spray painting wheels?
ljwalker
PostPosted: 19:17 - 14 Mar 2008    Post subject: spray painting wheels? Reply with quote
i notice my wheels where looking very tatty on my bike how do i go about spraying them do i need to still apply primer ect any tips or guidence would be very much appreciated.
thanks. Very Happy
19van71
PostPosted: 19:21 - 14 Mar 2008    Post subject: Reply with quote
A picture/photo of your wheels may give a better idea of the task ahead. Wink
Living the dream....on my little 'ol CG125 Very Happy
Proview
PostPosted: 19:40 - 14 Mar 2008    Post subject: Reply with quote
Well i would have to say obviously take the wheels off the bike and rub them down untill all of the old paint has come off and you can see bare metal (well)
use a good primer and let it go off
Get a good colour, spray with air powered air machine or use a can
If using a air powered machine use a top coat ( clear ) should help protect the paint
Now im not too sure how long it would last because of the salty roads and stuff but if it was me i would do it my self
But if it is done profressionaly ie poweder coated etc it would defonitvley last longer
Hope this helps
Aerox R 50cc 2008 ,Aerox RR 2002, Mbk Nitro 2001, Beta RRT Elf racing series ,1989 Beta trueba Needs fixing
! ! ! -Pat- ! ! !
Gonna wrap a teatowel around the lid nextime..y'know for relgious reasons
ljwalker
PostPosted: 20:04 - 14 Mar 2008    Post subject: Reply with quote
yeah that is a great help i was just looking on a website at some spray paint is it any good?
https://beedspeed.com/paint-silver-wheel-paint-500ml-p-4294.html?cPath=80_167&osCsid=69e225e8ab5c60f67651a71f21257d0c
although i dont really want it that colour can you recomend anywhere i can get it from?
thanks Thumbs Up
tutton
PostPosted: 22:18 - 14 Mar 2008    Post subject: Reply with quote
Its the same process me and that Z6 person explained in your other thread, except if your taking it down to bare metal you should use a etch primer.
Also any local motor factors sell that paint as simonitz is a big aerosol brand, i remember seeing it in places like hickley valtone, autospares, just any general car shops. i dont think halfrauds stock any but there own..
Edit my wrong they do sell the 5 colour silver
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_161743_langId_-1_CarSelectorCatalogId__CarSelectorGroupId__varient__categoryId_90895_crumb_33958-90886_parentcategoryrn_90895
ZRX61
Victor Meldrew
PostPosted: 05:00 - 15 Mar 2008    Post subject: Reply with quote
Wheels are a PITA, just get em powder coated Smile
ljwalker
PostPosted: 08:28 - 15 Mar 2008    Post subject: Reply with quote
so i wet and dry them down to bare metal Thumbs Up
then i apply etch primer Thumbs Up
wait for primer to go off Thumbs Up
do i wet and dry again or not Question
then apply top coat Thumbs Up
is that right or not Question
ZRX61
Victor Meldrew
PostPosted: 17:43 - 15 Mar 2008    Post subject: Reply with quote
Not even close Wink
ljwalker
PostPosted: 18:26 - 15 Mar 2008    Post subject: Reply with quote
good job i decided to get the garage to do it then wasnt it Thumbs Up
tutton
PostPosted: 19:27 - 15 Mar 2008    Post subject: Reply with quote
most people would sand blast wheels,
You wouldnt wet and dry to bare metal
we just use dry paper/pads, as you'd need some harsh grits to rip off al the old paint
Etch yes, wait for it go go off, then put a layer of real primer over the etch, dont wet and dry unless you mucked it up, then arnt you going to add some paint?! bare metal isnt pretty,?
Hope that helps
and ye powdercoating is the best way as so many stone chips otherwise Smile
ljwalker
PostPosted: 19:30 - 15 Mar 2008    Post subject: Reply with quote
like i said im geting someone else with experience to do it now but thanks for your help
ZRX61
Victor Meldrew
PostPosted: 19:40 - 15 Mar 2008    Post subject: Reply with quote
Which remove too much material so the wheel bearings will fall out when they are refitted... Wink
tutton
PostPosted: 19:41 - 15 Mar 2008    Post subject: Reply with quote
I thought that was the norm to remove bearings, and either fit new bearings or reuse the old ones (if viable) whilst doing this..
ZRX61
Victor Meldrew
PostPosted: 20:27 - 15 Mar 2008    Post subject: Reply with quote
It is, but no one in their right mind sandblasts alloy wheels & expects the bearings to fit in the (now larger) hole.
The only wheels that are sandblasted are steel.....
crphillips
PostPosted: 21:09 - 15 Mar 2008    Post subject: Reply with quote
I was a pro sprayer and i would sandblast the wheels. I just simply mask off the bearing races/housing with tape and avoid that area. Most wheels are cast and have textured spokes......if you sand it you remove the original texture. Also with sanding you cannot remove 100% of corrosion without removing serious amounts of material.......sandblasting keeps the original texture and also removes all corrosion as it can get to the bottom of any pitting.
If you have your wheels sprayed by a pro they will sandblast them.
The best way would be to paint strip them, sandblast and then powder coat although 2K paint is more than adequate.
You made the right choice getting them done by a pro.....the cans of spray paint you buy are rubbish......the first time you get some petrol or other solvent on your wheel it would pickle the paint and come off.
CBR600RR8 Hannspree Colours, beautiful!
tutton
PostPosted: 21:11 - 15 Mar 2008    Post subject: Reply with quote
As i thought Thumbs Up
was going to say. we might of wrecked some gixxer wheels if that was true about not sandblasting!
ZRX61
Victor Meldrew
PostPosted: 01:57 - 16 Mar 2008    Post subject: Reply with quote
We use #80 glass bead Smile
PostPosted: 09:30 - 16 Mar 2008    Post subject: Reply with quote
Just leave the bearings in, do all the work then fit new bearings. Either that, or turn-up some blanks.
The last post was made 17 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.29 Sec - Server Load: 1.26 - MySQL Queries: 16 - Page Size: 103.53 Kb
