tatters Exxon Valdez
Posted: 21:46 - 15 Jan 2004 Post subject: Jet size |
l have fitted a after market air filter on my bike and it is running lean l was told that l would have to change the jet size and that l it would have to be a "del tory" jet cos the carb is on (told by garage) can any one tell me what the 1998 Honda nsr125 RR main jet size is and where l can get the right jet sizes to sort out the leaness problem. |
P_J Nearly there...
Posted: 21:51 - 15 Jan 2004 Post subject: |
AFAIK you can re-jet your bike yourself, personally, i'd get someone else to do it, ie the garage you took it to in the first place?
If you get the correct settings/size's and you are confident enough to re-jet it yourself then go ahead but is it worth the risk, not doing it correctly?
I'm sure someone will have the settings/size's you need though.
PJ ____________________ Dreams will get you nowhere, a good kick up the arse will take you a long way.
Only1PJ.co.uk |
Kickstart@Work Scooby Slapper
