Air Filter Reprocusions
Rowey
PostPosted: 23:27 - 21 Jan 2008    Post subject: Air Filter Reprocusions Reply with quote
I'm cosidering getting two KN style air filters for my cb250n super dream, so I can remove the air box and get rid of a bit of weight.
When I do this, will i have to adjust the carbs and will it have any drastic effects?
Thanks
ZX6R C6F.
hmmmnz
PostPosted: 00:53 - 22 Jan 2008    Post subject: Reply with quote
yes you will have to rejet the carbs, and lift the needles,
it takes quite a few time to get it right,
with my gs it took 5 jet changes and about 10-15 tweaks to get it running as well as stock
the humans are dead
I kick arse for the lord
TUG
PostPosted: 00:55 - 22 Jan 2008    Post subject: Reply with quote
Generally when you change something on a bike there is a repercusion.
I fitted a K&N and it made my bike run leaner, still needs setting leaner too.
Its best to jet your bike to suit the K&N's and it sounds like you are going for the pod types.
I have a guide you can read but apart from that i cant really help you as i'm no expert as many will agree, but i can help you out with a bit of reading oncarb tuning?
Haz ER-5, innit!
Rowey
PostPosted: 01:15 - 22 Jan 2008    Post subject: Reply with quote
Great link lonewolf, should be going to bed rather than reading it though Confused
ZX6R C6F.
TUG
PostPosted: 01:21 - 22 Jan 2008    Post subject: Reply with quote
Sleep is for the weak! I go to bed at 1 am then get up at 7:30 am. Shocked
I hope that guide gives you a rough idea, carb tuning is a black art but once practiced is extremly rewarding, i set my carbs up spot on once.. then i changed my exhaust. Thumbs Up
Haz ER-5, innit!
virus
PostPosted: 13:59 - 22 Jan 2008    Post subject: Reply with quote
it might be a bit difficult, superdreams dont tend to like pods as much as other bikes of that era (z250 for example) but basically, change em over, start it up with clean plugs and see how if runs, then plug check.
you want to be doing needle moving before getting new jets in, saves cash and might only need the needles raising a notch.
John
own: 81 xs1100g...
Rowey
PostPosted: 17:38 - 22 Jan 2008    Post subject: Reply with quote
Where can I get new jets for my super dream from? I recently replaced them with new, stock size ones. but don't know where I'd get bigger ones.
ZX6R C6F.
virus
PostPosted: 11:50 - 23 Jan 2008    Post subject: Reply with quote
what make and model carb is it?
should be able to get them from keihin or mikuni, if you cant find them on wemoto etc..
John
david silver spares is worth a check aswell
own: 81 xs1100g...
Rowey
PostPosted: 13:10 - 23 Jan 2008    Post subject: Reply with quote
They're Keihin VB30B's
I've already contacted David Silver's and they told me they only do stock sizes.
Where else may I get different size jets from?
And what size up do you think I'd need, im getting a motad 2-1 exhaust and some pod style KN air filters. I was going to go one size up and see how that goes.
Also would the jets from other hondas be inter-changable?
ZX6R C6F.
virus
PostPosted: 20:31 - 23 Jan 2008    Post subject: Reply with quote
its not the honda bit you want to compare, look for bikes with the same carb if you want to get jets like that.
a motad wont affect your caburation on its own, not a bit, k&ns will make it leaner, so lift the needles a notch at a time, test running it after every lift and doing plug checks to see how its going, then if you cant get it sorted on the needle then you need to get bigger main jets, oh and turn your pilot air screw towards rich (don't know if thats in or out on your carb) by about 1/4 turn, should make it idle right, if not then just turn it either way slowly until it idles evenly.
John
own: 81 xs1100g...
The last post was made 18 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.63 - MySQL Queries: 16 - Page Size: 68.07 Kb
