correct grease for rear axle
Swim41
PostPosted: 16:28 - 16 Feb 2008    Post subject: correct grease for rear axle Reply with quote
Hi,
What's the recommended grease for rear axles? Last time I refitted my rear wheel I used graphited grease as I was in a hurry and it was all I had. Is this suitable or should I use something else ~ got visons of rapidly wearing components ~
cheers Smile
Yamaha XJ600N
boffo
PostPosted: 16:41 - 16 Feb 2008    Post subject: Reply with quote
"Correct" grease is likely to be a molybdenum disulphide grease.
Graphited is more suited to leaf springs on olde worlde cars, but it wouldn't cause a problem. Owt's better than nowt.
ZRX61
Victor Meldrew
PostPosted: 17:02 - 16 Feb 2008    Post subject: Re: correct grease for rear axle Reply with quote
cheers Smile
The grease is pretty much to stop corrosion & make it easier to remove/replace....nothing should be moving enough against the axle to wear it out...that's why we have wheel bearings Wink
Swim41
PostPosted: 17:47 - 16 Feb 2008    Post subject: Re: correct grease for rear axle Reply with quote
I knew that, honest! Embarassed Home-mechanicing is a steep learning curve.
cheers guys!
Yamaha XJ600N
TUG
PostPosted: 18:00 - 16 Feb 2008    Post subject: Reply with quote
silkolene red racing grease ftw. Use it alot at work, copper grease for threads and red grease for alot of other aplications.
Haz ER-5, innit!
ZRX61
Victor Meldrew
PostPosted: 22:05 - 16 Feb 2008    Post subject: Reply with quote
I have a tub of Valvoline gen purpose grease thats red, it don't half hum.. Shocked
PostPosted: 22:20 - 16 Feb 2008    Post subject: Reply with quote
Red water-resistant grease stinks too. I hate re-loading my grease-gun with that stuff.
Cigaro
PostPosted: 11:40 - 17 Feb 2008    Post subject: Reply with quote
Last time I did it I used copper grease, seemed to work fine.
Finglonga
PostPosted: 11:53 - 17 Feb 2008    Post subject: Reply with quote
I use anything to hand, the axle isn't a moving part as said its only to stop corrosion and make it easier to remove if needed.
Andy Sez....
F.Y.Y.F.F.
fra-zzr
PostPosted: 13:47 - 17 Feb 2008    Post subject: Reply with quote
another vote for copper grease, just cos it was around. Iv heard black lithium grease is good though Question
Syx
PostPosted: 14:14 - 17 Feb 2008    Post subject: Reply with quote
I just used whatever generic grease was around at the time. I think I ended up going with something that said "multi purpose grease" on the tin.
ZRX61
Victor Meldrew
PostPosted: 16:44 - 17 Feb 2008    Post subject: Reply with quote
I've used:
Boat trailer wheel bearing grease (blue)
Lithium (whitish)
Axle/Moly (black)
Valvoline GP (red)
Castrol LM (Lt brown)
& some synthetic stuff....
The last post was made 18 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.39 - MySQL Queries: 16 - Page Size: 72.27 Kb
