suzuki GS500 valve shim tool?
PostPosted: 19:02 - 26 Oct 2008    Post subject: suzuki GS500 valve shim tool? Reply with quote
Anyone know where to get one other than main dealers.
(looked on ebay,but their all from the u.s.)
Also what price should i expect to pay?
Is there another way to do it without this tool (and without removing the cams).
Thanks
Dave
DRZ-400sm
NiteMare
PostPosted: 19:13 - 26 Oct 2008    Post subject: Reply with quote
have you got a picture of this tool ??
if it is the same or similar to the one i used on my gs550, i made my own out of a piece of 3mm thick steel 25mm wide , i just ground it to the shape i required using an angle grinder
it ain't broke...
i ain't fixed it enough
yen_powell
PostPosted: 19:27 - 26 Oct 2008    Post subject: Reply with quote
Looks like my old FJ1200s set up. I had the proper tool but didn't use it much. It's easier to use a small flat bladed screwdriver. See the notches in the bucket that holds the shim (part 13 and 14). Turn that with your fingers until the notch faces away from the cam lobe. (You should have already turned the crank so the flat part of the cam is bearing on the shim). Gently push the flat blade of the small screwdriver through the notch and under the shim. A tiny amount of the blade will be under the shim. Twist the screwdriver and you will find that the shim lifts and the screwdriver goes right under. The shim will come out straight into your hand first or second twist.
To put back, just push the shim between the bucket and the cam lobe, making sure the size stamp is facing the bucket and not the cam. The shim will just click back into place in the bucket. I used to be able to remove all the shims on my FJs in a few minutes this way, never had any damage.
https://www.cmsnl.com/img/partslist/cam-shaft-valve-gs500-2001-2002-usa_bigSUUSA92665.gif
XT1200Z and a DR350 in bits
PostPosted: 19:52 - 26 Oct 2008    Post subject: Reply with quote
Cheers for the reply's Thumbs Up Thumbs Up
Heres a pic of the tool:(attached)
Yen-powell-
That sounds like it should work,but could be a bit messy.
I'll try that as a last resort if i cant find the tool cheap enough.
DRZ-400sm
NiteMare
PostPosted: 21:00 - 26 Oct 2008    Post subject: Reply with quote
that picture appears to be exactly the same as required for my old 550 ...
you don't need to buy it, or make it identical ...
mine was a roughly shaped curve that tapered and wedged between the bucket and camshaft (not the lobe) to depress the bucket ..
as posted before (yen_powell), i flipped them out with a screwdriver and used a magnetic probe just to slide them out (easier than pliers)
it ain't broke...
BarryM
PostPosted: 03:22 - 30 Dec 2008    Post subject: Reply with quote
I brought one of these the other day, to do my Honda from
https://www.valvetool.com.au
this is a must have tool for any valve assembly
hmmmnz
PostPosted: 11:08 - 30 Dec 2008    Post subject: Reply with quote
the easiest way, is once you have measured your clearances and recorded the measure ments,
undo the camchain tensioner, then
undo the the cams and lift them up and pull the shim out,(leave the chain in place and put a mark on both the chain and cam sprocket, so if it does spin you can easily return the cam to its correct position)
once you have recorded the shims and got the new ones of correct size, put them all back in tighten the cams back up,
reset the tensionor before you stick the rocker cover back on,
job done,
have fun
the humans are dead
I kick arse for the lord
PostPosted: 12:07 - 30 Dec 2008    Post subject: Reply with quote
It's a bummer when you reply without looking at the date it was started Laughing
Cheers anyway though fella Razz
DRZ-400sm
hmmmnz
PostPosted: 12:13 - 30 Dec 2008    Post subject: Reply with quote
yeah i saw that just after i posted, fucken fuckers i hate when people do that,
not too worry
hows the bike running any way??
the humans are dead
PostPosted: 12:28 - 30 Dec 2008    Post subject: Reply with quote
Running sweet Very Happy
I'm gonna end up killing myself on it if i keep riding it in this weather Laughing
Embarassed too bloody fast
DRZ-400sm
The last post was made 17 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.24 - MySQL Queries: 16 - Page Size: 67.06 Kb
