Oil on my brakes
Cigaro
PostPosted: 08:38 - 28 Oct 2008    Post subject: Oil on my brakes Reply with quote
What's the best way to get oil off my brakes?
I've wiped as much as I can off the disc but it still seems reluctant to stop. Will I have to take the pads out and douse them in petrol or something?
NSR Mick
PostPosted: 08:46 - 28 Oct 2008    Post subject: Reply with quote
Brake cleaner. Wink
PostPosted: 08:51 - 28 Oct 2008    Post subject: Reply with quote
As above but use a tooth brush to clean out all the holes.
It's possible it's soaked into your pads a bit too, in which you'll either have to live with it (and be aware you will run over several kittens per journey because of this!) or get some new pads.
PostPosted: 08:57 - 28 Oct 2008    Post subject: Reply with quote
I'd wash the discs with brake cleaner and buy new pads. For the sake of £30 I'd rather be able to stop.
Cigaro
PostPosted: 09:03 - 28 Oct 2008    Post subject: Reply with quote
It's just had new pads though. I don't want to replace them again Sad
Seriously though, I'll douse the whole lot in brake cleaner, and if it's not right after that I'll replace them.
PostPosted: 09:04 - 28 Oct 2008    Post subject: Reply with quote
Well, to be blunt, you shouldn't have tried to ride the bike with oil on the discs!!
Cigaro
PostPosted: 09:06 - 28 Oct 2008    Post subject: Reply with quote
But Marjay, Oh Great One, I didn't realise there was oil on them until the first time I tried to stop.
BanditsHigh
Worse than a woman
PostPosted: 09:17 - 28 Oct 2008    Post subject: Reply with quote
Once you've cleaned all the oil off, rub the pads on a rough surface which should take off any remaining oil ... something like a paving slab should do it Thumbs Up
Oh and of course, take it easy until you feel that the brakes are 100% Very Happy
PostPosted: 09:24 - 28 Oct 2008    Post subject: Reply with quote
From what I've seen, the oil can soak a fair way in; it's often far from just on the surface.
My NSR fork oil used to leak over the front disc quite badly. The braking was quite variable; but still had enough to stop; though to do stoppies you might have to do a bit of lighter braking first to burn of a bit of oil.
In the end, you're probably still going to have better braking than the majority of 'classic' bikes, etc; just need to ride appropriately to the situation Smile.
Cigaro
PostPosted: 11:24 - 28 Oct 2008    Post subject: Reply with quote
Well, I've sprayed brake cleaner all over the disc and pads but it's still not quite right. No oil on the disc now but it still won't stop properly.
I've sprayed it again around the pads and left it to soak in for a few hours, with a bit of luck that will sort it, otherwise i'll take them out, soak them in petrol, burn them and then sand them down slightly. Apparently that works.
PostPosted: 11:54 - 28 Oct 2008    Post subject: Reply with quote
Take the pads out and use brake cleaner on them. Wouldn't expect it to have as much effect if the pads are still in place.
Itchy
PostPosted: 12:37 - 28 Oct 2008    Post subject: Reply with quote
the dangeorus method I did was to ride it off, my NTV oil filler cap wasn't tight and it leaked all over my back brake, I stopped wiped it off and continued riding another 200 miles , the oil 'burned' off and left a fine film of dust on my back brake, took it to an MOT 3 weeks later it passed.
Cigaro
PostPosted: 12:43 - 28 Oct 2008    Post subject: Reply with quote
Unfortunately it's the front one, if it was the back I could live with it.
The mechanic who put my fork seals in did a fantastic job, and then lost all credibility by leaving one of the little bolts undone at the bottom on the offside fork, causing it to drip oil all over the brakes as soon as I put the fork back on the bike.
I don't even know why there's a bolt there. It's obviously not to drain oil out (as there's an allen bolt to do that in the bottom of the fork leg). Perhaps it was the reason why I couldn't seperate the forks Very Happy
PostPosted: 12:54 - 28 Oct 2008    Post subject: Reply with quote
It is there to drain the oil out. The hex bolt is not to drain the forks, it is there to hold the forks together.
Cigaro
PostPosted: 13:50 - 28 Oct 2008    Post subject: Reply with quote
In which case, I can't believe he didn't tighten it up! What a mong!
On the plus side, he did do it for £18, which saved me a huge amount of hassle.
dissy-rxs
PostPosted: 18:34 - 29 Oct 2008    Post subject: Reply with quote
I would try and salvage the pads if this happened to my pushbike's pads....maybe..
On a motorcycle I would buy new pads.
But if they are brand new and you do really want to salvage them, this is what I used to do-
Grab a large, flat file. Clamp in vise with large flat side facing up. Scrape the pad up&down the length of the file. Repeat until at least 1/3rd of the pad material is taken off.
None of that messing around with sandpaper or the sidewalk.
Cigaro
PostPosted: 19:20 - 29 Oct 2008    Post subject: Reply with quote
A mechanic's told me to burn them, wipe the oil off, repeat until all the oil is gone and then sand them with sandpaper. I'll try that tonight and report back.
plugger147
PostPosted: 20:15 - 29 Oct 2008    Post subject: Reply with quote
Damn it, was about to suggest heating them with a hot air gun. The oil will rise to the top wipe it off and repeat until your happy then give them a good rubbing with some sandpaper.
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
ZRX61
Victor Meldrew
PostPosted: 20:17 - 29 Oct 2008    Post subject: Reply with quote
Apparently not.... Rolling Eyes
Cigaro
PostPosted: 20:23 - 29 Oct 2008    Post subject: Reply with quote
I have a blowtorch actually... Whistle
Just waiting for my mate to get back so I can go and use his garage Laughing
The last post was made 18 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.92 - MySQL Queries: 16 - Page Size: 113.88 Kb
