| Sallyt |
 Sallyt L Plate Warrior
| tutton |
 tutton World Chat Champion
| Sallyt |
| saikouslx |
 saikouslx Renault 5 Driver
| ballbag |
 ballbag Two Stroke Sniffer
 Posted: 13:06 - 19 Aug 2008 Post subject: |
you can check if the GPR is sparking by removing the sparkplug, connecting the HT lead to the plug and placing a bit of the plug on the cylinder head (so that its metal on metal). Push the starter button and you should see the spark plug sparking... if not take it to a mechanic..
remember to hold the spark plug by the HT lead or you might get a nasty shock .. I know this..
Derbi's are normally pretty reliable. Have you checked all the fuses? |
| samj6 |
 samj6 Renault 5 Driver
 Posted: 20:48 - 19 Aug 2008 Post subject: |
my mate had exactly the same problems but with the 125 faired gpr i can't remember exactly but i think it cost him bout £300 to get it sorted and it's still dodgy every so often!! Think it was the ignition coil and something else lol sorry not much help really |
| prawny1 |
 prawny1 World Chat Champion
| Sallyt |
| prawny1 |
| jake_Gpr50 |
 jake_Gpr50 L Plate Warrior
 Posted: 17:38 - 13 Feb 2009 Post subject: Re: Derbi GPR50 starting problems |
hi im new to this website, i have a Derbi Gpr 50 2000model.
i have a problem with the bike starting, i took off the front mud guard to try and fix a couple of the brackets and i had to ride it around to and from collage and water kept on splashing up at all the eletrics and the bike kept cutting out. i got the bike home and took the coil off and dryed it with a hair dryer and i dryed all the eletrics and i have a spark and there is petrol getting to the spark plug "which i renewed aswell" but it just still doesnt want to start can any one please help me regards jake
email me on [email protected]  |
There is a gap of 330 days between these two posts... |
| DERBI DOCTOR 99 |
 DERBI DOCTOR 99 L Plate Warrior
 Posted: 12:17 - 10 Jan 2010 Post subject: Re: Derbi GPR50 starting problems |
hello there..
i own a derbi gpr 50 race replica and i had serious problems with it starting and i had to bump it in every dry place possible and was starting to get on my nerves.
my solution is quite simple really... problems that could occur are as the followings below...
1. clean the exhaust baffle (rod with holes in the muffler) as carbon sticks to it and could suffercate breathing area so dip in a flammable substance such as parrafyn, burn the baffle and rub it with a wire brush or ..... buy a road legal race can, thats what i did.
2. check carburettion as it could be over-flooding your engine or your mixture is too rich- check float height
3. use better oil than what your already using (castrol is my recommendation)
4. lubricate the bike in every place apart from brake disks and calipersas you are masking a sheet of oil over them and obviously the brakes will not be able to grip disks
5. starter motor could have seized and could need anew.
6. if you hae worn out the battery the best thing is to buy a new one.
7. CHECK YOUR TICK-OVER SCREW! i had my derbi and the idiots put my revs ticking over at 1000rpm .. you want it ticking at more than 1000 and less than 2000.
8. weak spark, pick up coils too far from rotor
no spark, sooty spark plug or faulty rotor
9. if none of this has helped your bike is in need of a serious service, send in to the nearest dealer and if he is good enough he should charge you only £50 for full service check.
derbi has a regular occurance with starting problems and it all relies down to 2-stroke engines... their rubbish... good top end but 0% in reliability, you'll be lucky for a derbi to last you 10 months before it needs a new engine. dont hurt the bike and rev its butt off , keep it running nice and easily, 2/3s of throttle for first 100miles.
last and final thing, if you have had the bike de-restricted thats when the problems come in, shorten engine life and it just simply wont start unless you do something about it DO NOT DE-RESTRICT BEFORE 600 MILES!!.. my dad and the people at his work were draining my head with all of this information and beleive me, it worked. |
| swiftb |
 swiftb World Chat Champion
 Posted: 20:12 - 10 Jan 2010 Post subject: |
I think he may have fixed it or given up by now considering it was posted nearly a year ago |
| ms51ves3 |
 ms51ves3 Super Spammer
| swiftb |
| Dalemcgarry |
 Dalemcgarry L Plate Warrior
The last post was made 16 years, 284 days ago. Instead of replying here, would creating a new thread be more useful? |
