| Hunter |
 Hunter Nitrous Nuisance
 Posted: 17:11 - 16 Jun 2002 Post subject: need help guys! |
Hey guys and girls! I need a bit of help, pleeeese reply cause my RK is lying naked on the garage floor screaming for help..
1) Is SAE 40 good enough for transmission oil? ambient temperature all year round is about 29 degrees centigrade here..!
2) If I want to replace piston rings and reeds do I have to replace any gaskets? Is there any sealant I could use with the old gaskets as gaskets are not available here in sunny sri lanka!
3) I have to replace the foam air filter with a new one cause the old one has a gaping hole in the center (bits were sucked in..!), any suggestions on replacement foam filters? Any special type of foam required or would normal foam do?
4) Any precautions when cleaning out a carb for the first time? Are there bits I shouldn't fiddle with too much?!
5) Ok.. thats it for the moment.. round two tommorow
Thanks for the effort.. really appreciate it!
Hunter |
| Guest |
 Guest
 Posted: 13:32 - 17 Jun 2002 Post subject: |
Pleeese respond my bike needs to get out a bit..  |
| peabo |
 peabo L Plate Warrior
 Posted: 17:09 - 18 Jun 2002 Post subject: |
Hey there!!
First of all NSRs are crap in comparison to Aprilia RSs!! heheh.. I know cause I own both...
1) SAE 40 (API SE etc.) is good enough.. you don't need multi-grade oils for NSR transmissions.
2) You can just use a sealant.. but its recommended to change gaskets.!
3) I suppose normal foam would do.. i've never really had to replace them before.. but don't really think its that important. Now that you know your bike worked without the air-filter why don't you just leave it like that!!!
4) don't fiddle with anything you don't know about.. just use compressed air to clean it thoroughly.
I suppose most people here don't know much about NSRs after all.. hahaha
P-BO |
| G |
 G The Voice of Reason
| Keen |
 Keen World Chat Champion
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 18:31 - 18 Jun 2002 Post subject: hmmmmmm |
i dont see it the rs has the top end trophy but from the rs's ive ridden the nsr out accelerats it to 60 and out handles it, i have never had an rs keep up with me on corners ive evan had a race through my local national park lol with a vfr400 and won the guy who was ridin it was evan nice enough to get in the first round ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| TiN |
 TiN Pocket Tin
| Korn |
 Korn Admin
| Dan |
 Dan Brolly Dolly
| Scooby |
 Scooby Scrappy Doo
| Demonic69 |
 Demonic69 The Pink Rhino
| Hunter |
| Kickstart |
 Kickstart The Oracle
| TiN |
 TiN Pocket Tin
 Posted: 22:30 - 19 Jun 2002 Post subject: |
Isn't it funny how all of the questions are actually being answered now?...welcome back Keith!...we've been padding out the topic posts in anticipation of your return...
Tin |
| Kickstart |
| Hunter |
 Posted: 16:59 - 20 Jun 2002 Post subject: |
Keith mate!! I have a question!
I took the air box apart for an inspection (first time since I bought the bike) and found that a chunk of it has got swallowed into the carb and no doubt the combustion chamber and through the exaust.. hehe
I have noticed that the power was really down on the lower revs on my bike lately and thats why I decided to have a look at the air box.
1) Do I have to take the carb apart and clean it up thoroughly? When taking it apart would I have replace any o-rings?
2) Can I improvise a new piece of foam with anything else? I.e. do the ones for other bikes work too? In sri lanka you cannot find NSR specific stuff.
3) Can I change the reeds too while i'm at it.. without replacing any gaskets?
As you can probably tell I'm new to this bike servicing stuff!!
cheers for the help.. really appreciated!
Hunter |
| Kickstart |
| Dylan |
 Dylan Trackday Trickster
| Hunter |
 Posted: 18:55 - 25 Jun 2002 Post subject: |
You can get carbon fiber ones from boyesen (though MandP also I think)..
I'm doing an over-haul on my bike at the mo.. and will put these on.. will keep you posted!
Keith! Thanks for the replies!!
I just bought myself a compression tester.. is this a surefire way of testing the cylinder compression? How is the best way to test for compression using it? Any suggestions would be greatly appreciated!!
Is servicing the transmission a tough job? can you do it all without special tools (i.e. any flywheel pullers needed?) I have got the usual set of tools (spanners, wrenches, allen keys and feelers), no torque wrench though
What does usually go wrong with the transmission on NSRs? Mine feels a bit 'sticky' and the return spring ain't too good I think!
Cheers!  |
| Kickstart |
| Hunter |
 Posted: 19:32 - 25 Jun 2002 Post subject: |
Cheers Keith!!
My problem is that I cannot find head gaskets in Sri Lanka.!
I would have liked to take the head apart though, because I want to check the condition of the piston/head.
I have imported a piston (with rings) from MandP, its a brand called 'JCC' (taiwanese), any ideas on the quality of these pistons? Should I replace it with the Taiwanese one if I take the head apart? My bike is a NSR 125RK with 16000KM on it..!
Also, have you heard of Silicon gasket makers? Are they any good as gasket replacements, can they be used together with old gaskets which are in good shape (for low pressure areas such as reeds)?
Too many questions I know.. I'm still learning!!
Cheers! |
| Kickstart |
| Hunter |
 Posted: 19:22 - 26 Jun 2002 Post subject: |
Keith! More questions!
I took the carb apart and have taken all the jets, pilot screw, and throttle stop screws off.
How does the float level affect the performance of the bike?
Also, I noticed that the strainer screen that was supposed to be present at the fuel inlet was actually not there! Does this cause an issue? I suppose I should be able to find one tommorow... wonder why anybody would take this off.. anything performance related?
What does the pilot screw do exactly? I have heard from some that this should be 2 turns from some people and 2.5 turns from some others! Was wondering what difference this makes!
Okay thats it for now ! Cheers! |
| Hunter |
 Posted: 19:25 - 26 Jun 2002 Post subject: |
Oh and one more thing, what is the best possible way to clean the entire carb.. I have access to a compressor but can't for the life of me figure out how these little jets and holes can be blown by the 1/2 inch tube that comes out of it!! Wouldn't they fly off!! How about using a compressed air can? would the pressure be enough?
Thanks again!!  |
| Kickstart |
The last post was made 23 years, 179 days ago. Instead of replying here, would creating a new thread be more useful? |
