Gearbox got confused
bunglehaze
PostPosted: 17:18 - 30 Jul 2008    Post subject: Gearbox got confused Reply with quote
Hi folks, I have just had the wierdest experience after atking my bike out today, I got on and rode out of my alleyway in first just fine, got to the main road and struggled to find second, then it would not go into first without a crunch at which point I noticed the lever felt like it was jammed up.
Anyhoo, I carried on trying to shift up and got no joy so pulled into a petrol station to take a look and see if there was anything obvious, I turned off the bike and tried to hand shift up through the gears - again first and second only and a wierd crunch type feeling as I did.
Then I couldnt find neutral at all and my bike will not allow me to start up with the clutch lever in which I dont quite understand, anyway after a bit of manual persuading of trying 1st to second for about 10 minutes it found neutral again so I started her up to try and ride around and see if I could get any more movement, third came a bit crunchy but eventually happened and then I could get the rest so I got my gear on and rode off steadily to see what happened.
After shifting through the entire box it suddenly went silky smooth, no clunking or notchiness at all, just sweet shifts.
Anyhoo, I am obviously a little concerned how this might have happened and if there is a possible cause for it that would need looking at, all I can think is that it got tangled up for some reason as the box now feels better than it ever has done before.
Any suggestions on what might have happened?
cheers
leigh Very Happy
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
ZRX61
Victor Meldrew
PostPosted: 01:07 - 31 Jul 2008    Post subject: Reply with quote
It would appear that you aren't aware that Kawasaki's will only go into 1st or neutral when the bike isn't moving..
calum17
PostPosted: 22:04 - 31 Jul 2008    Post subject: Reply with quote
not true, my ZZR6 does both when moving if i want it to ...
bunglehaze
PostPosted: 23:07 - 31 Jul 2008    Post subject: Reply with quote
Yeah but as per original post it wouldnt go past 2nd while moving in the first place, THEn wouldnt find neutral.
cheers
leigh Very Happy
ZRX61
Victor Meldrew
PostPosted: 23:58 - 31 Jul 2008    Post subject: Reply with quote
& what exactly does that have to do with what I posted? Rolling Eyes
calum17
PostPosted: 06:40 - 01 Aug 2008    Post subject: Reply with quote
you said kawasaki's dont go into neutral or first when the bke is moving ... but mine does. so it's not all kawasaki's that dont do it.
mattgirv
PostPosted: 06:50 - 01 Aug 2008    Post subject: Reply with quote
Why? Confused
Bikes: 1998 Honda VFR800Fi, 26,500 miles Laughing
1989 Honda CB-1, 38,000 miles
daywalker
PostPosted: 15:03 - 01 Aug 2008    Post subject: Reply with quote
have these last few comments helped to answer the original question? no its just a bickering war! sorry dude cant help on your problem,it just annoys me when you ask a simple straight foward question and some numptys start a "yes you can no you can't"!!!
old people are like slinkys.........there not much use but they make you smile when you push em down the stairs!!!!!!!!
if it's got wheels or breasts it's gonna cost you money!
PostPosted: 15:32 - 01 Aug 2008    Post subject: Reply with quote
Not really it seems like one bloke can't grasp the word "isn't" and thats it.
mr.kris
PostPosted: 16:00 - 01 Aug 2008    Post subject: Reply with quote
change ur oil and filter and look for any metle fileings sounds like it may have eaten a tooth or 2 something not right there drain it and see whats in it dont ride it till you have done it or if you have got fielings ur going to be throwing them all round the motor doing all kinds of nasty ness!!!!!!!!!!!!!!!!!
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
Finglonga
PostPosted: 16:14 - 01 Aug 2008    Post subject: Reply with quote
Eh? In English please. Rolling Eyes
Andy Sez....
F.Y.Y.F.F.
Timmeh
PostPosted: 16:42 - 01 Aug 2008    Post subject: Reply with quote
Finglonga wrote:
Eh?
bruv change oil bruv before engine goes bang mate, sound yeah?
Finglonga
PostPosted: 20:27 - 01 Aug 2008    Post subject: Reply with quote
Timmeh wrote:
Finglonga wrote:
Eh?
Tis betta blud! Thumbs Up
Andy Sez....
F.Y.Y.F.F.
ZRX61
Victor Meldrew
PostPosted: 01:45 - 02 Aug 2008    Post subject: Reply with quote
Are you having a bit of trouble with basic reading comprehension? That's the exact OPPOSITE of what I posted you doofus.... Rolling Eyes
ZRX61
Victor Meldrew
PostPosted: 01:49 - 02 Aug 2008    Post subject: Reply with quote
mattgirv wrote:
Why? Confused
So you can easily find neutral without doing a Fred Astaire impression on the shift lever.
scott666
PostPosted: 11:08 - 02 Aug 2008    Post subject: Reply with quote
Assuming its the bike in your avatar, i had the same prob with my J2 (same bike with different size engine) just grease all around the gear change lever with a quality grease. The problem is they are open to the elements and grit etc can get in them and this causes the problme you described i once had to ride 10 miles in 2nd gear on fast duals to get home, greased it and it was fine.
steppen22
PostPosted: 16:03 - 02 Aug 2008    Post subject: Reply with quote
No it isn't.
You wrote:
"It would appear that you aren't aware that Kawasaki's will only go into 1st or neutral when the bike isn't moving.."
I.e:
Kawasaki's will only go into 1st or neutral when the bike IS STATIONERY.
And the chap replied:
"Not true, mine goes into n/1 when the bike is moving (i.e not stationery).
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
ZRX61
Victor Meldrew
PostPosted: 16:25 - 02 Aug 2008    Post subject: Reply with quote
steppen22 wrote:
No it isn't.
I.e:
Good fucking grief there are some pedantic fucking morons on this forum.
OK, let me word it thusly:
When the bike is NOT MOVING it will only go into 1st or neutral. Which is why these same fucking morons end up tearing apart Kaw engines they have just rebuilt when they *test* the gearbox with the engine sat on the workbench. It's not unknown for some of these same brain donors to do it 3 or even 4 times.
The last post was made 17 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 1.39 - MySQL Queries: 16 - Page Size: 104.58 Kb
