Honda XR 125 L 2006 - General Maintenance Help Please?
Leicester1977
PostPosted: 20:42 - 30 Sep 2008    Post subject: Honda XR 125 L 2006 - General Maintenance Help Please? Reply with quote
Hi I have just purchased a 2nd hand XR125 L 6 - Can someone please help as i havent got a manual (????)
How do I remove the Seat?
Is the Air filter under the seat?
Choke positioning which is on or off UP or DOWN?
I can start it in when pushed down or middle at present but not if fully up?? - I have played around but any time I put fully up it cuts out??
Splutters!! - when riding the bike sometimes it splutters and loses power for a bit the bounces back into life - not fully just spluttery - ANY IDEAS Why this is??? Its usually in 3rd/4th Gear.. it lacks power then finds it loses it finds it etc........
Many Thanks for your Help?
PostPosted: 09:24 - 01 Oct 2008    Post subject: Re: Honda XR 125 L 2006 - General Maintenance Help Please? Reply with quote
Usually you remove the side plastics.once removed you'll see two bolts holding the seat on (once removed the seat slides backwards)
Not sure on that bike but usually accesed from the side of the bike.(black box with a cover held on by a few screws?).If you could take a couple of pics of the side of the bike i could tell you for sure.
When you have the bike running,if you put the choke fully on the bike should cut out.(from what you said i would say fully up is choke on?)
Start with a service (oil,oil filter,air filter,plugs) and see if it get's better.Not worth messing about with other things till you've checked the basic service items.
DRZ-400sm
adz4321
PostPosted: 07:33 - 07 Oct 2008    Post subject: Reply with quote
Choke on is fully up! i found out the hard way - flat battery
Keir
PostPosted: 15:41 - 07 Oct 2008    Post subject: Reply with quote
having the choke on wont flatten the battery.
Current : '08 Yamaha FZ1s
adz4321
PostPosted: 06:44 - 08 Oct 2008    Post subject: Reply with quote
No but having it turned off will . . . lol . . . as it don't start = Dead battery
alan52
PostPosted: 21:11 - 08 Oct 2008    Post subject: Reply with quote
The air filter is under the seat, should be quite easy to spot.
The choke is off in the fully down position .The spluttering sounds exactly like what happened last time I rode off and forgot to turn the choke off on my xr125.
The last post was made 17 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 16 - Page Size: 50.37 Kb
