| julie-nsr-125 |
 julie-nsr-125 Derestricted Danger
| Trixie |
 Trixie World Chat Champion
| StealthDJ |
 StealthDJ Nova Slayer
| julie-nsr-125 |
| Trixie |
 Posted: 13:40 - 02 Jun 2008 Post subject: |
If your fuel tap has a "prime" position, the tap should be in the horizontal position, as it would be for "off" on other models. If you look closely, it should be marked as either "prime" or "off".  ____________________ Dead nobodies in company cars... |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:46 - 02 Jun 2008 Post subject: |
Fairly certain it doesn't have a vacuum fuel tap.
I would normally suggest a blocked fuel filter, but think the NSR does without one, even in the carb itself. Next suggestion would be the fuel tank breather being blocked.
However if the breather was blocked (or anything else restricting fuel flow) then pulling the choke on would just manage to keep it running for a bit longer. It would still die when the fuel in the carb was used up.
| StealthDJ |
| julie-nsr-125 |
| Kickstart |
| StealthDJ |
| julie-nsr-125 |
| julie-nsr-125 |
| StealthDJ |
| julie-nsr-125 |
| StealthDJ |
 Posted: 14:28 - 02 Jun 2008 Post subject: |
It's not the float that you want to clean, particularly, it's the valve that it opens and closes (which you have to remove the float to get to). On some bikes they drop straight out, on others, you need to remove a retaining collar - I'm not sure which it is in your case.
A damaged float usually sinks and floods the carb - you'd be having the exact opposite of the problems you're having.  ____________________ Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50 |
| Kickstart |
 Posted: 14:29 - 02 Jun 2008 Post subject: |
If I am reading this correctly:-
1) Engine will not start or run without choke taking fuel from the tank.
2) Engine will start and run with choke on taking fuel from the tank, and continue to run indefinatly.
3) Engine will start and run fine if you put a funnel full of petrol directly the the fuel pipe on the carb.
These seem contradictory to me, so I suspect I am missreading your description of the problem.
Could you go through in detail the exact symptoms and what you have tried (whether it worked or not) to get around it.
| julie-nsr-125 |
| julie-nsr-125 |
| Kickstart |
| Kickstart |
| julie-nsr-125 |
| julie-nsr-125 |
The last post was made 17 years, 188 days ago. Instead of replying here, would creating a new thread be more useful? |
