bump it) freed the kick start(the spring sliped)
and now going to buy a new CDI . Can u guys estimate a price for me???
Thanks
Kev
The last post was made 22 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.48 - MySQL Queries: 16 - Page Size: 52.37 Kb
