welding an exhaust
Bikeless
PostPosted: 14:12 - 02 Jul 2008    Post subject: welding an exhaust Reply with quote
Hi,
Can i weld my fireblade exhaust while it is connected to the bike?
Thanks
Paul
virus
PostPosted: 15:27 - 02 Jul 2008    Post subject: Reply with quote
Yeah, Id disconnect the battery first though to avoid risking damage to the CDI etc.
Cheers
John
own: 81 xs1100g...
ZRX61
Victor Meldrew
PostPosted: 17:03 - 02 Jul 2008    Post subject: Reply with quote
.. & put the ground clamp as close to the weld as possible...
I also disconnect electrical stuff like CDI's & FI brains etc
hmmmnz
PostPosted: 17:37 - 02 Jul 2008    Post subject: Reply with quote
as as above, but its a real bastard to do,
but if you can't be fuct removing the rad act, then there uis no problem with doing that.
good luck
the humans are dead
I kick arse for the lord
mca6969
PostPosted: 18:15 - 02 Jul 2008    Post subject: Reply with quote
why not just remove the exhaust
its only a few screws Confused
Yamaha Aerox 07 Rossi rep De restricted variator + polini belt
Finglonga
PostPosted: 18:18 - 02 Jul 2008    Post subject: Reply with quote
You reckon? Shocked
Andy Sez....
F.Y.Y.F.F.
Bikeless
PostPosted: 18:36 - 02 Jul 2008    Post subject: Reply with quote
Yeh,after removing/disconnecting rad which means i then have to go out and buy distilled water and the fancy 5 year coolant i put in it,then a stud breaks/snaps/threads,new exhaust gaskets.I can't be arsed when it's a couple of small blow holes on the link pipe.
Thanks for the advice everyone,i thought i would have to disconnect the battery but will probably do the CDI and rectifier too as it takes seconds.Oh and the clamp near the weld sounds like a good idea too.
Cheers Paul.
Pete.
PostPosted: 20:01 - 02 Jul 2008    Post subject: Reply with quote
If the pipe is badly rusted (in separate pieces) then it's always best to at least tack it together on the bike. It's amazing how far out of line you can weld a pipe if you take it off first.
a.k.a 'Geri'
sheep2504
PostPosted: 20:08 - 02 Jul 2008    Post subject: Reply with quote
My exhaust was welded when still attached to the bike but it had to be placed on the edge of a pit as the angle was to difficult to do otherwise.
Stilll fine and that was about 2 years ago
The last post was made 17 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 16 - Page Size: 61.62 Kb
