TDR Issues...
Ridge Racer
PostPosted: 21:28 - 10 Jan 2008    Post subject: TDR Issues... Reply with quote
right lads long story short...
i had problems with my CDI aka Coil and the wire was part of the box, my mate desided to rip the wire off rendering the unit useless..
i ordered a new one and it came today but its like... twice as big?!
mine looks like this...
https://i8.ebayimg.com/01/i/000/bd/a1/df13_1_sbl.JPG
yet this new one has 2 connections on the top and is masssive compared to mine???
what should i do? as i dont think i can get hold of my original one? apparently those are from the earlier tublier frame models?!?!
or can i just run the one iv got? the main problems i have there is the 2 mounts dont line up i can only mount the unit on one of the mounts on the frame i cant seem to get it to spark either?!
help Neutral
Honda XLR 125 4 Stroke with Beefy Exhuast xD
finpos
PostPosted: 22:01 - 10 Jan 2008    Post subject: Reply with quote
Whoa. Step back!
Your CDI is not your coil. They are two separate things (though some smaller bikes have them built into the same physical unit). The coil is usually connected to the CDI by a single, small wire. A CDI will generally have 3 or 4 thin wires going to it and no thick wire.
That's a picture of a coil. Coils and CDIs are matched, so if you have another coil that's clearly physically different, there is some risk of blowing up your CDI if you connect them together. You'd need to measure the resistance of the coil to be sure.
Do you have a picture of the thing you were sent? maybe it's a combined coil/CDI???
If I were you, I'd try harder to fix your old one - may involve some cutting. I never understood those moulded in leads.
f.
Ridge Racer
PostPosted: 22:18 - 10 Jan 2008    Post subject: Reply with quote
thanks for the info, yes i was going to try and use the old one by screwing a wire into the part where the old wire went into it then put a convensional ht lead onto the end of the screw once hacked off then solicone it all up and hope for the best but the garage told me that it will not work?!
finpos
PostPosted: 22:32 - 10 Jan 2008    Post subject: Reply with quote
I've done that before, works fine. Cut the head off a screw and sharpen it so you have a two pointed screw, one end goes into what's left of the old one and then new HT lead and cap onto the other end. As you say, the problem then is getting enough mechanical support and electrical insulation around it to stop it arcing out at the join.
The other thing you can do is cut away enough of the coil casing to reveal the root of the HT lead.
f.
finpos
PostPosted: 22:49 - 10 Jan 2008    Post subject: Reply with quote
I hope your pictures are blurry otherwise I've just lost what's left of my eyesight Smile
1. Stick something in the spark plug hole. Small screws have a strange attraction to it, and you've no idea how annoyed you'll be when that happens Smile
2. Looks like the replacement is a coil, good guess that the extra black wire is an earth. But, still, you are in danger of killing your CDI, so if you don't know how to measure all the relative coil resistances (including that extra wire) I wouldn't risk it.
3. I hate to say this, but is the "unknown" wire supposed to go onto the spade on the coil? You coil should have 3 connections - One Earth (maybe through the body), one low tension (the spade) and one high tension (the spark plug) wire.
Ridge Racer
PostPosted: 22:55 - 10 Jan 2008    Post subject: Reply with quote
yea sorry my camera is terrible, heres the comparison between the 2, definetly not for this bike what so ever Laughing
im going to try and bodge the other one.. that wire (the orange one) connected to the coil on the top originally
the garage said that the part numbers etc all check out so there obiously not able to get hold of the replacement im after
bodge time Rolling Eyes
Ridge Racer
PostPosted: 00:21 - 11 Jan 2008    Post subject: Reply with quote
ok lads made progress here!
first i bodged it all up with a screw then hack sawing the screw head off then put the ht lead onto it, new plug on that
connected it all up and kicked her over and whoom! in a puff of smoke she started! goes alot better now? and idles better pretty good result for a bodge!
cheers for the help dudes Very Happy
The last post was made 18 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.93 - MySQL Queries: 16 - Page Size: 54.95 Kb
