| Shay HTFC |
 Shay HTFC World Chat Champion
 Posted: 16:51 - 21 Jun 2008 Post subject: GS500 back brake issues |
Ok... Ever since I've bought this bike, the back brake hasn't worked properly.
I replaced the pads and cleaned out the brake pistons etc, but couldn't bleed them. Tested everything (as per a previous thread) and decided that the master cylinder was bust.
I've just got a new one, but the same problem exists.
Now, this is hard to explain, but I tried playing with my old one and when I replicated the bleeding process (used my fingers to cover the entry and exit holes and test the pressure and vacuums that are created when pushing the arm in and out)
I learnt that the master cylinder essentially 'blocks up' when the arm is pushed only a little bit in (I blew down the pipe that comes from the reservoir and after the push arm bit went in just a tad, it blocked my blowing).
Now my theory is that when the brake is off, the master cylinder isn't actually fully released, in that the through passage from the fluid reservoir to the brake line is still blocked and therefore not sucking fluid down the pipe.
Not sure if I rambling or even understandable, but the master cylinder worked when I was trying it out in my hands using my fingers to block off holes and test out the suction and vacuums that are created.
What do I do? As far as I can tell, the arm needs to come right back out, but the brake mechanism is keeping it pushed in a bit and I can't seem to adjust it as the brake lever and 'rear set' seems to be locked in place.
Anyone ever had a similar issue or got any tips? ____________________ Full Motorbike License - GS500E '95 |
| Shay HTFC |
 Posted: 17:03 - 21 Jun 2008 Post subject: |
EDIT: Just been for a better look and it seems I need to adjust some of the nuts on the 'arm'. Just gonna have a play around with that.
The master cylinder definitely works. I've just unattached it from the brake lever and let the push rod go out to its fully extended length and manually pushed it in and out and the bleeding process works fine.
Only I think that the pushrod is at its most extended already. I might have to cut some of it off, but that doesn't seem right!
(I'll try and get some photos to explain what its like later because this is hardly easy to understand and picture )
EDIT:
Added a video with a bit of commentary
https://www.youtube.com/watch?v=jb7pJFX0Gfg
As you can see, the rear brake lever is as high as it goes. Infact, it's too high and should be lower. But making it lower involves pushing it down and just makes the problem worse.
How can I make the push rod come further out even though it is as far out as seems possible? I've read two manuals and the net and it says that you should just adjust the adjuster nut. Doesn't give any more info.
All I can think of is cutting the push rod and making it shorter! ____________________ Full Motorbike License - GS500E '95 |
| Thom |
 Thom World Chat Champion
| Shay HTFC |
 Posted: 19:32 - 21 Jun 2008 Post subject: |
Well I've been looking through the manual thoroughly and on other things that aren't directly related to the brake pedal. It turns out there is a pinch bolt that determines the position of the brake springs etc AND the bracket that the master cylinder connects to.
I don't have the right allen key to take of the whole footrest bracket , but hopefully tomorrow I can get hold of one, take off the pinch bolt and put it back on a slightly more rotated angle which should have the master cylinder bracket pulled further away. Will get my brake pedal in a better position too hopefully.
I've attached a pic of the pinch bolt and the mechanism around that area. ____________________ Full Motorbike License - GS500E '95 |
| Shay HTFC |
The last post was made 17 years, 301 days ago. Instead of replying here, would creating a new thread be more useful? |
