Author |
Chuck100 |
Chuck100 Two Stroke Sniffer
Back to top |
Sparks! |
Sparks! Sir Tart-a-lot
Posted: 02:27 - 11 Feb 2004 Post subject: |
1) Replace the measuring screw thing you need it anyway.
2) The left side, you'll find is actually the spindle, so it should just push through (Use a hammer to gently knock it through) Keep the wheel level as it'll make getting it out easier (as the spindle goes through wheel, the side will sag a bit which makes it difficult, same for when fitting it back in)
3) Best off removing the rear caliper, just unbolt it and slide it off the disc and support it out the way, don't remove from the bike though, no need.
4) When wheel is loose, push in towards shock, lift chain off and remove, repeat in reverse to re-fit it.
You'd be best off getting the wheels laser aligned at a garage anyway, only costs a tenner and is well worth the money, that's what I do anyway as I can then be sure wheels are perfectly aligned! ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
Sparks! |
Posted: 02:30 - 11 Feb 2004 Post subject: |
By the way, whilst wheel is off, perfect opportunity to give the rear shock and swing arm a proper clean, it's a difficult area to clean when wheel etc is in the way but it'll have loads of crud spat up by the wheel just corroding it all away. So you might as well give it a clean over. ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
Chuck100 |
Back to top |
Chuck100 |
Back to top |
Sparks! |
Posted: 11:21 - 11 Feb 2004 Post subject: |
You need that bolt to adjust your chain etc, so you'll have to get one.
The spindle needs to come all the way out, it shouldn't be too difficult though, try lifting the rear wheel slightly as might loosen it up a bit. Make sure your knocking it through from the other end by the way, I don't know anything about 125's or NSR's but most bikes you undo the left side nut then hit the left side through, as the right has is basically the spindle so won't go through the swing arm, if that makes sense? (Could be other way around though I think, doesn't matter, but it should be clear which way it needs to go through)
For your chain, clean it in paraffin and a toothbrush then re-lube it all up with non-fling chain wax.
No idea on tyres am afraid as I know bugger all about any bikes below 400cc's someone from here should help though! ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
Kris |
Kris World Chat Champion
Posted: 11:26 - 11 Feb 2004 Post subject: |
Bridgestone BT45's are your best bet my friend. ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
Back to top |
Crash it for fun |
Crash it for fun Spanner Monkey
Back to top |
Kris |
Back to top |
Chuck100 |
Back to top |
Sparks! |
Posted: 22:24 - 11 Feb 2004 Post subject: |
DIY/home improvement stores etc have them
If not go to a bike shop and ask for some chain cleaning products or something.
I think you can use WD40 tho or white spirit but I'd double check first ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
Back to top |
chunkielad |
chunkielad Nearly there...
Back to top |
The last post was made 20 years, 79 days ago. Instead of replying here, would creating a new thread be more useful? |
