What engine?
garth
PostPosted: 16:10 - 27 Mar 2008    Post subject: What engine? Reply with quote
First of all I am fully aware I'm an idiot.
I'm going to change the engine in the goose. I want something a bit pokier. Like a 500 2T or similar.
I was thinking CR500, but don't they vibrate like buggery?
So basically just want to know what peoples knowledge of compact, powerful 2T singles there are around.
//Discuss
PostPosted: 16:16 - 27 Mar 2008    Post subject: Reply with quote
Doing this would be a hell of a lot of work (and with no lights, etc, using a CR500 engine).
Think the Goose uses the engine as a stressed part of the frame which will make things more difficult.
thegubner
PostPosted: 16:28 - 27 Mar 2008    Post subject: Reply with quote
Was there a 500 gamma?
That was 2 stroke wasn't it?
I heard they were loads of fun if i am thinking of the right thing.
map
Mr Calendar
PostPosted: 16:38 - 27 Mar 2008    Post subject: Reply with quote
IMO sounds easier to play around with the engine bits, pistons, carb jetting, exhaust, etc. rather than an engine swap.
garth
PostPosted: 16:56 - 27 Mar 2008    Post subject: Reply with quote
I have the know how and tooling to do so.
Was thinking about building a cradle.
The only major mounting point for the goose engine is the rear. This goes into a cast piece of ally which is then bolted to the steel trellis frame. The front of the engine is bolted to this also, and there is one final top engine mount.
I thought I could make a cradle running from the rear engine mount (in the cast ally) to the front mount on the steel trellis, and go from there.
Think it's do-able.
NSR Mick
PostPosted: 17:01 - 27 Mar 2008    Post subject: Reply with quote
Of course it's do-able go for it. Thumbs Up
CR500 would be the best bet for performance. If you want to retain a charging system etc maybe a CRM250 engine would be the one to go for although you wouldnt be gaining much performance wise.
PostPosted: 17:05 - 27 Mar 2008    Post subject: Reply with quote
How long do you want it to last between services?
Some of the MX 4 stroke single 400cc motors could be pretty good.
Aprilia SXV550 motor. Razz
garth
PostPosted: 17:08 - 27 Mar 2008    Post subject: Reply with quote
Big_Ham
There's not too much space in there, that's why I'm thinking 2T single.
With regards to the charging front, I found someone who has done a cr/derbi and they fitted a lighting coil, https://dspace.dial.pipex.com/prod/dialspace/town/pipexdsl/s/asgq17/CR5/page2.htm
Hmm.
PostPosted: 17:34 - 27 Mar 2008    Post subject: Reply with quote
I wonder if a DRZ400 motor would fit?
Ought to be suitably insane.
mrtEE
PostPosted: 19:14 - 27 Mar 2008    Post subject: Reply with quote
DO you mean insane to swap a 35bhp motor for a 40 bhp motor?
Yes does seem a bit mad Wink
PostPosted: 19:19 - 27 Mar 2008    Post subject: Reply with quote
Iwouldn't fit a 2T crosser engine they just aren't suited to road-riding. Sure it would be a mental-case but at the expense of an extreme maintenance schedule.
PostPosted: 19:44 - 27 Mar 2008    Post subject: Reply with quote
I would consider some of the enduro 2strokes rather than mx - these often come with all the charging stuff etc for a start and are a bit more reasonable on the road.
KTM EXC range (don't do it anymore, but there was a 380cc 2 stroke if I remember) Gas Gas EC range. KTM did an 'EXG' 250 which was autolube.
On the 4 stroke side, Husaberg 650 or similar to keep the weight down (probably less than your 350); can get a 750cc kit for the Hussy' that actually makes it more reliable!
Or go for a Maico 685cc 2 stroke if you could actually find one Smile.
Are you sure the Goose frame can take it; maybe you should look at a new frame at the same time Razz.
dougon2wheels
PostPosted: 20:26 - 27 Mar 2008    Post subject: Reply with quote
garth wrote:
Big_Ham
Hmm.
the cr5 motor makes for an appauling road bike,too vibey,doesn't like constant throttle,hard to start,etc,etc.
there's a few cr5 conversions out there(i thought about it for my mito),most of them are unfinished projects,or they never get taken out and ridden,one guy converted an rgv to cr power,spent thousands,with hundred of hours of work,then after a week of trying to ride it he said it was just too viby to ride with any enjoyment and converted it back to the rgv engine.
unfortunatly the lad who owned the derbi 50/cr500 sm conversion was killed by it a few months later Sad .
my vote would be for maybe a cr250 motor(far more managable)if it has to be an mx engine,crm 250 nice but not that much more powerful.tuned tzr/tdr 250 or 350 ypvs would be my choice
PostPosted: 20:44 - 27 Mar 2008    Post subject: Reply with quote
That all the difference? I always thought the DRZ400 was one of those new generation, banzai crosser motors.
Hey ho.
Madmanx
PostPosted: 20:48 - 27 Mar 2008    Post subject: Reply with quote
Rd 500 lc engine if you can find one. Cool
or Suzuki Gt 500
https://i284.photobucket.com/albums/ll9/manxhornet/Hornet001.jpg
sickpup
Old Timer
PostPosted: 21:43 - 27 Mar 2008    Post subject: Reply with quote
Hey ho.
You really are in for a surprise. Dog slow.
PostPosted: 22:07 - 27 Mar 2008    Post subject: Reply with quote
If you look at the DR350 to DRZ400E engine, I suspect in real terms you're more talking maybe 10'real'hp at the rear wheel difference, less for the 's' model.
However they are still a heavyish and not too fast, but reliable engine. Basically a water cooled XR400 sorta thing.
Suzuki do the RMZ450 I believe which is that 'bansai' crosser thing.
DRZ is fine for what it is, but just whish they'd given it a sixth gear.
Madmanx
PostPosted: 22:14 - 27 Mar 2008    Post subject: Reply with quote
BLUEX5 wrote:
or Suzuki Gt 500
eh?
PostPosted: 08:51 - 28 Mar 2008    Post subject: Reply with quote
garth wrote:
Big_Ham
Hmm.
A 350 single 4T came out so surely a 400cc 4T shouldn't be too much of a struggle? I was joking about the SXV. Razz
garth
PostPosted: 08:57 - 28 Mar 2008    Post subject: Reply with quote
Now theres an idea. I rode an EC300 GG. That went well.
Um, as for the frame, we'll find out. I reckon it can handle a bit more.
Just brainstorming at the moment. But thanks for the input. Thumbs Up
Matty21
PostPosted: 10:01 - 28 Mar 2008    Post subject: Reply with quote
what about a 350 lc ?
or A kr1 Wink 250 2t
ktm 660, just some suggestions
He who does not dare,does not succeed!
Trackdays half the season, second half racing.
PostPosted: 10:06 - 28 Mar 2008    Post subject: Reply with quote
Note the comment about the derbi 50cc conversion - ok we're talking a lot more of a difference in power there, but it's definitely something to bare in mind.
From what I remember, they couldn't work out if the frame broke after or before the impact, but he had definitely been told by many people that what he was doing wasn't a great idea.
The last post was made 18 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.29 - MySQL Queries: 16 - Page Size: 140.64 Kb
