Installing speakers into the parcel-shelf of a car.
JonB
Afraid of Mileage
PostPosted: 08:52 - 02 Oct 2008    Post subject: Installing speakers into the parcel-shelf of a car. Reply with quote
Right on the outset this seems like a chav like question to ask.
However, my Citroen C1 only has two very poor speakers at the very front of the car which has no quality to the sound at all. Usually a stock setup in a car is enough for me, but anything above vaguely loud sounds tinny and un-satisfying.
Therefore I am looking to install some half decent speakers to the rear of my car and not use the two front ones already installed. I have absolutely zero knowledge of car electrics and so installing is going to be a pain in the ass as it is.
My main bone of contention is if i'll still be able to take the parcel-shelf out of the car when I want to load more than a weeks worth of shopping (The C1 possibly has the smallest boot space of any car about). What I mean by this is can you disconnect the speakers easily enough to be able to take parcelshelf out of the car?
This may sound confusing, I apologise in advance if it is, but I have no idea what I am talking about. Laughing
D O G
PostPosted: 09:04 - 02 Oct 2008    Post subject: Reply with quote
Do it properly and put decent speakers in the FRONT.
You don't go to a concert then stand with your back to the stage.
Should be easy enough, just remove door panels, speakers, see how big (and deep) your hole is, get some better speakers to fit (preferably co-axials with an in-built tweeter, if you don't already have separate tweeters). Wire up, install, job done.
Plus, you won't knacker the parcel shelf, display your 'mad' speakers to the local chavs, and the inside will look stock, retaining the value of the car.
I did it in my Daewoo (ok, don't laugh), bought the cheapest, biggest speakers that would fit (for like 25squid - last season's Panasonics), wired them up and installed. No probs, and plenty enough volume and clarity for me. It's loud enough to make me want to turn it down before I get any distortion.
Speakers in the parcel shelf is cowboy style.
Finglonga
PostPosted: 09:08 - 02 Oct 2008    Post subject: Reply with quote
You would be better to put a decent set of component in the front as you will get no highs or mids from the rear. Then fit a sub for the bass.
Andy Sez....
F.Y.Y.F.F.
Mr Hammers
PostPosted: 09:08 - 02 Oct 2008    Post subject: Re: Installing speakers into the parcel-shelf of a car. Reply with quote
You could fit a quick connector in the wiring so that when you need to take the shelf out you just disconnect the speakers, something like this;
. . . . . . . . . .|===[]=========> to player
where ( ) are the speakers, and [] is the connector.
Have a look at maplins.co.uk, they should have what you need.
A Guide To Powerbands
Fawbish
PostPosted: 09:22 - 02 Oct 2008    Post subject: Reply with quote
I installed some rear speakers in me gfs old Rover, wasnt hard at all, i did it with a knife and a small screw driver.
Mind you, it had rear speakers to begin with. But it wouldnt be hard to make some connectors up (or, grab some from Halfords or soemthing, you can get "grip connectors" theyre easy enough.)
and run some wire to the rear, should be easy.
However, if you want better quality, your radio/stero system might need upgrading, as speakers wont just don the job by themselves if the origin of the music isnt good enough anyway.
Id only use a sub if you were doing a proper jobby.
We got some nice looking "Fly" ones for about 30 quid for two 6" speakers, they look good, pretty tasteful, and sound a lot better than standard. Thumbs Up Might do the rest soon, but the car has 122K miles, so might not have enough time left Laughing
JonB
Afraid of Mileage
PostPosted: 09:25 - 02 Oct 2008    Post subject: Reply with quote
The main problem I have with installing them at the front is that my car doesn't have your conventional door speakers. Instead the speakers are right at the front of the dash, which I imagine will be a royal pain in the arse to get too.
I too would much prefer decent sound from the front.
Not should I would want a woofer as: -
A) The boot is tiny, wouldn't want to stick something like a woofer in it.
B) I'm on a tight budget.
My car dash...
https://img.photobucket.com/albums/v93/JonBod/DSC00438.jpg
JonB
Afraid of Mileage
PostPosted: 09:28 - 02 Oct 2008    Post subject: Reply with quote
Maybe in older cars, but this car is new and IMO new systems tend to be a lot better. I know for a fact VW and Ford stock systems are fantastic. Although my car is a Citroen, 80% of it is a Toyota and this head unit is the same as the one in the Aygo. I'm sure it would be good enough.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 09:34 - 02 Oct 2008    Post subject: Reply with quote
Parcel shelf speakers are pure chav. The only thing you want coming from behind you is bass - rear speakers in cars are for rear passengers.
PostPosted: 09:35 - 02 Oct 2008    Post subject: Reply with quote
Grab a Haynes and have a look at how to remove those grills. They might well just be a push fit, revealing the speakers as soon as they are out of the way.
Also check for any other positions set up for speakers. Likely to be other places designed to hold speakers on higher spec models. If you are lucky they may even already be wired up.
JonB
Afraid of Mileage
PostPosted: 09:40 - 02 Oct 2008    Post subject: Reply with quote
I'm just gonna have a search about on the net for some sort of guide to changing the speakers.
My spec of the C1 is the lowest spec available. Not even got central locking or leccy windows. Laughing The courtesy light doesn't even come on when the passenger door is open. Laughing
PostPosted: 09:42 - 02 Oct 2008    Post subject: Reply with quote
They are unlikely to have spent extra money tooling up new plastic interior panels especially for the cheap spec car just to remove the other speaker positions.
JonB
Afraid of Mileage
PostPosted: 09:50 - 02 Oct 2008    Post subject: Reply with quote
Well that was easy...
Found out how to get to the speakers on the Toyota Aygo owners club site.
The standard unit supplied with the car is made by Panasonic. Changing the speakers is the easiest way to enhance the sound in your system. For the Aygo you will have to get a set of 100mm wide speakers for the front and back. Speakers are generally sold in pairs. Generally speaking all you have to do is unscrew the old speakers unplug them then connect up the new speakers and screw them in. To access the front speakers (which are on the dash) you will have to remove the plastic cover on the A-Pillar then prise off the speaker cover with your hands from the side. There are only two screws/bolts needed to hold the speakers in the Aygo therefore on your new speakers you will have to snip off two screw-hole prongs that are not needed, then put your new speakers in place and screw them in.
Fitting a subwoofer:
You have two choices in this section:-
1. Buying the official Toyota subwoofer from a dealer
2. Fitting your own subwoofer purchased from an car audio shop
Using the official Toyota subwoofer it would be mounted underneath the front driver’s seat. This is done by wiring it in by removing the front drivers seat and running the cable supplied along the centre console next to the gear shift.
Fitting your own would involve wiring the power for your amplifier from the battery. The thickness of this wire depends on the power of your amplifier. The best place to run the power cable for the subwoofer on the Aygo is the opposite side from the battery as the main wiring loom grommet comes through the bulkhead on the drivers side of the car. Also the remote turn on for the subwoofer should be wired to pin 7 (white wire) on the power plug as this is the ignition power for the radio, so the subwoofer only turns on when the ignition is on.
You would also have to RCA cables (phono) for the audio signal which would run down the nearside. This would come from the headunit. To use the original headunit that came with the car you will need to purchase a high level to low level converter for the RCA cables.
So I need 100mm speakers it seems. I have found a site that does speakers, but have no idea what makes a decent speaker.
Also is a sub /really/ needed as it seems too complicated to install. Laughing
Budget - £30 tops. https://www.caraudiocentre.co.uk/category_m-4-34-speakers-10cm-_c-995.htm
D O G
PostPosted: 12:25 - 02 Oct 2008    Post subject: Reply with quote
You really won't need a sub if you put some decent speakers in. However, 100mm isn't that big - so they may lack bass. I would look at the hole first, and see if you can get something bigger in there - it may well be possible.
The original speakers in my car were 100mm, but 130's went in no problem, and have plenty of bass, even when I dust off the old drum n bass choons!
Even if you can go no bigger, you may find you don't want/need the extra kick a sub will bring.
As for type of speaker, pretty much any of the big names' entry level co-axial speakers will be many, many times better than the ones in there at the moment. Don't worry about it too much.
Oh, and someone said about uprating the head unit. From my understanding, the weakest link in the majority of original car audio equipment is the speakers, not the head unit. Personally I wouldn't go there at all.
Fawbish
PostPosted: 12:34 - 02 Oct 2008    Post subject: Reply with quote
Well I only suggested that as the ol' Rover is '96 reg. Its original stuff is not up to much Laughing
If youve got a newer head unit and its good, cool.
But my only point was that some people will buy new speakers, expecting it to be perfect, and not realise the headunit is letting the modern (better) speakers down.
D O G
PostPosted: 12:42 - 02 Oct 2008    Post subject: Reply with quote
True. Unfortunately the gays who now design car interiors make the most annoying head units, no longer the standard letterbox.
I just had a look on th epics of his interior - the head unit is all swoopy and that. Major ballache to change, and it would look pump.
JonB
Afraid of Mileage
PostPosted: 12:57 - 02 Oct 2008    Post subject: Reply with quote
OK. So it seems that a sub might well be a bit pointless in my car. I'm sure Tiesto will sound good without it.
So the difference between a pair of £15 kenwood speakers is likely to have little difference over some costing £28?
Wave2k
G's Stalker
PostPosted: 13:05 - 02 Oct 2008    Post subject: Reply with quote
Ive got a set of 6x9s in my parcel shelf (i didnt put them there), but i love music specially when its put through quality speakers.
No amp just a set of speakers wired up to a good head unit.
Best 'mod' you can make to a car imo
Ducati 1299 Panigale
2009 Corvette C6 z51
JonB
Afraid of Mileage
PostPosted: 13:09 - 02 Oct 2008    Post subject: Reply with quote
Well i'm a lot like that and usually stock speakers are pretty good, but these are dire. I have a decent sound setup on the PC and when you got a decent tune on through decent speakers it makes the hairs on my neck tingle. Laughing
Apparantly the head unit in my car was made in conjunction with Panasonic and Toyota, so I reckon that would do fine and the CD player looks really well tied in with the dash and it has an AUX input, so I really don't want to buy a new head unit.
JonB
Afraid of Mileage
PostPosted: 13:15 - 02 Oct 2008    Post subject: Reply with quote
I'm a bit confused, what is the difference between dual cone and co-axial speakers?!
JonB
Afraid of Mileage
PostPosted: 13:30 - 02 Oct 2008    Post subject: Reply with quote
Another question also, what is better a 2-way or 3-way speaker?
Finglonga
PostPosted: 18:40 - 02 Oct 2008    Post subject: Reply with quote
Dual Cone . . .
https://www.germes-online.com/direct/dbimage/10387377/Car_Speaker__CS2005_B_.jpg
2 Way Coaxle . . .
https://www.allproducts.com/manufacture100/ztzaudio/product2-s.jpg
3Way . . .
https://carjamz.com/zen/images/15-PRC63.gif
But component 2 ways would be easier to fit . .
https://img.alibaba.com/photo/101012445/Hertz_Hsk_165_2_Way_Component_Car_Speaker.jpg
As you can get the tweeter in the correct place for the best sound.
Andy Sez....
F.Y.Y.F.F.
tutton
PostPosted: 20:25 - 02 Oct 2008    Post subject: Reply with quote
When my brother has been installing speakers and subs etc into his hot hatches and that.
He kept hammering into me the higher the wattage the better it will sound up louder. so go for some nice Alipines or JVC's
https://www.caraudiocentre.co.uk/product_m-alpine-sxe-6925s_p-21902.htm
chrisw
PostPosted: 20:41 - 02 Oct 2008    Post subject: Reply with quote
Then he really didn't know a huge amount about what he was fitting I'm afraid.
Yes, higher wattage = better power handling, but it says nothing about sound quality.
For 99% of small cars a decent set of components in the front is all that is really needed. If you still want more volume, attach them to an amp. If you still arn't happy, look to sound-deadning before doing anything else.
Price is genrally a good guide to quality with car audio, buy cheap, expect poor sound quality, spend a bit more and you'll hear the difference (despite what the bloke in the pub might say about is £20 market-stall 6x9s).
JonB
Afraid of Mileage
PostPosted: 05:21 - 03 Oct 2008    Post subject: Reply with quote
I presume car speakers are the same as normal speakers and i've always followed the line of thought that more factors come in than just pure wattage.
depth of sound frequencies is quite important as well, so i've ended up settling for these: -
https://www.caraudiocentre.co.uk/product_m-pioneer-ts-g1002i_p-23155.htm
Not gonna pay £7.99 postage though, luckily their nearest store is in Brum, so a 20 minute drive away, will get them later and give you feedback.
Icey
PostPosted: 06:09 - 03 Oct 2008    Post subject: Reply with quote
Have you looked at : https://www.caraudiodirect.com
They have a sale on ATM.
The last post was made 17 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.37 - MySQL Queries: 16 - Page Size: 144.26 Kb
