lost key
ashwin2936
PostPosted: 12:04 - 10 Apr 2008    Post subject: lost key Reply with quote
Hi as you can see from the title i have lost the key for my 1994 honda nsr 125, but i have an immobiliser which i can start the bike with and cut it out, the big problem is that i cant open the tank to put anymore petrol in. ive been told if you have the key code you can get a new key cut but i dont think i have it unless you can find it on the bike. can anyone recommend the cheapest solution to gettin a new key
cheers
ashwin
Cigaro
PostPosted: 12:12 - 10 Apr 2008    Post subject: Reply with quote
If you go to Honda with the registration they will be able to get you a new master key.
Mac_Black
PostPosted: 23:14 - 12 Apr 2008    Post subject: Reply with quote
I lost my key and even though I had the key code Honda told me they could'nt (would'nt more like) do anything about it Evil or Very Mad
So I had to get a lockset of ebay, and then pay £140 in labour and transportation charges to get it fitted.
(Yes not only did I loose my key but I had left the steering lock on so they had to take the whole front end appart to replace the locks Embarassed )
Tricolor Fan
PostPosted: 23:31 - 12 Apr 2008    Post subject: Reply with quote
I assuming it's an after-market immobiliser from your post.
If it is then all you need to do (assuming you don't have the steering lock on) is remove the ignition barrel and find the barrel number that will be stamped on it somewhere.
A good locksmith should be able to make up a key based on this number. PM me for the number of one that'll cut it and post it for £11.50.
Give me ambiguity or give me something else.
PostPosted: 23:40 - 12 Apr 2008    Post subject: Reply with quote
If you need it quickly, there are some that will come to you and make the key - expect to pay around £70; I'd go with the £11.50 option if you can Smile.
GhostRider
PostPosted: 09:31 - 13 Apr 2008    Post subject: Reply with quote
Hi,
Did exactly the same thing myself about a month or so ago.
Had left the steering lock on also, after ringing about 20 or so locksmiths found only one guy that was willing to come out and sort it.
The first night he got there at 6pm and called it a day at about 10.20pm, came back the next day and finally managed to cut a key to fit the lock (without knowing the key code) in about an hour. He was contemplating taking the whole front end off to replace the barrel etc, but said it would have taken him a few hours and woulda most likely cost me £300-400, so I was god damn lucky he was able to do it just by cutting it to the lock.
All in all cost me £150, needless to say I've got 4 copies of the key now and I wont be making that mistake again.
Feckin locksmiths must be bloody raking it in.
GhostRider
PostPosted: 09:43 - 13 Apr 2008    Post subject: Reply with quote
Generally cheaper if you can, say, get the top yolk with ignition barrel off and take it to them.
PostPosted: 12:03 - 13 Apr 2008    Post subject: Reply with quote
An NSR lock won't be all that complicated, and probably quite worn inside. With a bit of jiggling a similar key wold most likely open your tank cap to get you out of trouble temporaily.
The last post was made 18 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.4 - MySQL Queries: 16 - Page Size: 57.76 Kb
