keith-im sorry-help!!
batman
PostPosted: 15:29 - 21 Jun 2002    Post subject: keith-im sorry-help!! Reply with quote
my bike is overheating now very badly
i think i may have damaged the engine just goin down the road a few times
we took it apart again searchin for blockages etc, but the radiator, engine and coolant tank are all full of coolant and seem fine
any ideas why it is overheating so badly?
thanx
Kris
PostPosted: 15:41 - 21 Jun 2002    Post subject: Reply with quote
Hmmm
Dont think you should have messed with your Aprilia matey. Crying or Very sad
Why didn't you use a dealer?
Keen
PostPosted: 16:11 - 21 Jun 2002    Post subject: Reply with quote
Thats like a worst nightmare come true- mess about with your bike and fuck it up Sad Embarassed
(I'm sure keith will post something more constructive soon)
PostPosted: 22:49 - 21 Jun 2002    Post subject: Reply with quote
My RS125 started overheating a while back when I had done the rings. Turned out I had used too strong a mix of antifreeze in it. Took some out and replaced it with water and the bike was fine. Antifreeze is very thick, and an impellor cannot pump it round that well.
After that, check for an air leek (use the bleed screw to get any air out of the system) and check the thermostat is OK (probably, as not heard of one going on an Aprilia 125)
All thebest
batman
PostPosted: 23:34 - 21 Jun 2002    Post subject: pray Reply with quote
i put soem fuck off -36 degree shit in
its for cars
ill try that tomorrow-i already did the valve thingy
im just praying now that i didnt fuck it up driving it around when it was overheating so bad-i went out at night and it only rises when stopped, which i wasnt for about 10 mins, so when i did the thermo hit 90!
please dont be scorched cylinder/fucked rings :(
thanx anyway man
PostPosted: 11:45 - 22 Jun 2002    Post subject: Reply with quote
Think a car water pump is rather better at pumping round than the small impellor fitted to a bike. One thing to check is whether the radiator is hot when the engine is. When I had too strong an anti freeze mix in place the engine was hot, while the top of the radiator was slightly warm and the bottom cold. My bike got somewhat hotter than 90 degrees.
PS - you will need some antifreeze in place to stop the water corroding the alloy of the engine, but pure water is a very good coolant.
Ropehead
PostPosted: 22:38 - 22 Jun 2002    Post subject: Reply with quote
any ides about my bike its not getting up to temp?
it one point it was over heating and when i looked the impeler wheel had snapped of so i glues it back with some epoxey resin worked a treat, iv putt a new thermostat in 2 still not heating up fully only 1/4 ish..
if i have 2 much water E:g a weak coolent mix could that cause it 2 not get up to temp?
THanks Guys Laughing
TZR 125 bye the way
PostPosted: 10:36 - 23 Jun 2002    Post subject: Reply with quote
Not sure, but on any occasion where I have overfilled the colling system (on a car) the resulting excess preasure has resulted in the car overheating. My guess would be the thermostat you have put in is not correct. Other point to check is that the temp gauge is reading correctly (air air bubble round the sensor could cause odd readings), but to be honest it is about 12 years since I last rode a TZR125
batman
PostPosted: 00:16 - 24 Jun 2002    Post subject: query Reply with quote
hey keith i was just wonderin how long it takes before new rings are run in
i need to know when i can hit the powerband again!
i think however the engine might be arsed, find out for sure tomorrow whether the coolant fun has affected it
tanner18
PostPosted: 08:40 - 24 Jun 2002    Post subject: Reply with quote
the temp gauge on my nsr 2000 only just comes out of the blue is this a good thing should it be in the middle or is mt temp gauge likely to be knackered please help
inline 4's rule
Ropehead
PostPosted: 09:30 - 24 Jun 2002    Post subject: Reply with quote
will running it at a lower temp do any damage?
batman
PostPosted: 19:09 - 24 Jun 2002    Post subject: temp Reply with quote
my mates nsr temp guage never gets above half way ever
i think it may be an nsr thing
TiN
Pocket Tin
PostPosted: 19:21 - 24 Jun 2002    Post subject: Reply with quote
...what?...you mean the "NSR is more reliable" thing?... Razz
...(just joshin' with ya mate...I have nothing against Aprilia's... Wink )
Tin
PostPosted: 19:59 - 24 Jun 2002    Post subject: Reply with quote
Except when the antifreeze mix was too strong the RS has never had an overheating problem. The older '87 model AF1 would, but only slightly (they also were meant to run at a lower temp).
The one that gets real hot very quickly is the Bimota. Instant boil in tthe bag if you are wearing waterproofs and get caught in traffic
batman
PostPosted: 23:08 - 24 Jun 2002    Post subject: bah Reply with quote
its stopped now
everythin is workin, but the horrible sound persists!
the piston/rings/cylinder are all perfect, but still it sounds deep and heavy
i havent been able to trash it yet, only 60km done since rings put in, but i have a smelly feelin it wont pull as well as it did!
thanx keith for the help
and any other suggestions
The last post was made 23 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.23 - MySQL Queries: 16 - Page Size: 86.73 Kb
