| Leviathan |
 Leviathan Borekit Bruiser
| 2006 _p1 |
 2006 _p1 Crazy Courier
| Welshd1k |
 Welshd1k World Chat Champion
| Thom |
 Thom World Chat Champion
| Welshd1k |
| Leviathan |
| Kickstart |
 Kickstart The Oracle
 Posted: 19:47 - 08 May 2008 Post subject: |
RS is in a higher state of tune. A carb alone doesn't so much give you performance, more supply fuel and air adequate for the performance. If the rest of the engine can produce more power than that size of carb can flow the mixture for then you loose power.
The RS125 34mm carb runs far larger jets than the 28mm carb fitted to other RS125s.
Larger carb is a bit of a double edged sword. While they does supply mixture for the higher power output they will also tend to have more problems at lower engine speed.
| Leviathan |
| Leviathan |
| Kickstart |
 Posted: 22:17 - 08 May 2008 Post subject: |
No, a huge carb alone will do nothing. A larger carb will support an engine that is capable of producing more power, but will likely loose lower down power.
The larger the carb for an engine size then the lower the air speed through it, so less pressure drop which means it doesn't atomise the fuel as well. At higher engine speeds the gas speed is high enough. Hence you can land up with an engine that may make a bit more power but the loss of low down power makes it feel like it is making quite a lot more power.
Anyway, as such the size of carb on an engine is a compromise. And depending on the maker they may have already gone for as larger a carb as will work effectively on the engine. Or they might have used a smaller carb and lost nothing at the top end, or smaller again and lost some top end.
With fitting a larger carb yourself you then have all the fun of trying to get the jetting at least close to correct. And the makers have a lot more experience and equipment to get this right than most people do.
| Leviathan |
| Kickstart |
 Posted: 13:37 - 09 May 2008 Post subject: |
| Leviathan wrote: | i see so am i right in thinking the pressure from the downwards piston action has to really suck the fuel past the jets or it wont enter the cylinder in the correct er... consistancy? |
Essentially yes. Carb provides a slight restriction, which causes the air speed to increase. Higher speed air lands up at a lower pressure and this results in fuel being drawn from the float bowl into the air stream (technically the atmospheric pressure pushes the fuel into the lower pressure airstream in the carb). Large carb at low revs and there is very little pressure drop so the carb works poorly at drawing the fuel into the airflow.
Same basic principle that an aircraft wing uses, but with a wing the air going round the top has further to go than that around the bottom, so the air on the top travels faster, hence lower pressure.
| Leviathan wrote: | this is beggining to make sense, and i can see what your saying, so bogging down will happen in lower revs because there is less of a force present? |
Basically yes. Also one reason why with slide carbs you need to open them progressively, rather than just yanking them fully open at low revs (and why CV carbs where the slide is also operated by air pressure is a lot more idiot proof).
| Leviathan wrote: | the only thing left to clear up is how my mates mito managed to pull it off | [/quote]
Same as the RS125. A 34mm / 35mm carb is within reason for the rest of the engine. But the Mito / RS have more radical port timing, ignition timing, exhaust design, etc, enabling them to take perform better with a larger carb.
| Leviathan |
| Kickstart |
 Posted: 22:08 - 11 May 2008 Post subject: |
Larger carb might be necessary to take advantage of other engine mods. It is all a compromise.
Basically it is true that the more fuel / air you ram into the cylinder the more power you will get. But a carb doesn't really do that, it just allows in the fuel / air demanded by the engine up to a limit. You can use a larger carb to raise that limit, but if the engine cannot draw in more mixture it is a waste, and you will likely loose out at the bottom end.
| Leviathan |
| Kickstart |
 Posted: 12:42 - 12 May 2008 Post subject: |
Trouble with both superchargers and turbochargers (well, technically a turbocharger is a type of supercharger) is that they take power to drive them. With a turbo this means that you likely loose a load of power at low revs and gain some at high revs, but also give it a trickier to control throttle response (ie, you open the throttle, the engine responds to that, the turbo gets speeded up by the engine waking up and then that shoves more fuel / air into the engine).
Carb jets flow fuel, and the size of the jets affects how much fuel they flow, but you need the air to go with them. Fuel air ratio should be around 14 parts air to 1 part fuel (by weight, not volume), but you have advantages running it a bit either side of that. Bit more fuel and you get more power, bit less fuel and you can reduce fuel consumption (at the expense of emissions of oxides of nitrogen going through the roof).
However it isn't only the size of the jets that affects the fuel they flow. As mentioned earlier the carb works by the pressure difference between the air going through an atmospheric pressure (basically the atmospheric pressure presses on the fuel in the float bowl). If you do something strange then this can have odd effects. For example full throttle on a slide carb at low revs and the air pressure through the carb will be barely lower than atmospheric pressure, hence barely any fuel gets pushed into the fuel / air mix going to the engine.
Worse than that run a wrongly designed turbo setup and you will pressurise the air going into the engine, and land up with it at a higher pressure than the air pushing on the fuel in the float bowl. Hence no fuel goes to the engine.
| Leviathan |
| Kickstart |
| Leviathan |
| Leviathan |
| Kickstart |
| Leviathan |
| Kickstart |
The last post was made 17 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
